Offy Dual Intake w/ Stock Generator Help!
Discussion in 'The Hokey Ass Message Board' started by papasmurf240, Nov 19, 2012.
  1. papasmurf240
    papasmurf240
    I just picked up an offenhauser 2 x 2 for my 8BA flathead. This is not the super dual but the regular dual that is supposed to let you run the generator in the stock location. I got everything bolted up today and there is about 1/4 inch of interference between the carb and generator. Am I doing something wrong here? Can you only run a certain type of Carb and still leave the generator in the stock location?
    I've dug through the search function and I can't find anybody else that has had this problem.
    Any help would be greatly appreciated.
  2. arto
    arto
    Which carbs are you running? I believe Strombergs with the fuel inlet to the side are supposed to offer more clearance than Holley 94s.
  3. papasmurf240
    papasmurf240
    Stock ford script 94's
  4. V8 Bob
    V8 Bob
    Is the generator correct? It should have a hole in the case that locates on a small pin in the bracket.
  5. Bruce Lancaster
    Bruce Lancaster
    Good idea there. Most of them have TWO holes for location actually, because same gen mounts to different brackets for six and v8 applications. I do not remmeber how far apart said holes are. Remove gen from bracket and look for a small locater pin on the bracket, holes in gen case.
  6. nutter_street_rodder
    from Nevis MN
    I seem to recall that Lincoln & Mercury generators were a higher output, but were a little longer length than a Ford.
  7. Strombergs will fit, 94s need to sit on phenolic spacers to clear.
