Oil Filter question- 283
Discussion in 'The Hokey Ass Message Board' started by ferrets bueller, Mar 9, 2012.
  1. ferrets bueller
    ferrets bueller
    from NW Indiana
    I have a 66 283 that has an oil filter adapter, to replace the original canister style filter.
    I plan on changing the oil when I pull it out of the garage after being parked for the winter in a week or two, but have no idea what filter to buy.
    It currently has a filter that says Champ PH25 on it...which, from my research... depending on the source, appears to be an Australian Marine application!?!?, a GMC truck filter, or a non-Chevy GM V8 filter. Needless to say...I am quite confused.
    Does anyone happen to know exactly what filter to buy? Does the filter vary depending on what adapter was installed?
    Any help would be greatly appreciated.
  2. squirrel
    That's a Chevy filter, just get another one with the same number....or maybe I'm out to lunch? PH5 is a common chevy filter.
    There were some adapters that used the Ford-Dodge filter (PH-8A). The O ring is way smaller size, so it's pretty easy to tell which one you have.
  3. ferrets bueller
    ferrets bueller
    from NW Indiana
    Thats the problem- its not PH5, its PH25. And as far as I know, its not the same as the Fram PH25, as its appears the diameters may be different. I haven't been able to find a real cross-reference on a Champ PH25.
  4. Mr48chev
    That should equal a Wix 57099 http://www.wixfilters.com/filterlookup/ResultsExact.asp?PartNo=PH-25
    As Jim said it's a regular Chevy filter. Wix 57099 or Napa Gold Fil 1069
    Make sure that the gasket on the filter lines up right with the gasket surface on the adapter though as most of the earlier adapters used the PH8 or Ford style filter rather then the Chevy style filter.
  5. flamed34
    flamed34
    I searched Champ ph25 cross reference and this came up. This is an add for a "high tech" oil filter, and lists all of the filters it replaces. http://www.synlube.com/GLwm.htm
    <table border="1" width="419"><tbody><tr><td width="212">
    Product Type: ​
    </td> <td width="195">
    Full-Flow Lube Spin-on​
    </td> </tr> <tr> <td width="212">
    Anti-Drain Valve ​
    NO​
    Product Height ​
    4.00"​
    Thread. ​
    13/16-16 ​
    Product O.D. ​
    3.75"​
    Relief Valve Setting PSI ​
    NONE​
    </td> </tr> </tbody></table>
    <hr> <table bgcolor="white" border="2" cellpadding="4" cellspacing="2" width="400" align="left"><tbody><tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_0" style="height:12px;"> <th>BRAND NAME </th><th>Part Number </th></tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_0" style="height:12px;"> <td class="ig_cd1923c4_9">AC-DELCO</td> <td class="ig_cd1923c4_10">PF12</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_1" style="height:12px;"> <td class="ig_cd1923c4_9">AC-DELCO</td> <td class="ig_cd1923c4_10">PF25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_2" style="height:12px;"> <td class="ig_cd1923c4_9">ALLIANCE</td> <td class="ig_cd1923c4_10">ABP/N10G-LF651</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_3" style="height:12px;"> <td class="ig_cd1923c4_9">ALLIS-CHALMERS </td> <td class="ig_cd1923c4_10">1146873</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_4" style="height:12px;"> <td class="ig_cd1923c4_9">ALLIS-CHALMERS </td> <td class="ig_cd1923c4_10">11468733</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_5" style="height:12px;"> <td class="ig_cd1923c4_9">ALLIS-CHALMERS </td> <td class="ig_cd1923c4_10">1146873-3</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_6" style="height:12px;"> <td class="ig_cd1923c4_9">ALLOY</td> <td class="ig_cd1923c4_10">ABH-30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_7" style="height:12px;"> <td class="ig_cd1923c4_9">AMSOIL</td> <td class="ig_cd1923c4_10">ASF25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_8" style="height:12px;"> <td class="ig_cd1923c4_9">AMSOIL</td> <td class="ig_cd1923c4_10">EAO25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_9" style="height:12px;"> <td class="ig_cd1923c4_9">AQUA POWER</td> <td class="ig_cd1923c4_10">6006</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_10" style="height:12px;"> <td class="ig_cd1923c4_9">ARCO </td> <td class="ig_cd1923c4_10">A0F-49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_11" style="height:12px;"> <td class="ig_cd1923c4_9">ATLAS</td> <td class="ig_cd1923c4_10">G-71</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_12" style="height:12px;"> <td class="ig_cd1923c4_9">AUTO PACE</td> <td class="ig_cd1923c4_10">111</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_13" style="height:12px;"> <td class="ig_cd1923c4_9">AUTO VALUE</td> <td class="ig_cd1923c4_10">1-30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_14" style="height:12px;"> <td class="ig_cd1923c4_9">AUTOEDGE</td> <td class="ig_cd1923c4_10">AL30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_15" style="height:12px;"> <td