1952-59 Ford oil pressure safety switch
Discussion in 'Off Topic Hot Rods & Customs' started by 56FORD390, Jun 21, 2019.
  1. 56FORD390
    56FORD390
    I have been told that I should install some kind of a safety system that hooks into the oil pressure line so the engine will not start until there is oil pressure present.
    Has anyone heard of this?
    Is it possible, or am I getting my leg pulled?
  2. 40cpe
    40cpe
    from Star, MS
    There are oil pressure switches that only connect under pressure but are usually used as safety switches for electric fuel pumps. I think it would make you crank a long time if the car has sat for a while and oil has drained from the p***ages.
  3. ffr1222k
    ffr1222k
    I think Vegas came with one. I looked into using one on a 2.3 Turbo that I eliminated the distributor and ran LS coils. If the cam gear stripped the oil pump gear I wanted the engine to cut off.
  4. okiedokie
    okiedokie
    from Ok
    Have one on my 53 F100 so that it kills the electric fuel pump if the engine loses oil pressure.
  5. 56longroof
    56longroof
    I dont think it is necessary. How long would you have to crank on it to build oil pressure? Maybe a emergency shut off but that's not necessarily needed either.
  6. Paul2748
    Paul2748
    I'm sure that such a switch may be needed in some type of application, but in a auto engine it is is not necessary.
    Just think of this - there have been billions of cars manufactured over the years. With a possible really small exception, none of the cars had such a switch.
  7. 54vicky
    54vicky
    I ran one on our race engines for years in conjunction with a light and gauge.I would think overkill on street but at highway speed lose oil pressure then ask if it was worth the time and effort.as to no factory install think MONEY the penny pinchers at head office.one of our member I think would have wished he had one as he lost a lot of money and time and the saga continues
  8. okiedokie
    okiedokie
    from Ok
    The purpose is to prevent the chance of a fire in a wreck when the fuel pump continues to supply fuel to a none running engine.
  9. Texas57
    Texas57
    "one of our member I think would have wished he had one as he lost a lot of money and time and the saga continues"
    ME?
    Hahaha.
    Actually I do have one, which is why I never heard any noises......the computer shut down the fuel pump when the engine started seizing, and the engine just shut off. I think all cars since the 90's are probably set up that way.
    Actually, not sure if it was an oil pressure sensor that made the computer shut the fuel off.......I'm more inclined to think it was the cam position sensor when the cam siezed up, but either way, I think the newer cars probably have multiple safety systems.
    the-stig likes this.
  10. 54vicky
    54vicky
    I was talking old school no multiple sensor type engines.simple oil pressure kill ignition type.not electric fuel shutoff.not my money though sorry Rich if your system did not help
  11. cb186
    cb186
    Oil pressure switch(that kills ignition) with a push ****on byp*** switch inside that you hold in when starting, until oil pressure comes up. Wouldn't be difficult or silly.
  12. 54vicky
    54vicky
  13. 40cpe
    40cpe
    from Star, MS
    That will work, but defeats the original poster's intent to prevent firing until oil pressure builds.
  14. cb186
    cb186
    Yeah, I was more thinking along the lines of shutting it down if there was a loss of oil pressure(as a resent thread highlights).
