Hot Rods oil leak on 383 stroker sbc
Discussion in 'The Hokey Ass Message Board' started by 26hotrod, Jul 1, 2018.
  1. 26hotrod
    26hotrod
    from landis n c
    I need help. 383 stroker sbc,450hp. Put in new seal and it leaks just like the old one did. I go for a drive, come home and have a spot of oil the size of a soda can. Any suggestions??
  2. tb33anda3rd
    tb33anda3rd
    which seal?
    26hotrod and ClayMart like this.
  3. 26hotrod
    26hotrod
    from landis n c
    Front main seal .
  4. tb33anda3rd
    tb33anda3rd
    did the damper have a groove worn into it?
    26hotrod likes this.
  5. 26hotrod
    26hotrod
    from landis n c
    I really don't know. I can live with this for a while but plan to pull it off when the weather gets cooler. I really just want to know what to look for.
  6. tb33anda3rd
    tb33anda3rd
    also check that there are bolts in the front two holes near the water pump, otherwise oil will leak out there. the bolts need to be short, 1/2" long
    trollst, 26hotrod and Dooley like this.
  7. 26hotrod
    26hotrod
    from landis n c
    I will check the bolt holes 1st thing in the am. Thanks tb, have a gud nite…..
  8. goldmountain
    goldmountain
    Maybe just try tightening the pan bolts.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  9. treb11
    treb11
    there are two different SBC pan seals. Not to mention the LH / RH dipstick thing. Make sure you are using the right ones.
  10. squirrel
    and the Chinese chrome front covers and oil pans are not all made very well, some just don't fit.
  11. 26hotrod
    26hotrod
    from landis n c
    Thanks treb & squirrel for the tips. I am using steel 7qt pan & the right pan gasket. I don't care for the chrome oil pans or front covers. It's hot as hell here today but might check out some issues tonight. a/c in the garage might be my next home project. Thanks to everyone for the advise and if and when I figure this out I will let you guys know. Have a gud 4th and thanks to the HAMB...…………..
  12. NewGuyOldFord
    NewGuyOldFord
  13. Seems like we're missing some info here. Are you the one replacing the seal, or someone else?
    You're using a puller for the damper, right? You're looking right down at the damper, as it comes off, right?
    You're using the proper tool to pull it back on, yes? Again, looking right at it.. but you didn't notice a groove worn into the damper?
    I'm going to suggest, when you change the seal for the third time, you pay close attention to the seal surface on the damper. You're going to have to start there.
    Doubtful this is the case here, realistically speaking. It must have an aftermarket counter-weighted damper for the 400 crank. Unless it has beau coup miles on it already, it's probably not your problem.
    Good luck
  14. Dooley
    Dooley
    from Buffalo NY
  15. ClayMart
    ClayMart
    How are you set up for crankcase ventilation?
    LBCD, Blues4U and 26hotrod like this.
  16. dana barlow
    dana barlow
    from Miami Fla.
    On SBC Chrome timing chain covers that hold the seal to the pan lip,that lip that is on cheep chrome cover is only spot welded,not welded all along like GM is. If you fill all the way around that lip with sealer,leak will stop.{with cover off} = leak is really oil running in behind that lip an cover/so go right p*** the pan gasket.
  17. 26hotrod
    26hotrod
    from landis n c
    Hey guys, thanks for all the info. I am using a stock front cover & stock cc ventilation. The pcv is on the drivers side and a vent tube on the p***. side going from the carb. air breather to the p***. valve cover. It will cool down temp. wise & I will go to the garage in a while and check some things. Dooley thanks for the engine block photo as that is the 1st thing I will check. Hope that's it as it looks like an easy fix. Thanks again every one for your post and concern...………….. HOT AS HELL IN N.C.
  18. pat59
    pat59
    if ya put a bolt in that hole make sure that it's a short one.
    Rich S., Montana1 and 26hotrod like this.
  19. 26hotrod
    26hotrod
    from landis n c
    Mark Yak, my friend and I used a puller to remove the damper and we didn't notice a grove in it. It is also counter weighted by the machine shop that balanced every thing else. Pat59 I will definitely use a short bolt. Thanks again guys...……………...
  20. 26hotrod
    26hotrod
    from landis n c
    Goldmountain my pan bolts were loose, so I tightened them up. Cleaned every thing under the car and see what happens next time I drive it. Dooley Thanks again for the photo of the engine block. That hole has a bolt in it because that is the mounting point for my a/c compressor(I use an electric fuel pump as the mechanical pump hole had been pluged ) and didn't see any oil leak there. How ever this turns out I will let you know. Happy 4th everyone and thanks for your input...………...
  21. southcross2631
    southcross2631
    Did you put a dab of sealant in the keyway of the balancer ? I have seen oil run past the key and look like a front seal leak.
    deathrowdave and 26hotrod like this.
  22. 26hotrod
    26hotrod
    from landis n c
    Southcrosss2631, am pretty sure we didn't put any sealant on the keyway. If it still leaks after the next drive that is something we will do. We will wait until the hot weather breaks to do that. Thanks for the tip...…….
    pat59 likes this.
  23. 26hotrod
    26hotrod
    from landis n c
    Went for a drive and the leak is almost gone. Just a small spot on the floor. I will go back under the car and put some sealant on front of the oil pan. The pan is a 7qt. pan with the sides kicked out. I had the pan powder coated and also had the inside teflone coated as well. The tefone helps the oil run down the side of the pan to the bottom quicker. This is a very slick coating. Thanks everyone for all the info as its all good food for thought. If the sealant on the pan helps I will be sure to let you know...…………...
  24. afaulk
    afaulk
    All my junk is dedicated to racing and if I didn't have a leak somewhere I'd think I forgot to put oil in the damn thing. Mine are dis***embled too often to worry about it but I admire your dedication.
  25. 26hotrod
    26hotrod
    from landis n c
    Thank you afaulk. I know hot rods mark their territory but I hate a dang leak...…………..
    afaulk likes this.
  26. 26hotrod
    26hotrod
    from landis n c
    OK folks, here is the latest on the oil leak. ClayMart, I changed the crank case vent on my valve covers for better breathing. I still have a small leak after a drive of a few mikes. I believe southcross2631 may have a good suggestion of sealant on the key way slot on the balancer. This will be something I will do this winter as I will have to pull the radiator to do this. THANKS EVERYONE for your suggestions. Will keep you posted.....
  27. choptop40
    choptop40
    Those china pans and front covers ****...GM parts only for me...glad you narrowed it down to key way...
  28. sunbeam
    sunbeam
    You might try tightening the bolt holding the damper. If the damper is not seated all the way back against the cam gear it makes a keyway leak worse.
  29. 26hotrod
    26hotrod
    from landis n c
    Thanks topchop40 and sunbeam. I'll check that damper bolt. It would be nice if that's the problem...……..
  30. 26hotrod
    26hotrod
    from landis n c
    Still have a small oil leak dang it!! I'll be pulling the radiator this Jan. to clean it out at which time will pull the balancer to put sealant in the key way slot and reinstall. I'll let you know how it goes...……...
