Technical Oil cooler, Condenser Order?
Discussion in 'The Hokey Ass Message Board' started by AldeanFan, Jan 17, 2026.
  1. AldeanFan
    AldeanFan
    I’m adding Vintage Air to my woody this winter.
    It currently has a big transmission cooler mounted in front of the radiator.
    what is the best position for the condenser?
    Should it be
    Condenser - Cooler - Rad
    Or
    Cooler - Condenser- Rad
    or does it matter?
  2. Bandit Billy
    Bandit Billy
    The more **** you stack in front of the radiator, the less air flow through the core. I would move the ****** cooler if was my rig, it does not need to be out in front of the radiator. I mounted my cooler under the truck, and it keeps the transmission at proper temp even when it was idling at the transmission shop last year during a pressure test.
    If you have to stack them, I guess I would go small, bigger, biggest for aesthetics.
    AldeanFan and Just Gary like this.
