Hot Rods Oil light won't go off
Discussion in 'The Hokey Ass Message Board' started by Bigstar, Aug 14, 2015.
  1. Bigstar
    Bigstar
    from Austin
    The other day the oil light on my '66 C10 started to flicker. I checked the oil and it was a little low so I topped it off and now the oil light stays on most of the time. It may go off for a second but it comes right back on. The oil level is right on. Any ideas? The light has never come on and stayed on like that before. Thanks
  2. Fedman
    Fedman
    Do you have a mechanical oil pressure gauge to check the pressure with?
    This is where I would start.
    tb33anda3rd likes this.
  3. ROADSTER1927
    ROADSTER1927
    STOP running it until you verify you have oil pressure! Gary:eek:
    49ratfink likes this.
  4. plym_46
    plym_46
    from central NY
    light monitors oil pressure not oil quan***y............
  5. olscrounger
    olscrounger
    put a gauge in it and check before you run it any more
  6. dirtracer06
    dirtracer06
    No oil pressure, bad sensor, or bad wire..ie, shorted.
  7. 29AVEE8
    29AVEE8
    What color is the oil filter?
    49ratfink and Johnny Gee like this.
  8. ROADSTER1927
    ROADSTER1927
    Probably orange? Gary
    Johnny Gee likes this.
  9. Don's Hot Rods
    Don's Hot Rods
    from florida
    Only two possibilities, either you have no/low oil pressure or the light is giving you a false reading. Like everyone said, do not run the motor until you have hooked up a mechanical direct reading gauge to determine if you really have pressure or not.
    Don
  10. Kiwi 4d
    Kiwi 4d
    Knock knock, okay sorry but we have a car that has had a faulty light and have done 18000 Mls with a very intermittent off and on light, but the first time I did verify oil pressure was good , don't ignore the warning.
  11. HOTRODPRIMER
    HOTRODPRIMER
    Never trust idiot lights,pull the dipstick and verify your oil level is correct.
    As others have stated,add a gauge and use a piece of electrical tape and cover up the bulb. HRP
  12. 325w
    325w
    Did you check to be sure the connector on the sender was tight are the wire not frayed. Possible loose bulb in the cluster. This all can be checked with just the key on.
  13. aaggie
    aaggie
    I learned a lesson years ago about electric oil pressure sensors. Never use Teflon tape because they need to be grounded to read correctly. It worked fine until about 100 miles from home and the gauge dropped to "0", it was a fresh rebuild and all sorts of possibilities presented themselves.
  14. blackrat40
    blackrat40
    Had an issue a couple of times in the past where the driver over revved an older engine and
    the oil pump relief valve stuck in the open position. Oil indicator light stayed on.
    Removing the oil pan and un-sticking the relief valve solved the problem.
    Just offering another possibility.
    slack likes this.
  15. If the engine isn't making any lifter noise most likely it's the sending unit. As stated find a mechanical gauge (either a hand held oil pressure gauge or a under dash gauge and hold it) and check if it really has pressure. If good pressure is present then ground gauge wire, if the light comes on then you need to replace the sending unit.
    scrap metal 48 likes this.
  16. Even if the oil light goes out it only means you have 6 plus psi. JW
  17. d2_willys
    d2_willys
    from Kansas
    Check the wiring around the sender unit. All it takes is to have a frayed wire the shorts to ground to light the bulb. My 54 Chrysler did this, moved the wire and no flicker.
