Technical Oil pan on my 40 Olds.
Discussion in 'Traditional Hot Rods' started by MWWADE, Dec 5, 2021.
  1. MWWADE
    MWWADE
    Trying to find out what oil pan I have. 350 Chevy engine. The dip stick has 8qt mark on it. The dip stick does look new, so it not original. The engine is a crate motor. Is there a way to measure the oil pan for quart capacity? The oil drain is on the drivers side, located right on the corner of the deep hump. image.jpg
  2. footbrake
    footbrake
    Put 5 qts in run it a couple seconds and pull the stick and file a mark on it where it shows full.
    TrailerTrashToo likes this.
  3. MWWADE
    MWWADE
    My thinking is if the oil pan is made for larger oil containment then 5 qts. would not be enough. I’m going to drain the pan, measure the old oil, to see how many qts. are in it. Then put a mark on the stick.
    SS327 likes this.
  4. 57JoeFoMoPar
    57JoeFoMoPar
    5 quarts plus filter is standard for a stock pan, which is what that looks like.
  5. rtp
    rtp
    A 8 qt. pan would really wide or really deep.
    That looks to be a stock pan.
    But what do I know Iam a olds motor in a Oldsmobile kinda guy.
  6. MWWADE
    MWWADE
    I drained the oil today, the pan had 5qts. In it. I put a mark on the dip stick. Good to go.
  7. Ebbsspeed
    Ebbsspeed
    Curious, how close is the mark you made to the "8 QT" mark?
