Hot Rods OIL PAN TROUBLE
Discussion in 'The Hokey Ass Message Board' started by rustyrods, Jan 21, 2016.
  1. rustyrods
    rustyrods
    from Dixon,Il.
    Chevy SB. Looking for a oil pan that has the dip stick on the P***enger side that comes out of the pan. Not sure of the year, maybe 1980 . Mine is rusted out and can't seem to find any online any where or know what years they used them.
  2. An '80 pan should be for left dipstick. It should be pan located instead of block located. If your block had a dipstick hole on the driver side you can use an early pan and just put a soft plug in the block then buy a pan mount dipstick kit.
    I have a number that you can call for a pan and for ***istance in pan choice. it is a catalog speed shop and I am not spamming today so if you want it PM me.
  3. hdman6465
    hdman6465
    Try the early v8 Monza oil pans.
  4. Stonebird
    Stonebird
    Not V8 Monza unless they changed sides somewhere along the line. I just looked at mine to be sure. All three that I looked at are in the pan but on the drivers side.
  5. 270dodge
    270dodge
    from Ohio
    The pan is rusted out? I've fixed many with some sheet metal and brazing rod.
  6. big duece
    big duece
    from kansas
  7. verno30
    verno30
    80-85 SBC will have a p***enger side dipstick.
  8. okiedokie
    okiedokie
    from Ok
    Pretty sure I see em on EBay.
  9. rustyrods
    rustyrods
    from Dixon,Il.
    My motor is on the left but I need a pan with the dip stick out of the pan to clear some exhaust manifolds I 'm useing
  10. Stonebird
    Stonebird
    I'm confused, the original post says p***enger side now you say left. Chevy Monza V8 pan has dipstick in the pan on the drivers side, but can be hard to find. 78 & 79 Malibu 305 was also supposed to have stick in the pan not sure which side. There are some listed on Car-part.com. That's as much as I know, hope it helps.
  11. There is some basic disagree on the '78/9 Mailbu 305. I am not sure I have worked on one and never owned one so I can't really weight in on the topic which is why I went with the '80. I know that in '80 they had p*** side dipsticks. That said I have an oddball '80 block that has a driver side dipstick, it also has some odd sized soft plugs that are basically unobtainium. :eek: :D
  12. Stonebird
    Stonebird
    Ok, I read through the listings on car-part and some specify dipstick in pan on left side. Monza and Malibu are the only stock pan mounted SBC dipsticks I know of, but I certianly don't know everything.
  13. krgdowdall
    krgdowdall
    from Alberta
    The 64-67 Chevy II V8 had a driver side, pan mounted dipstick, but it also had a front sump
  14. PONTNAK123
    PONTNAK123
    jegs has both dip stick soft plugs left part number 809-1409 4563 right part number 809-942 1743
  15. rustyrods
    rustyrods
    from Dixon,Il.
    I'll take ether Right or left as long as the dip stick comes out of the pan. My Manifolds dump at the hole in the block. Ebay only shows pans with dipsticks for big blocks. I have a 305 in another car with a pan mounted stick out the right . I thought it would be simple.
  16. ffr1222k
    ffr1222k
    Dorman 904-256 Oil Pan Dipstick Flange
    Would something like this work for you? It is for the Ford 7.3, I wish I had know about it with my 65 Ford. It would have solved my problem. I found it on Amazon
