oil for flatheads?
Discussion in 'The Hokey Ass Message Board' started by Upchuck, Mar 22, 2004.
  1. Upchuck
    Upchuck
    from Canada BC
    I was wondering what sort of oil to use in a used dirty old flathead thats been sitting for years? if I used high detergent oil for a diesel engine would that flush out to much **** and plug galleries up or should I just use regular old quaker state?
    right now its seized up tight as a nun but when it comes time to pop the ole cherry I may not be thinking of what sort of lube to use in my excitement [​IMG]
  2. 286merc
    286merc
    from Pelham, NH
    If it has been sitting that long a HD detergent wont have much effect on hardened sludge. A good quality 20W50 will keep the bearings and the rest of the rotating ***embly very happy.
    Best thing is to drop the pan, clean it out and at least clean the oil pump screen. If it was me and I wanted it to run for a few years I would put in a new Melling M19 pump.
    The Melling will also work in a old 59A style block if you use the 8BA pickip and screen.
  3. UNCLECHET
    UNCLECHET
    Mine is worn out so I just run what ever I find cheap. 30w or 40w. It doesn't seem to mind at this point. When something does go wrong I guess I'll pull it out and rebuild.
  4. Upchuck
    Upchuck
    from Canada BC
    regular oil it is then
    thanks