class="ig_cd1923c4_9">AUTOPAR</td> <td class="ig_cd1923c4_10">FE134</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_16" style="height:12px;"> <td class="ig_cd1923c4_9">AUTOPRO</td> <td class="ig_cd1923c4_10">2069</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_17" style="height:12px;"> <td class="ig_cd1923c4_9">AUTOWIZE</td> <td class="ig_cd1923c4_10">A6</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_18" style="height:12px;"> <td class="ig_cd1923c4_9">AWARD</td> <td class="ig_cd1923c4_10">AOF-49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_19" style="height:12px;"> <td class="ig_cd1923c4_9">BALDWIN</td> <td class="ig_cd1923c4_10">B27</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_20" style="height:12px;"> <td class="ig_cd1923c4_9">BIG A</td> <td class="ig_cd1923c4_10">92046</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_21" style="height:12px;"> <td class="ig_cd1923c4_9">BIG A</td> <td class="ig_cd1923c4_10">92069</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_22" style="height:12px;"> <td class="ig_cd1923c4_9">BOSCH</td> <td class="ig_cd1923c4_10">0451104002</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_23" style="height:12px;"> <td class="ig_cd1923c4_9">BRAVO</td> <td class="ig_cd1923c4_10">B49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_24" style="height:12px;"> <td class="ig_cd1923c4_9">BUMPER TO BUMPER</td> <td class="ig_cd1923c4_10">BBO-49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_25" style="height:12px;"> <td class="ig_cd1923c4_9">BUMPER TO BUMPER</td> <td class="ig_cd1923c4_10">BBO-4900</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_26" style="height:12px;"> <td class="ig_cd1923c4_9">CAM2</td> <td class="ig_cd1923c4_10">C49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_27" style="height:12px;"> <td class="ig_cd1923c4_9">CANADIAN TIRE</td> <td class="ig_cd1923c4_10">17-1735-8</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_28" style="height:12px;"> <td class="ig_cd1923c4_9">CARCARE</td> <td class="ig_cd1923c4_10">IOF30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_29" style="height:12px;"> <td class="ig_cd1923c4_9">CARQUEST</td> <td class="ig_cd1923c4_10">85046</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_30" style="height:12px;"> <td class="ig_cd1923c4_9">CARQUEST</td> <td class="ig_cd1923c4_10">85069</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_31" style="height:12px;"> <td class="ig_cd1923c4_9">CARQUEST</td> <td class="ig_cd1923c4_10">B49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_32" style="height:12px;"> <td class="ig_cd1923c4_9">CASITE</td> <td class="ig_cd1923c4_10">CF25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_33" style="height:12px;"> <td class="ig_cd1923c4_9">CASTROL</td> <td class="ig_cd1923c4_10">CKF-5</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_34" style="height:12px;"> <td class="ig_cd1923c4_9">CENEX</td> <td class="ig_cd1923c4_10">CO54</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_35" style="height:12px;"> <td class="ig_cd1923c4_9">CHAMP</td> <td class="ig_cd1923c4_10">AR25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_36" style="height:12px;"> <td class="ig_cd1923c4_9">CHAMP</td> <td class="ig_cd1923c4_10">PH12</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_37" style="height:12px;"> <td class="ig_cd1923c4_9">CHAMP</td> <td class="ig_cd1923c4_10">PH25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_38" style="height:12px;"> <td class="ig_cd1923c4_9">CHAMP</td> <td class="ig_cd1923c4_10">PH25B</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_39" style="height:12px;"> <td class="ig_cd1923c4_9">CHAMPION</td> <td class="ig_cd1923c4_10">OF03</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_40" style="height:12px;"> <td class="ig_cd1923c4_9">CHAMPION</td> <td class="ig_cd1923c4_10">OF413</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_41" style="height:12px;"> <td class="ig_cd1923c4_9">CHECKER</td> <td class="ig_cd1923c4_10">5578052</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_42" style="height:12px;"> <td class="ig_cd1923c4_9">CHECKER</td> <td class="ig_cd1923c4_10">701069</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_43" style="height:12px;"> <td class="ig_cd1923c4_9">CHRIS-CRAFT </td> <td class="ig_cd1923c4_10">0681-08746</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_44" style="height:12px;"> <td class="ig_cd1923c4_9">CHRIS-CRAFT </td> <td class="ig_cd1923c4_10">1681-08746</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_45" style="height:12px;"> <td class="ig_cd1923c4_9">CHRYSLER </td> <td class="ig_cd1923c4_10">2451859</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_46" style="height:12px;"> <td class="ig_cd1923c4_9">CHRYSLER </td> <td class="ig_cd1923c4_10">990359</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_47" style="height:12px;"> <td class="ig_cd1923c4_9">CHRYSLER </td> <td