Oil Dry... then what?
Discussion in 'The Hokey Ass Message Board' started by guiseart, Feb 28, 2008.
  1. guiseart
    guiseart
    ...after soaking up the oil on a concrete floor, is there any home remedy to get rid of the stain?
  2. jusjunk
    jusjunk
    from Michigan
    Had a couple friends that owned a gas station years ago they said gas and tide worked great.. No smoking though..
    Dave
  3. 29 sedanman
    29 sedanman
    from Indy
    On a concrete drive if you work the oil dry into the concrete by crushing it (stepping on it) it breaks down finer and seems to work more of the oil out of the pores. Not sure if it works as well an a smooth floor or not. The floor coatings companies I am sure must sell something for cleaning concrete that would have to remove it to get the epoxy to stick.
  4. Section 8
    Section 8
    from AZ
    Gas, laundry soap, brake cleaner.
    Bleach or acid will simply burn off the top layer of concrete and you'll have a very white driveway that is still oil stained.
  5. LowFat48
    LowFat48
    gas + powdered laundry soap = napalm , be careful.
  6. chaos10meter
    chaos10meter
    from PA.
  7. Section 8
    Section 8
    from AZ
    I guess I should have been more clear-- First gas, then brake cleaner then scrub with water and laundry soap-- Not all at the same time!
    And no gas if it's inside a garage- that's for driveways. Gas vapors gather near the floor, and that's where your pilot lights are.
    Acid will just eat up your concrete.
  8. Make sure you don't have an old fridge in the shop while using gas or shit that burns. If you got the floor covered and that bitch kicks on it's GOOD NIGHT IRENE!!!!!!!!!!!!!!!!!!!!
  9. flathead A
    flathead A
    from michigan
    Try a bottle of coca cola I heard that it works but have not tried it.Like 29 sedanman says works good also.
  10. TxRat
    TxRat
    Yep this works for us. grind it in by sliding your foot back and forth ....
  11. SHRUM
    SHRUM
    Lay oil dry (kitty litter) let sit for a while. Sweep up. Spray Carb cleaner and cover entire stain. Let sit a few minutes. Then poor oil dry on top of the carb cleaner and sweep up. It will be cleaner than the rest of the concrete around it.
  12. simple green. full strength. stiff bristled brush..
  13. zzford
    zzford
    Try oil dry then run a concrete block over the oil dry. That's what we used at a gas station I worked at when I was a kid. Worked good.
  14. CraigKrage
    CraigKrage
    from central IL
    CreteClean and a Mop with water.
  15. Pete1930
    Pete1930
    from Boston
    Yup - this is how I do it. I've also heard that using ashes from the fireplace works well too -- it's smaller in size than crushed kitty litter. :confused:I've never tried it though, always used the crushed kitty litter approach.
    Good luck
    Pete
  16. misfit36
    misfit36
    from new york
    these all seem to be good ideas for concrete and similar surfaces. does anyone know about remving stains from asphalt and blacktop? i kinda * cough cough* dripped some oil on pops' driveway. not a happy camper.
  17. SaltCityCustoms
    SaltCityCustoms
    You just need to learn to reorganize the shop and put a work bench or large tool over the stain, then it will go away!
  18. 067chevy
    067chevy
    I had a major oil spill on my shop floor used the oil dry and then washed it with parsons ammonia. Can't tell I ever spill oil there. floor looked new
  19. rstanberry
    rstanberry
    from terrell tx
    Fireplace ashes work pretty good
  20. bulletproof1
    bulletproof1
    from tulsa okla
    i always pour some chemtool on the spot ,then pour the oil dry over that ,then rub it in with a shovel,let it set a few minutes .shovel up the oil dry...leaves a nice clean dry spot....
  21. Section 8
    Section 8
    from AZ
    Laundry soap.
    Anything with solvent will also dissolve the asphalt.
  22. guiseart
    guiseart
    Nice suggestions! Thanks, keep goin' if there is more.
  23. slo60
    slo60
    chem clean (powder concrete cleaner) degreaser (red, water based) simple green and a little bit of dishsoap, lots of water, and a scrub brush... pulled up 4 year old oil stains with this combo...
    keith
  24. 3wLarry
    3wLarry
    from Owasso, Ok
    GUNK makes a driveway cleaner just for this type of stain.
    kidcampbell71 likes this.
  25. fab32
    fab32
    Put down the oil dry then "scrub" it with a short (4-5") piece of 2x4 keeping the grit under the board and overlapping the strokes. A couple of passes will make the concrete good as new. If the stain has been down a long time it takes a couple of applications to do the trick.
    Frank
  26. Slate
    Slate
  27. rjgideon
    rjgideon
    Take a hammer to some drywall scraps over your stain. The powder will soak up the oil in the pits. You can just let it sit for a few days and then spray off with water (or rain). I've also used the kitty litter a few times.
  28. Danimal
    Danimal
    1. A-D Truckers
    I use WD-40 and then wipe it up with a clean rag. Sometimes leaves a 'too clean' spot, though.
  29. jetmek
    jetmek
    ya aint seen a worse mess on the floor till youve youve spent a weekend chasing a couple of sludged up stuck flatheads around getting them apart. old fashioned mineral spirits worked in with a broom followed by oildry does a good job when im done...
  30. Fix the oil leak!~!!!!!!
