Technical oil and temp sending units
Discussion in 'The Hokey Ass Message Board' started by CayoRV, Mar 14, 2025.
  1. CayoRV
    CayoRV
    I have a 1951 Nash gauge cluster I want to use which contains the speedo, fuel, oil and temp. Problem is I don't have the sending units for the oil and temp. The fuel is not a problem and the speedo is very nice. I have been totally unsuccessful in finding those sending units so my question is would another manufacturers, say Ford or GM, sending units work with these gauges?
    Any help appreciated.
    Sharpone likes this.
  2. squirrel
    Sure, another sender might work, but first you need to figure out what resistance needs to be. I'd connect a gauge to power and a resistor in place of the sender, to ground, and see what it reads. I'd start with resistances in the range of 10 to 300 ohms.
    Once you figure out what resistance is needed for 0 and full scale, you can search for matching senders. I have some catalog listings that might help.
  3. RodStRace
    RodStRace
    They have the oil sender, I think
    https://www.nashparts.com/Parts/Group3.htm
    50-54 Rambler;
    52-54 Statesman/Amb***ador
    Oil Pressure Gauge
    (Sending Unit In Cylinder Block)
    3134704 NOS, $59
    but don't show a temp sender that far back. You could ask them if they have a resistance number.
    Sharpone and squirrel like this.
  4. squirrel
    his cluster might be 51 Statesman, so that might not fit.
  5. Do it like @squirrel said. You can also make a test setup with a variable resistor and a meter.
    Sharpone, 19Eddy30 and RodStRace like this.
  6. gene-koning
    gene-koning
    I'd be surprised if the temp gauge didn't originally have the closed capillary bulb for the end in the motor. Didn't know anyone was using electrical temp (or oil pressure) gauges back then.
    Sharpone and Jokester like this.
  7. squirrel
    I found a 51 Statesman cluster on ebay to look at pictures, it definitely has electric oil and temp gauges
    Truckdoctor Andy and Sharpone like this.
  8. gene-koning
    gene-koning
    Well, I'm surprised.
  9. leon bee
    leon bee
    He never said what he was using the gauges in.
  10. RodStRace
    RodStRace
    It could go into any combustion engine. The gauge still needs the correct resistance to ground to register the correct info on the gauge. Just needs the correct voltage. Even polarity shouldn't make a difference.
    leon bee and Sharpone like this.
  11. squirrel
    I was too.
    Sharpone and Truckdoctor Andy like this.
  12. CayoRV
    CayoRV
    Yes, the gauges are electric, I was surprised also. I will check with nashparts.com and see what they may have to offer, thanks.
  13. pprather
    pprather
  14. In_The_Pink
    In_The_Pink
    Sorry, no. Stock engine parts are long gone.
    pprather likes this.
  15. Blues4U
    Blues4U
    from So Cal
    Or use a potentiometer, cheap and widely available. Wire it up as a variable resistor, i.e. just use the center terminal and one outer terminal, then operate the pot to find where the gauge operates, then measure the resistance. That will tell you what resistance range you need for the sending unit.
  16. squirrel
    If you use a potentiometer, find one with low resistance...but most you'll find are 10k or more.
    I would use resistors, because I have a bunch, and I like to have an excuse to remember how the color code works every now and then, and I also don't have any low resistance pots.
  17. Blues4U
    Blues4U
    from So Cal
  18. In_The_Pink
    In_The_Pink
  19. deathrowdave
    deathrowdave
    from NKy
    What research I have done which isn’t a lot , I determined the were 3 ranges used . Random between GM , FORD and MOPAR . As the Squirrel has said a POT will be your friend . Once you determine what you need they are produced in almost any thread one could ever ask for