class="ig_cd1923c4_10">J0990359</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_48" style="height:12px;"> <td class="ig_cd1923c4_9">CITGO</td> <td class="ig_cd1923c4_10">C49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_49" style="height:12px;"> <td class="ig_cd1923c4_9">CO-OP</td> <td class="ig_cd1923c4_10">PL-PF-12</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_50" style="height:12px;"> <td class="ig_cd1923c4_9">CO-OP</td> <td class="ig_cd1923c4_10">VER-49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_51" style="height:12px;"> <td class="ig_cd1923c4_9">CROSLAND</td> <td class="ig_cd1923c4_10">543</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_52" style="height:12px;"> <td class="ig_cd1923c4_9">CRUISEMASTER </td> <td class="ig_cd1923c4_10">203</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_53" style="height:12px;"> <td class="ig_cd1923c4_9">CRUSADER</td> <td class="ig_cd1923c4_10">201104</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_54" style="height:12px;"> <td class="ig_cd1923c4_9">DEFENSE</td> <td class="ig_cd1923c4_10">DL5632</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_55" style="height:12px;"> <td class="ig_cd1923c4_9">DELUXE</td> <td class="ig_cd1923c4_10">WD-129</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_56" style="height:12px;"> <td class="ig_cd1923c4_9">DELUXE</td> <td class="ig_cd1923c4_10">WD-130</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_57" style="height:12px;"> <td class="ig_cd1923c4_9">DELUXE</td> <td class="ig_cd1923c4_10">WD-52</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_58" style="height:12px;"> <td class="ig_cd1923c4_9">DELUXE</td> <td class="ig_cd1923c4_10">WD-54</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_59" style="height:12px;"> <td class="ig_cd1923c4_9">DEUTSCH</td> <td class="ig_cd1923c4_10">D432</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_60" style="height:12px;"> <td class="ig_cd1923c4_9">DEUTSCH</td> <td class="ig_cd1923c4_10">PH12</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_61" style="height:12px;"> <td class="ig_cd1923c4_9">DONALDSON</td> <td class="ig_cd1923c4_10">LFP550025</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_62" style="height:12px;"> <td class="ig_cd1923c4_9">DONALDSON</td> <td class="ig_cd1923c4_10">P550025</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_63" style="height:12px;"> <td class="ig_cd1923c4_9">DYNALIFE </td> <td class="ig_cd1923c4_10">CN-30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_64" style="height:12px;"> <td class="ig_cd1923c4_9">ECONO LUBE</td> <td class="ig_cd1923c4_10">L20049</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_65" style="height:12px;"> <td class="ig_cd1923c4_9">EVERGARD</td> <td class="ig_cd1923c4_10">E49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_66" style="height:12px;"> <td class="ig_cd1923c4_9">FACET</td> <td class="ig_cd1923c4_10">30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_67" style="height:12px;"> <td class="ig_cd1923c4_9">FIAAM</td> <td class="ig_cd1923c4_10">FT4967</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_68" style="height:12px;"> <td class="ig_cd1923c4_9">FILTERS INCORPORATED</td> <td class="ig_cd1923c4_10">OF30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_69" style="height:12px;"> <td class="ig_cd1923c4_9">FIRESTONE</td> <td class="ig_cd1923c4_10">TF-30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_70" style="height:12px;"> <td class="ig_cd1923c4_9">FLAG</td> <td class="ig_cd1923c4_10">C-13A</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_71" style="height:12px;"> <td class="ig_cd1923c4_9">FLAG</td> <td class="ig_cd1923c4_10">C-30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_72" style="height:12px;"> <td class="ig_cd1923c4_9">FLEETGUARD</td> <td class="ig_cd1923c4_10">LF651</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_73" style="height:12px;"> <td class="ig_cd1923c4_9">FLEETRITE</td> <td class="ig_cd1923c4_10">LFR-8651</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_74" style="height:12px;"> <td class="ig_cd1923c4_9">FORD</td> <td class="ig_cd1923c4_10">C3RZ-6731-A</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_75" style="height:12px;"> <td class="ig_cd1923c4_9">FORD</td> <td class="ig_cd1923c4_10">C3RZ-6731-C</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_76" style="height:12px;"> <td class="ig_cd1923c4_9">FORD</td> <td class="ig_cd1923c4_10">D7PJ-6714-AA</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_76" style="height:12px;"> <td class="ig_cd1923c4_9">FRAM</td> <td class="ig_cd1923c4_10">PH30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_77" style="height:12px;"> <td class="ig_cd1923c4_9">FREIGHTLINER</td> <td class="ig_cd1923c4_10">11-09948-000</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_78" style="height:12px;"> <td class="ig_cd1923c4_9">GENERAL MOTORS</td> <td class="ig_cd1923c4_10">5578052</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_79" style="height:12px;"> <td