Technical Oil filter question
Discussion in 'The Hokey Ass Message Board' started by upspirate, Aug 27, 2016.
  1. upspirate
    upspirate
    I have an NOS oil filter from the '80's , crosses to PH 13 Fram , PF 35 AC , PER40 Purolater . I can't remember what it fits ! :confused:
    I'm looking to change oil & filter on my 327 small block , spin -on type and wonder if this fits.
    Just pull the old one and check to make sure the threads and gasket match up?
    I feel dumb for even asking this:rolleyes:
  2. Yep, it'll work just fine.
  3. upspirate
    upspirate
    Thanks ....it'll save me buying another one !
  4. tb33anda3rd
    tb33anda3rd
    is it a 327 that was adapted to a spin on? i think the adapted motors use a different filter than a stock, from the factory spin on type. if i remember right. someone will correct me if i am wrong.
  5. upspirate
    upspirate
    Easy little trick I've been doing for years. Didn't want the rust issue nor expense of chrome filter covers on my rods , so I give them a quick shot of paint before I install them. Yes alcohol is usually involved !;) 20160827_124622.jpg
    mad mikey likes this.
  6. upspirate
    upspirate
    I don't know , I haven't driven it enough to change oil & filter ...... this is the first time. I'll check this out. Thanks
  7. uncle buck
    uncle buck
    The only 2 types of adapters I have seen will use either the filter you have (equivalent to Napa#1061) or a Napa #1515. The easy identify is the filter you have has the gasket all the way out to the outer edge , and the other one has the gasket about 3/8" inboard of the outer edge. Here is a comparison [​IMG]
    volvobrynk, upspirate and tb33anda3rd like this.
  8. pat59
    pat59
    And don't use the wrong one. I did once, filter spun right on but I never checked the gasket. Dumped 5 quarts right onto the street. Ya live and learn. :)
    mad mikey, volvobrynk and upspirate like this.
  9. dan c
    dan c
    i had a '67 camaro/250 inch six that i used these on. more filter area and the same $.
  10. upspirate
    upspirate
    Thanks for the photo Buck . I had bought this old filter back when I was running 350's in my rods, and also had an iron duke in a '27 T roadster
  11. squirrel
    I wonder how old oil filters hold up to time? I think the only thing I'd be worried about, is the glue holding the filter material to the end caps.
    I'm curious because I have a couple 1970s vintage AC filters for a Chevy, and would like to put one on my old car, because it looks neat (and you can kind of see it, with the fender well headers, high nose, etc). I just wonder if I'm risking oiling issues...
  12. upspirate
    upspirate
    Never thought of that aspect Squirrel....can't be much worse than a J.C.Whitney toilet paper filter??!!! ;)
    volvobrynk likes this.
  13. volvobrynk
    volvobrynk
    from Denmark
    I agree with above, you CAN use that filter, but I wouldn't!
    Right for you application, but wrong in most other senses!
  14. volvobrynk
    volvobrynk
    from Denmark
    The question ain't is it worse, the question should be; is it good enough for your engine!!
    upspirate likes this.
  15. tb33anda3rd
    tb33anda3rd
    i had/have a bunch of old oil filters and always wondered what the shelf life was.
    i did cut some open that "hinted" of being stored in a damp spot and there were rust stains on the paper element.
  16. Gman0046
    Gman0046
    Your probably better off using the old AC filters. They were USA made. The new AC are now made in China.
    gary
    squirrel likes this.
  17. upspirate
    upspirate
    Good news , the filter was the right one , and no leaks. There were 2 bolts into the block under (above) the filter , if I remember correctly , these held the adapter onto the block?? been a long time since I messed with this stuff , and even back then , I just spin the old one on & off.:(
  18. squirrel
    There is a bolted on adapter no matter which type block it is. the difference is, on the early blocks with a spin on adapter, the filter gasket fits against the adapter. On the later blocks, the filter gasket fits against the block itself.
    tb33anda3rd and upspirate like this.
  19. George
    George
    Yeah, counter guy gave me the wrong one once, maybe for a 305 Chevy instead of a 305 Buick, same results as yours!:(
  20. pat59
    pat59
    Yea I think the one I had used was for a pontiac. The gasket was further inside. :)
