Oil Pump Pick up Hitting pan
Discussion in 'The Hokey Ass Message Board' started by Russell.K, Aug 1, 2013.
  1. Russell.K
    Russell.K
    Hi, I have the oil pan kit from Jamco suspension for a sbc in a 49-50 ford. I installed the oil pump pick up with the drill and tap bracket too. I started up my engine and the pick up taps against the the bottom of the oil pan. Any body else have this problem? Any suggestions on an easy fix? Thanks
  2. when I built stock car engines with a variety of oil pickups I always used a spacer on the pickup tube and set the pan on when in engine stand and checked for clearance before mounting the pickup permantely
    so you can check your clearance someway and bend something to make it clear, this is a cut and bend and weld world you are playing in
  3. mustang6147
    mustang6147
    from Kent, Ohio
    Bend it up. slightly.... you want it low as possible