class="ig_cd1923c4_9">GENERAL MOTORS</td> <td class="ig_cd1923c4_10">5578085</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_80" style="height:12px;"> <td class="ig_cd1923c4_9">GENERAL MOTORS</td> <td class="ig_cd1923c4_10">5578108</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_81" style="height:12px;"> <td class="ig_cd1923c4_9">GENERAL MOTORS</td> <td class="ig_cd1923c4_10">6435679</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_82" style="height:12px;"> <td class="ig_cd1923c4_9">GENERAL MOTORS</td> <td class="ig_cd1923c4_10">6437055</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_83" style="height:12px;"> <td class="ig_cd1923c4_9">GENERAL MOTORS</td> <td class="ig_cd1923c4_10">6437946</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_84" style="height:12px;"> <td class="ig_cd1923c4_9">GENERAL MOTORS</td> <td class="ig_cd1923c4_10">6438261</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_85" style="height:12px;"> <td class="ig_cd1923c4_9">GONHER</td> <td class="ig_cd1923c4_10">GP3</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_86" style="height:12px;"> <td class="ig_cd1923c4_9">GONHER</td> <td class="ig_cd1923c4_10">GP3M</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_87" style="height:12px;"> <td class="ig_cd1923c4_9">GOODYEAR</td> <td class="ig_cd1923c4_10">222-4505</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_88" style="height:12px;"> <td class="ig_cd1923c4_9">GOODYEAR</td> <td class="ig_cd1923c4_10">L30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_89" style="height:12px;"> <td class="ig_cd1923c4_9">GRAND PRIX</td> <td class="ig_cd1923c4_10">PH12</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_90" style="height:12px;"> <td class="ig_cd1923c4_9">GRAND PRIX</td> <td class="ig_cd1923c4_10">PH25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_91" style="height:12px;"> <td class="ig_cd1923c4_9">GREASE MONKEY</td> <td class="ig_cd1923c4_10">GM20049</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_92" style="height:12px;"> <td class="ig_cd1923c4_9">GREASE MONKEY</td> <td class="ig_cd1923c4_10">GM30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_93" style="height:12px;"> <td class="ig_cd1923c4_9">GROUP 7</td> <td class="ig_cd1923c4_10">V49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_94" style="height:12px;"> <td class="ig_cd1923c4_9">GULF </td> <td class="ig_cd1923c4_10">GF-203</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_95" style="height:12px;"> <td class="ig_cd1923c4_9">GULF </td> <td class="ig_cd1923c4_10">GF-206</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_96" style="height:12px;"> <td class="ig_cd1923c4_9">HASTINGS</td> <td class="ig_cd1923c4_10">LF225</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_97" style="height:12px;"> <td class="ig_cd1923c4_9">HASTINGS</td> <td class="ig_cd1923c4_10">LF25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_98" style="height:12px;"> <td class="ig_cd1923c4_9">HASTINGS</td> <td class="ig_cd1923c4_10">T225</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_99" style="height:12px;"> <td class="ig_cd1923c4_9">HAVOLINE</td> <td class="ig_cd1923c4_10">T-18</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_100" style="height:12px;"> <td class="ig_cd1923c4_9">HUTCHEN</td> <td class="ig_cd1923c4_10">S-49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_101" style="height:12px;"> <td class="ig_cd1923c4_9">HYSTER</td> <td class="ig_cd1923c4_10">127644</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_102" style="height:12px;"> <td class="ig_cd1923c4_9">JIFFY LUBE</td> <td class="ig_cd1923c4_10">HL30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_103" style="height:12px;"> <td class="ig_cd1923c4_9">JIFFY LUBE</td> <td class="ig_cd1923c4_10">JL49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_104" style="height:12px;"> <td class="ig_cd1923c4_9">JIFFY LUBE</td> <td class="ig_cd1923c4_10">L20049</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_105" style="height:12px;"> <td class="ig_cd1923c4_9">JOHN DEERE</td> <td class="ig_cd1923c4_10">AH82432</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_106" style="height:12px;"> <td class="ig_cd1923c4_9">JOHN DEERE</td> <td class="ig_cd1923c4_10">TY942</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_107" style="height:12px;"> <td class="ig_cd1923c4_9">JOHN DEERE</td> <td class="ig_cd1923c4_10">TY9429</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_108" style="height:12px;"> <td class="ig_cd1923c4_9">K & N</td> <td class="ig_cd1923c4_10">HP-2002</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_109" style="height:12px;"> <td class="ig_cd1923c4_9">K MART</td> <td class="ig_cd1923c4_10">K-3</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_110" style="height:12px;"> <td class="ig_cd1923c4_9">K MART</td> <td class="ig_cd1923c4_10">MP-3</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_111" style="height:12px;"> <td class="ig_cd1923c4_9">KENDALL</td> <td