Hot Rods Oil filter bypass question
Discussion in 'The Hokey Ass Message Board' started by MikeC62, Sep 11, 2016.
  1. MikeC62
    MikeC62
    from Missouri
    The byp*** spring in my oil filter mount is bad. Can I do away with the byp*** hole tig welding it shut or try to find a new spring and rebuild it? image.jpg image.jpg
  2. Slopok
    Slopok
    I'm sure they put the spring in there for a reason, every time that I've left something out figuring that's not necessary it came back to bite me.:eek:
    AVater likes this.
  3. Blues4U
    Blues4U
    from So Cal
    Holy ****!! Dude, springs are cheap and easy to find, put a new spring in it. The byp*** is there for a reason, if the filter gets plugged and the pressure differential across the inlet and outlet gets too great the byp*** opens up to allow oil around the element, so that your bearings don't starve!!! Don't tig weld it closed! Put a new spring in it, (you have to match it up so the pressure is the same) or replace the entire ***embly if you can't find a correct spring, but don't weld it closed.
  4. derpr
    derpr
    INVISIBLEKID likes this.
  5. jimmy six
    jimmy six
    Not sure on the Milodon and its application but most oil filters have the byp*** and none of my remotes have anything but the 2 holes. You should look up the AC PF-7 filter and see what it is or was. Good luck.
  6. MikeC62
    MikeC62
    from Missouri
    Probably the safest thing to do is get a new filter mount unless I can a find a filter with a byp***. I would replace the spring but it would just a guess on what pressure the new spring would open. I was just hoping someone had a miracle cure.
  7. Moondog13
    Moondog13
  8. saltflats
    saltflats
    from Missouri
    Find one out of a Chevy one.
    Bet that a machine shop my have one that they removed and plugged.
  9. flux capacitor
    flux capacitor
    I've always plugged them for oval track builds yet, I do run them on my drivers. I presume somehow before the days of oil filters, ex. like a babbit 235 six I'd rebuilt, stuff lasted for a while back then, with all the dirt road dust & metallic particulates scratching the bearing shells & cylinder bores. That being said, I believe above something like 5 psi, in many oil filter systems the byp*** opens & lets the "dirty stuff" byp*** the filter & sends some of it through the whole shabang. Flux.
