Hot Rods oil pan clerance
Discussion in 'The Hokey Ass Message Board' started by jerry7702, May 23, 2018.
  1. jerry7702
    jerry7702
    from fla
    I have had to replace my oil pan 3 times it is the lowest point on the car. I am thinking of running a circle track pan gaining about 1 1/2" has anyone run this on the street? Advice please
  2. What's the clearance from Oil Pan to ground now?
  3. jerry7702
    jerry7702
    from fla
  4. George
    George
    That might be a hint. While lots of people here don't like the NSRA their Srubline target of nothing below the bottom of the wheels has merit. Saw a '29 Dodge sedan with a SBC blower motor with the drain plug ripped out of it on a manhole cover....
  5. Deuces
    Deuces
    I'm going back to sleep....
    Bandit Billy and milwscruffy like this.
  6. My personal minimum oil Pan clearance is 5" and they still get smashed once in a while. So after you chop the oil pan you have to re do the pickup and then what's the next thing to hit? Trans Pan?
    1934coupe likes this.
  7. Happydaze
    Happydaze
    Not sure about circle track pans but I've used a Moroso pan that was shallower than stock for purpose of avoiding the ground and keeping the oil where it was of more use.
    Chris
  8. 1934coupe
    1934coupe
    To answer your question, a circle track pan will work with the appropriate pick up. That said what pan have you been putting on that you have changed it 3 times. Maybe a skid plate is more in the cards for you because as has been mentioned "whats next". I guess raising the car is out of the question.
    Pat
    zzford likes this.
  9. yellow dog
    yellow dog
    from san diego
    Not a circle track pan w/ kick out only one side (guessing you might make right hand turns too).
    Check out Kevco roadrace pans specs for depth, doors/baffling, etc
    seb fontana likes this.
  10. Deuces
    Deuces
    Let's see the front end of this car!!!! Pictures???
  11. milwscruffy
    milwscruffy
    5" minimum for me and I also make sure there is a crossmember in front of it that is just below the pan depth.
  12. Unkl Ian
    Unkl Ian
    Typical circle track pans work great in left turns.
  13. 1934coupe
    1934coupe
    The bottom of the oil pan does not care if you make turns, the kickout is to prevent oil from climbing back up the block and creating windage drag on rotating parts (something like that) and still maintain a decent capacity. A road race pan will work just as well only may be pricier.
    Pat
  14. Jalopy Joker
    Jalopy Joker
    - even running a shorter pan will still expose important parts to impact with something solid
    olscrounger likes this.
  15. DDDenny
    Roger that!
  16. Bandit Billy
    Bandit Billy
    "Scrub Line 101, one of the first cl***es I monitored my freshman year at HAMB University.
  17. squirrel
    something funny about this drawing...the engine doesn't usually sit in a car like that. The front usually sits up about 3 or 4 degrees. The engine and transmission pans are usually close the same distance from the ground.
    LM14 likes this.
  18. greybeard360
    greybeard360
    Look into a pan for a dragster. The sump is a little deeper at the front and tapers back, the bottom is flat. Used one on a blown BB Mopar in a tee bucket. Had plenty of ground clearance with a lot of capacity.
  19. The reference is there at the carb , it's drawn square on the paper
  20. flatheadpete
    flatheadpete
    from Burton, MI
    What engine? Can't believe no one has asked yet.
  21. RmK57
    RmK57
    Put a dry sump on it. Problem solved.;)
  22. dana barlow
    dana barlow
    from Miami Fla.
    I welded/brazzed 1/8in. skidplate to bottom of my pan many years ago,it may not be a full 1/8th. ANY MORE ! lol,but works fine. I have 3in. to the road. If your car is over 100in. WB,you may need another added 1/2in. + depening on how long an your local roads.
  23. Deuces
    Deuces
    I'm still dying to see pictures of this car....o_O:rolleyes:
    milwscruffy likes this.
  24. jerry7702
    jerry7702
    from fla
    thanks for the info sbc
  25. BamaMav
    BamaMav
    from Berry, AL
    Raise the engine or the car or both, problem solved.....
    Deuces likes this.