class="ig_cd1923c4_10">K4</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_112" style="height:12px;"> <td class="ig_cd1923c4_9">KERR-McGEE</td> <td class="ig_cd1923c4_10">KM-30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_113" style="height:12px;"> <td class="ig_cd1923c4_9">KNECHT</td> <td class="ig_cd1923c4_10">AW38</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_114" style="height:12px;"> <td class="ig_cd1923c4_9">KRALINATOR</td> <td class="ig_cd1923c4_10">L79</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_115" style="height:12px;"> <td class="ig_cd1923c4_9">LEE</td> <td class="ig_cd1923c4_10">LF-12</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_116" style="height:12px;"> <td class="ig_cd1923c4_9">LEE</td> <td class="ig_cd1923c4_10">LF-25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_117" style="height:12px;"> <td class="ig_cd1923c4_9">LEE</td> <td class="ig_cd1923c4_10">LF-25HP</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_118" style="height:12px;"> <td class="ig_cd1923c4_9">LUBER-FINER</td> <td class="ig_cd1923c4_10">LFP12</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_119" style="height:12px;"> <td class="ig_cd1923c4_9">LUBER-FINER</td> <td class="ig_cd1923c4_10">LFP25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_120" style="height:12px;"> <td class="ig_cd1923c4_9">LUBER-FINER</td> <td class="ig_cd1923c4_10">PH12</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_121" style="height:12px;"> <td class="ig_cd1923c4_9">LUBER-FINER</td> <td class="ig_cd1923c4_10">PH25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_122" style="height:12px;"> <td class="ig_cd1923c4_9">LUCAS GIRLING</td> <td class="ig_cd1923c4_10">F5547</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_123" style="height:12px;"> <td class="ig_cd1923c4_9">LUCAS GIRLING</td> <td class="ig_cd1923c4_10">F604</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_124" style="height:12px;"> <td class="ig_cd1923c4_9">MANN & HUMMEL</td> <td class="ig_cd1923c4_10">ML 1016</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_125" style="height:12px;"> <td class="ig_cd1923c4_9">MANN & HUMMEL</td> <td class="ig_cd1923c4_10">W920/54</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_126" style="height:12px;"> <td class="ig_cd1923c4_9">MANN & HUMMEL</td> <td class="ig_cd1923c4_10">W936/5</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_127" style="height:12px;"> <td class="ig_cd1923c4_9">MARATHON</td> <td class="ig_cd1923c4_10">MO30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_128" style="height:12px;"> <td class="ig_cd1923c4_9">MARATHON</td> <td class="ig_cd1923c4_10">PH12</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_129" style="height:12px;"> <td class="ig_cd1923c4_9">MARATHON-LETOURNEAU</td> <td class="ig_cd1923c4_10">MO30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_130" style="height:12px;"> <td class="ig_cd1923c4_9">MARATHON-LETOURNEAU</td> <td class="ig_cd1923c4_10">PH12</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_131" style="height:12px;"> <td class="ig_cd1923c4_9">MARINE POWER</td> <td class="ig_cd1923c4_10">MP-0905-000</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_132" style="height:12px;"> <td class="ig_cd1923c4_9">MASSEY-FERGUSON</td> <td class="ig_cd1923c4_10">1025280-M91</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_133" style="height:12px;"> <td class="ig_cd1923c4_9">MASSEY-FERGUSON</td> <td class="ig_cd1923c4_10">1035637-M91</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_134" style="height:12px;"> <td class="ig_cd1923c4_9">MASSEY-FERGUSON</td> <td class="ig_cd1923c4_10">1900374-M91</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_135" style="height:12px;"> <td class="ig_cd1923c4_9">MASTER PARTS</td> <td class="ig_cd1923c4_10">PH-25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_136" style="height:12px;"> <td class="ig_cd1923c4_9">MECHANICS CIRCLE</td> <td class="ig_cd1923c4_10">MOF 30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_137" style="height:12px;"> <td class="ig_cd1923c4_9">MERCRUISER</td> <td class="ig_cd1923c4_10">32716</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_138" style="height:12px;"> <td class="ig_cd1923c4_9">MERCRUISER</td> <td class="ig_cd1923c4_10">32717</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_139" style="height:12px;"> <td class="ig_cd1923c4_9">MERCRUISER</td> <td class="ig_cd1923c4_10">35-802885Q</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_140" style="height:12px;"> <td class="ig_cd1923c4_9">MERCRUISER</td> <td class="ig_cd1923c4_10">54111</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_141" style="height:12px;"> <td class="ig_cd1923c4_9">MERCRUISER</td> <td class="ig_cd1923c4_10">866340K01</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_142" style="height:12px;"> <td class="ig_cd1923c4_9">MERCRUISER</td> <td class="ig_cd1923c4_10">866340Q02</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_143" style="height:12px;"> <td