Technical Oil Pump Question. Anyone used Speedmaster products?
Discussion in 'The Hokey Ass Message Board' started by Rick Beil, May 30, 2014.
  1. Rick Beil
    Rick Beil
    Has anyone used Speedmaster products? I need and oil pump for my small block project and always ran the HV77 Melling pump or TRW. Speedmaster has one much cheaper but I never heard of them.
  2. wingman9
    wingman9
    from left coast
    Speedmaster is an Australian supplier. If the pumps are made there it's probably good stuff, but if they're imported from you know where it would be better to stick to the brands you know.
  3. Russco
    Russco
    from Central IL
    Milodon makes a good pump
  4. birdman1
    birdman1
    I ahve used lots of various brands theough the years. i honestly cannot tell the difference between any of the brands. I ahve used lots of speedmaster parts, work just fine.
  5. indyjps
    indyjps
    TRW - never had an issue with at least 40 sbc's, that's worth a few extra bucks to me.
    Nothing against speedmaster, oil pumps are just a pain in the ass to change if you drop the engine in and there's a problem. I don't wanna think twice about them once the pan goes on.
  6. 1940Willys
    1940Willys
    And, while yer at it why don't ya get the cheepie shaft and coupler too.
  7. Russco
    Russco
    from Central IL
    The Milodon is just a beefier casting I used to use the standard Mellings but after they changed the castings and I remembered reading about failures both here and other forums. I tried the Milodon, it was a nice piece but required the longer big block style pump stud due to the thicker base casting.
    Here is a link to the thread about the Melling casting changes.
    http://www.jalopyjournal.com/forum/threads/sbc-guys-oil-pump-fyi.143630/
