Hot Rods oil pan bits
Discussion in 'The Hokey Ass Message Board' started by RmK57, Oct 26, 2021.
  1. RmK57
    RmK57
    A few more images of the pump, distributor, shaft and the pieces. The pieces are slightly magnetized on the edge of a knife blade. The shaft fits in nice and snug in the oil pump, I compared it to the original Ford pump, same goes for the distributor.
    squirrel likes this.
  2. Bandit Billy
    Bandit Billy
    There are 6 of them, do they fit in here?
  3. RmK57
    RmK57
    No. It's one piece heat treated chromoly shaft. I don't think a hacksaw would touch this thing.
    There could be more than six but the residual oil in the pan tends to stick them pretty good to the bottom. I removed the oil pan on an engine stand upside down.
  4. PhilA
    PhilA
  5. Sporty45
    Sporty45
    They look like a broken off hold down tab from something, but I have no idea what it would be
    squirrel and seb fontana like this.
  6. seb fontana
    seb fontana
    from ct
    Are they hard? Look to me like a stamping and involved in some type of pawl action if they are hard.
  7. dmar836
    dmar836
    I thought nut locking washer tabs as well. From an old timing chain, etc.? Usually they are more beat up after several reuses.
    D
    Sporty45 and PhilA like this.
  8. egads
    egads
    Is that rust on some of them? That's why I always take off the pan before flipping the engine on the stand.
  9. The pawls below are from a bicycle. I was kidding earlier about the 460 having a pull start but I can't shake the feeling those are from some sort of ratcheting device. Any chance those are pawls from a socket set ratchet? Did you have a torque wrench explode when the heads went on?
    Fortunateson likes this.
  10. dmar836
    dmar836
    So THATS why my cranks just freewheel!
  11. RmK57
    RmK57
    I'm starting to think along the same lines. Something dropped in or fell apart while setting valve lash?
  12. squirrel
    something from the breather system?
  13. greybeard360
    greybeard360
    Motor ***embled complete 7 years ago. Heads pulled off a year ago for some work.
    Oil pump and shaft can't be like new, they have been run for 7 years.
    What kind of work did the heads get a year ago?
  14. Wrench97
    Wrench97
    Check to see if the tops of the valve guides are still intact.
  15. RmK57
    RmK57
    Car gets driven around 300-400 miles a year and a few trips out to the local track, so around 3000 miles in 7 years. Heads were pulled off for exhaust port work and to shim the valve springs just to get by for one more year.
    The valve guides are br***, the pieces I found in the pan are steel. The other larger piece in the photo is aluminum and I'm pretty sure that came off from the inside of the timing cover. All the valve guides and related parts are intact as I have the heads apart.
    I checked the breathers, inside the rockers covers and they all look fine. I even cut the oil filter apart and it was clean as a whistle, oil only had around 75 miles on it.
    I'm thinking something was dropped in either when I had the heads off or 7 years ago when the engine was ***embled. They stayed in the pan or got washed down through the oil drain back holes. I'll keep looking but don't expect to find anything.
    Thanks for all the replies.
  16. 2Blue2
    2Blue2
    Mystery Metal like that could keep me up at night.
  17. Truck64
    Truck64
    from Ioway
    Yep, if I couldn't resolve it somehow I'd be wonderin' every time I drove it.
  18. RmK57
    RmK57
    Hmmm......I wonder if it could be parts of an oil ring? Not sure how the broken pieces would get p***ed the s****per though.
    warbird1 likes this.
  19. greybeard360
    greybeard360
    That's a good possibility. May explain the piece of alumnum. Aee if you can find a photo of the type of piston you used and look at the oil ring groove. Some just have round holes, others have slots.
  20. RmK57
    RmK57
    This is exactly the same piston I'm using. I really didnt want to pull the engine down that far but I may have to now. The bores on the engine are really nice as in no gouges, s****es, marring so if this the problem I got off lucky.