class="ig_cd1923c4_9">MICRO </td> <td class="ig_cd1923c4_10">F-25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_144" style="height:12px;"> <td class="ig_cd1923c4_9">MIGHTY</td> <td class="ig_cd1923c4_10">M49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_145" style="height:12px;"> <td class="ig_cd1923c4_9">MILEGUARD</td> <td class="ig_cd1923c4_10">MO30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_146" style="height:12px;"> <td class="ig_cd1923c4_9">MILEGUARD</td> <td class="ig_cd1923c4_10">MO30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_147" style="height:12px;"> <td class="ig_cd1923c4_9">MINIT LUBE</td> <td class="ig_cd1923c4_10">PH25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_148" style="height:12px;"> <td class="ig_cd1923c4_9">MITSUBISHI</td> <td class="ig_cd1923c4_10">J0990359</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_149" style="height:12px;"> <td class="ig_cd1923c4_9">MOBIL</td> <td class="ig_cd1923c4_10">M1-202</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_150" style="height:12px;"> <td class="ig_cd1923c4_9">MOBIL</td> <td class="ig_cd1923c4_10">MO49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_151" style="height:12px;"> <td class="ig_cd1923c4_9">MONROE</td> <td class="ig_cd1923c4_10">FP-102</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_152" style="height:12px;"> <td class="ig_cd1923c4_9">MOPAR </td> <td class="ig_cd1923c4_10">L-136</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_153" style="height:12px;"> <td class="ig_cd1923c4_9">MOTOR TREND</td> <td class="ig_cd1923c4_10">ML30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_154" style="height:12px;"> <td class="ig_cd1923c4_9">MOTORCRAFT </td> <td class="ig_cd1923c4_10">FL 10</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_155" style="height:12px;"> <td class="ig_cd1923c4_9">MOTORCRAFT </td> <td class="ig_cd1923c4_10">FL 755</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_156" style="height:12px;"> <td class="ig_cd1923c4_9">MOTORCRAFT </td> <td class="ig_cd1923c4_10">FL 774</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_157" style="height:12px;"> <td class="ig_cd1923c4_9">NAPA</td> <td class="ig_cd1923c4_10">1046</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_158" style="height:12px;"> <td class="ig_cd1923c4_9">NAPA</td> <td class="ig_cd1923c4_10">1069</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_159" style="height:12px;"> <td class="ig_cd1923c4_9">NELSON</td> <td class="ig_cd1923c4_10">85121-E</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_160" style="height:12px;"> <td class="ig_cd1923c4_9">NELSON</td> <td class="ig_cd1923c4_10">88266-A</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_161" style="height:12px;"> <td class="ig_cd1923c4_9">NELSON</td> <td class="ig_cd1923c4_10">CP-10-SCR</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_162" style="height:12px;"> <td class="ig_cd1923c4_9">NELSON</td> <td class="ig_cd1923c4_10">WPF-25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_163" style="height:12px;"> <td class="ig_cd1923c4_9">OMC</td> <td class="ig_cd1923c4_10">173232</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_164" style="height:12px;"> <td class="ig_cd1923c4_9">OMC</td> <td class="ig_cd1923c4_10">502901</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_165" style="height:12px;"> <td class="ig_cd1923c4_9">OMC</td> <td class="ig_cd1923c4_10">502902</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_166" style="height:12px;"> <td class="ig_cd1923c4_9">PARTS MASTER</td> <td class="ig_cd1923c4_10">1-30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_167" style="height:12px;"> <td class="ig_cd1923c4_9">PARTS PLUS</td> <td class="ig_cd1923c4_10">PH25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_168" style="height:12px;"> <td class="ig_cd1923c4_9">PENNZOIL</td> <td class="ig_cd1923c4_10">PZ-3</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_169" style="height:12px;"> <td class="ig_cd1923c4_9">PERFORMAX</td> <td class="ig_cd1923c4_10">PO-3</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_170" style="height:12px;"> <td class="ig_cd1923c4_9">PERFORMAX</td> <td class="ig_cd1923c4_10">PO-3</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_171" style="height:12px;"> <td class="ig_cd1923c4_9">PERRY</td> <td class="ig_cd1923c4_10">PER-12</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_172" style="height:12px;"> <td class="ig_cd1923c4_9">PERRY</td> <td class="ig_cd1923c4_10">PL-3</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_173" style="height:12px;"> <td class="ig_cd1923c4_9">PHILLIPS 66</td> <td class="ig_cd1923c4_10">PO49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_174" style="height:12px;"> <td class="ig_cd1923c4_9">PLEASURECRAFT </td> <td class="ig_cd1923c4_10">R077002</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_175" style="height:12px;"> <td class="ig_cd1923c4_9">POWER FLO</td> <td