Oil Balancer
Discussion in 'The Hokey Ass Message Board' started by Jimv, Dec 21, 2013.
  1. Jimv
    Jimv
    How does a "oil filled" Balancer work, what is the advantage of them & are they worth the extra money?
    Thanks
    JimV
  2. BOBCRMAN
    BOBCRMAN
    from Holly
    Do you mean a "fluid balancer"? The material is not oil. They also have a life cycle and have to be replaced periodically.
  3. themoose
    themoose
    I can tell you that a lot of high performance aftermarket cranks are coming with a warning in the box about using a fluid filled damper. That must mean something.
  4. gary terhaar
    gary terhaar
    from oakdale ny
    **** flat out says,use them and your crank will break.
    Lots of testimonials from circle track racers that break the nose off their cranks after as soon as one race in.
    Either a pioneer Sfi approved(quite affordable) or a ati super damper are the way to go.
  5. Jimv
    Jimv
    what are those?
    JimV
  6. gary terhaar
    gary terhaar
    from oakdale ny
    Summit.
  7. gary terhaar
    gary terhaar
    from oakdale ny
    Ati
