Hot Rods Oil cooler barbed fitting conversion
Discussion in 'The Hokey Ass Message Board' started by RmK57, Feb 14, 2022.
  1. RmK57
    RmK57
    I would like to change over from barbed fittings to AN style fittings on my transmission cooler. They make a compression fittings for this but the problem I have is the oddball size on the cooler inlet / outlet ports. O/D of the tube is .340 and a standard 5/16 compression fitting is .312. Rounded off 11/32 is .340 and doubt they make that size of fitting.
    Any idea's?
    What I have now is hose with hose clamps which is alright but I still get a bit of leakage or vapor from them over time that messes up my radiator.
  2. pprather
    pprather
  3. mad mikey
    mad mikey
    Yep , those clamps work great for a variety of fluid hoses. Make sure you are also using top quality hose.
    egads and Fabulous50's like this.
  4. RmK57
    RmK57
    Never even thought of those. I may have to go with something like that.
    mad mikey and pprather like this.
  5. BamaMav
    BamaMav
    from Berry, AL
    I just ran a couple of short runs of rubber cooler hose, 4" or so, then connected that to the AN hose with a AN barb fitting. Of course my cooler is a stand alone unit mounted under the car, not in the radiator, and is out of normal sight. I snugged my clamps after I had run it a few times and while the lines were warm, so far, no leaks.
  6. Fabulous50's
    Fabulous50's
    from Maine
    I too have found that worm hose clamps are junk for automotive use. Ever notice how none of the OEMs have used them since to 80s?
    mad mikey likes this.
  7. fsae0607
    fsae0607
    I like using oetiker clamps for stuff like this that's more or less a permanent install.
    Harley Davison uses them on their oil & FI lines.
  8. pprather
    pprather
    My rod has the same problem. I've lived with it, but now see an easy and inexpensive solution. Thanks for starting this thread.
  9. BamaMav
    BamaMav
    from Berry, AL
    If you can find the USA made ones they are a better quality than the China made ones. My local parts store still gets USA made ones at times, I go through the bin and pick them out when I need clamps. I have heard some guys get them in the import section of Pull a part, some of them are still using the German made ones that are good as well.
    Fabulous50's likes this.
  10. 325w
    325w
    Make a knot on the end of the steel line with the flare tool use good hose and the fuel injection clamps.
  11. Fabulous50's
    Fabulous50's
    from Maine
  12. gene-koning
    gene-koning
    The odds are the barbed hose connection in the cooler is a pipe thread. You can get a br*** compression fitting with the correct threads, just take your hose barb in and see what the threads are for sure and get the proper size br*** fitting.
    Or use the injection clamps on hydraulic hose, non-hydraulic hose will break down from the modern trans fluid pretty fast. Tighten the clamps, run the car up to operating temp, let it cool, and retighten the clamps.
  13. sacminiwheels
    sacminiwheels
    Belmetric.com sells the German made Norma brand, stainless and very nice. Surprisingly inexpensive.
    wraymen likes this.