class="ig_cd1923c4_10">SL20049</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_176" style="height:12px;"> <td class="ig_cd1923c4_9">POWER FLO</td> <td class="ig_cd1923c4_10">SL34631</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_177" style="height:12px;"> <td class="ig_cd1923c4_9">PRECISION TUNE</td> <td class="ig_cd1923c4_10">OF-115</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_178" style="height:12px;"> <td class="ig_cd1923c4_9">PRO/GAUGE</td> <td class="ig_cd1923c4_10">PGO-49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_179" style="height:12px;"> <td class="ig_cd1923c4_9">PROMOTIVE</td> <td class="ig_cd1923c4_10">PH49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_180" style="height:12px;"> <td class="ig_cd1923c4_9">PRONTO</td> <td class="ig_cd1923c4_10">PO-30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_181" style="height:12px;"> <td class="ig_cd1923c4_9">PUROLATOR</td> <td class="ig_cd1923c4_10">L20049</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_182" style="height:12px;"> <td class="ig_cd1923c4_9">QUAKER STATE</td> <td class="ig_cd1923c4_10">QS30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_183" style="height:12px;"> <td class="ig_cd1923c4_9">QUALITY</td> <td class="ig_cd1923c4_10">QF25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_184" style="height:12px;"> <td class="ig_cd1923c4_9">ROCKHILL</td> <td class="ig_cd1923c4_10">61069</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_185" style="height:12px;"> <td class="ig_cd1923c4_9">ROCKWELL INTERNATIONAL</td> <td class="ig_cd1923c4_10">3280V5040</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_186" style="height:12px;"> <td class="ig_cd1923c4_9">ROL-PAK</td> <td class="ig_cd1923c4_10">APQ-12-FF</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_187" style="height:12px;"> <td class="ig_cd1923c4_9">SAFETY KLEEN</td> <td class="ig_cd1923c4_10">106</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_188" style="height:12px;"> <td class="ig_cd1923c4_9">SCHRAMM</td> <td class="ig_cd1923c4_10">10006</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_189" style="height:12px;"> <td class="ig_cd1923c4_9">SEARS</td> <td class="ig_cd1923c4_10">45084</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_190" style="height:12px;"> <td class="ig_cd1923c4_9">SEARS</td> <td class="ig_cd1923c4_10">45173</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_191" style="height:12px;"> <td class="ig_cd1923c4_9">SEARS</td> <td class="ig_cd1923c4_10">45193</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_192" style="height:12px;"> <td class="ig_cd1923c4_9">SECURITY</td> <td class="ig_cd1923c4_10">SO-49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_193" style="height:12px;"> <td class="ig_cd1923c4_9">SELECT 500</td> <td class="ig_cd1923c4_10">L1069</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_194" style="height:12px;"> <td class="ig_cd1923c4_9">SERIES 2</td> <td class="ig_cd1923c4_10">8102</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_195" style="height:12px;"> <td class="ig_cd1923c4_9">SERVICE 1</td> <td class="ig_cd1923c4_10">OF49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_196" style="height:12px;"> <td class="ig_cd1923c4_9">SERVICE PRO</td> <td class="ig_cd1923c4_10">SO30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_197" style="height:12px;"> <td class="ig_cd1923c4_9">SHELL</td> <td class="ig_cd1923c4_10">SH18</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_198" style="height:12px;"> <td class="ig_cd1923c4_9">SIEG</td> <td class="ig_cd1923c4_10">OS30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_199" style="height:12px;"> <td class="ig_cd1923c4_9">SIERRA</td> <td class="ig_cd1923c4_10">18-7824</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_200" style="height:12px;"> <td class="ig_cd1923c4_9">SIERRA</td> <td class="ig_cd1923c4_10">18-7877</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_201" style="height:12px;"> <td class="ig_cd1923c4_9">SILVERLINE</td> <td class="ig_cd1923c4_10">21069</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_202" style="height:12px;"> <td class="ig_cd1923c4_9">STP</td> <td class="ig_cd1923c4_10">S30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_203" style="height:12px;"> <td class="ig_cd1923c4_9">SUNOCO</td> <td class="ig_cd1923c4_10">O-3</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_204" style="height:12px;"> <td class="ig_cd1923c4_9">SUPERTECH</td> <td class="ig_cd1923c4_10">ST30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_205" style="height:12px;"> <td class="ig_cd1923c4_9">SUPERTECH</td> <td class="ig_cd1923c4_10">ST8873</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_206" style="height:12px;"> <td class="ig_cd1923c4_9">TARGET</td> <td class="ig_cd1923c4_10">SF49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_207" style="height:12px;"> <td class="ig_cd1923c4_9">TRUST</td> <td