Offy 216 intake-will it fit a 235?
Discussion in 'The Hokey Ass Message Board' started by Kev Nemo, Feb 5, 2006.
  1. Kev Nemo
    Kev Nemo
  2. VAPHEAD
    VAPHEAD
  3. 216's and 235/261's have a different intake port diameter. It'll bolt up, but it's not the same.
  4. dmarv
    dmarv
    Alliance Vendor
    from Exeter, CA
    As everyone else has said, "Yes". Here is the listing fro, the Offenhauser catalog.
  5. 302GMC
    302GMC
    from Idaho
    You'll have to run headers-won't bolt to stock exh. manifold ... also, every Offy intake I've ever seen has to be ground for clearance when using Fenton headers ...
    302
  6. orcas tow
    orcas tow
    I recently installed a 54 p***enger car 235 in place of the origonal 216 in a 51 2 ton truck & the stock 216 intake/exhaust was a direct bolt on to the 235.
  7. Kev Nemo
    Kev Nemo
    Yeah-but will it fit a 1962 235?
  8. Dale Fairfax
    Dale Fairfax
    A 235 is a 235 is a 235 unless YOUR 235 is really a 230 since it's a '62. '62 was the first year for the new series engines with 7 mains but my MoToRs Manual indicates that 235s still existed in '62. There is no interchangeability between the 216/265/261 series and the 230/250/292 series.
  9. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I would have a machine shop bore the alignment ring size out to 235 diameter. The rings keep the manifold from sliding down, and it will do that without them. Another method of keeping the manifold in place is to get everything lined up and drill at least two holes through the manifold and into the side of the cylinder head. Remove the manifold and drive an appropriate size dowel pin into the hole in the head, and drill the hole in the manifold one drill size larger so it will slip over the pin when bolted to the head.
  10. 302GMC
    302GMC
    from Idaho
    Hi,Orcas,
    Lots of the '41 up big trucks had 235 engines that look identical to the 216,at least until '49 - '50 up 235 trucks have the short side plate if I remember right.
    302
  11. orcas tow
    orcas tow
    The origonal engine in the truck had non pressurized rods so I ***umed it was the origonal 216?
  12. 302GMC
    302GMC
    from Idaho
    The early 235 truck had same oiling system as 216 ... first full pressure Chevy is '53 ...
    302
