Technical Oil Bath Air Cleaner
Discussion in 'Traditional Hot Rods' started by johnrfray, Sep 28, 2019.
  1. Does somebody make a modern filter that you can use inside the oil bath filter original for the 48 ford 8 flathead ?
  2. Oil bath filters work well
    Take yours apart and measure it. I’m sure something fits
    Once you have some measurements try ontario filter and supply in Mississauga off Shawson.
    They can find you a filter based just off id od and height.
    Easy guys to work with and cheap.