class="ig_cd1923c4_10">PH25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_208" style="height:12px;"> <td class="ig_cd1923c4_9">UNITED (ENGINE LIFE)</td> <td class="ig_cd1923c4_10">U2L</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_209" style="height:12px;"> <td class="ig_cd1923c4_9">UNITED (ENGINE LIFE)</td> <td class="ig_cd1923c4_10">U6L</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_210" style="height:12px;"> <td class="ig_cd1923c4_9">UNOCAL</td> <td class="ig_cd1923c4_10">PF25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_211" style="height:12px;"> <td class="ig_cd1923c4_9">VALUTEST</td> <td class="ig_cd1923c4_10">3829</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_212" style="height:12px;"> <td class="ig_cd1923c4_9">VALUTEST</td> <td class="ig_cd1923c4_10">4829</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_213" style="height:12px;"> <td class="ig_cd1923c4_9">VALUTEST</td> <td class="ig_cd1923c4_10">V2069</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_214" style="height:12px;"> <td class="ig_cd1923c4_9">VALVOLINE</td> <td class="ig_cd1923c4_10">VO12</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_215" style="height:12px;"> <td class="ig_cd1923c4_9">VALVOLINE</td> <td class="ig_cd1923c4_10">VO2</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_216" style="height:12px;"> <td class="ig_cd1923c4_9">VOLVO </td> <td class="ig_cd1923c4_10">3850559</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_217" style="height:12px;"> <td class="ig_cd1923c4_9">VOLVO </td> <td class="ig_cd1923c4_10">3850559-0</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_218" style="height:12px;"> <td class="ig_cd1923c4_9">VOLVO </td> <td class="ig_cd1923c4_10">835440</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_219" style="height:12px;"> <td class="ig_cd1923c4_9">VOLVO </td> <td class="ig_cd1923c4_10">835440-9</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_220" style="height:12px;"> <td class="ig_cd1923c4_9">VOLVO-PENTA MARINE</td> <td class="ig_cd1923c4_10">835440-9</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_221" style="height:12px;"> <td class="ig_cd1923c4_9">WAL-MART</td> <td class="ig_cd1923c4_10">WF-25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_222" style="height:12px;"> <td class="ig_cd1923c4_9">WALMI</td> <td class="ig_cd1923c4_10">WS-30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_223" style="height:12px;"> <td class="ig_cd1923c4_9">WARNER</td> <td class="ig_cd1923c4_10">PH12</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_224" style="height:12px;"> <td class="ig_cd1923c4_9">WARNER</td> <td class="ig_cd1923c4_10">PH25</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_225" style="height:12px;"> <td class="ig_cd1923c4_9">WESTERN AUTO</td> <td class="ig_cd1923c4_10">74-5812-8</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_226" style="height:12px;"> <td class="ig_cd1923c4_9">WESTERN AUTO</td> <td class="ig_cd1923c4_10">74-5923-3</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_227" style="height:12px;"> <td class="ig_cd1923c4_9">WGB</td> <td class="ig_cd1923c4_10">S-156-CP</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_228" style="height:12px;"> <td class="ig_cd1923c4_9">WGB</td> <td class="ig_cd1923c4_10">S-266-CP</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_229" style="height:12px;"> <td class="ig_cd1923c4_9">WHITE</td> <td class="ig_cd1923c4_10">703103</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_230" style="height:12px;"> <td class="ig_cd1923c4_9">WIX</td> <td class="ig_cd1923c4_10">51069</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_231" style="height:12px;"> <td class="ig_cd1923c4_9">WM. PENN</td> <td class="ig_cd1923c4_10">WP-30</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_232" style="height:12px;"> <td class="ig_cd1923c4_9">XSV</td> <td class="ig_cd1923c4_10">OP-49</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_233" style="height:12px;"> <td class="ig_cd1923c4_9">YAMAHA</td> <td class="ig_cd1923c4_10">YSC-10231-20-0C</td> </tr> <tr id="ctl00xContentPlaceHolder1xUltraWebGridxComps_r_234" style="height:12px;"> <td class="ig_cd1923c4_9">YAMAHA</td> <td class="ig_cd1923c4_10">YSC-13231-20-OC</td></tr></tbody></table>
  6. squirrel
    ok, I got out the book....champ PH25 changes over to Wix 51069. That fits the Chevy 250 six cylinder engine from the early 60s into the 1980s
    I was thinking PF25, not PH25, sorry.
  7. Mr48chev
    That looks like a good source to have for filter reference Flamed34, thanks for sharing the link.
  8. ferrets bueller
    ferrets bueller
    from NW Indiana
    Thanks a ton! I checked both Wix numbers with the Champ site, and they both led me back to PH454...which I'm guessing they replaced PH25 with at some point. They overlap in applications.
  9. ferrets bueller
    ferrets bueller
    from NW Indiana
    Ok, it looks like the only difference between the two Wix filters (57099, 51069) is that one is taller than the other. Sweet. Thanks a ton, guys.
