Technical Oil by intake bolt on sbc
Discussion in 'The Hokey Ass Message Board' started by RICH B, Jul 27, 2021.
  1. RICH B
    RICH B
    Never had this happen before; but I'm getting a little oil seepage around the second bolt back on the driver's side on this engine (the one hidden behind the temp sender boss in the picture). Long ago, I learned to always add Permatex to the middle two so oil didn't seep. I don't have a loose head handy to check; but is this a common thing too?
  2. squirrel
    there are a few other holes that go through....looks like you found one of them. Just pull it out and put some sealer on it and put it back in, should be ok.
    Blues4U, UNSHINED 2, RICH B and 4 others like this.
  3. Mario p herrera
    Mario p herrera
    Had the same problem with a older small block Chevy intake manifold I had .I had to seal it up with thread sealer
    RICH B and loudbang like this.
  4. gimpyshotrods
    gimpyshotrods
    I am in the "if the hole is not blind, it gets sealer" camp.
    I use Loc***e 545.
    Just Gary, RICH B and loudbang like this.
  5. larry k
    larry k
    Try some pipe sealant on the threads ,then use copper washers ,they won’t ever leak again !!!
  6. It's just letting you know it still has oil in it ;)
    RICH B, olscrounger and Blues4U like this.
