Technical Oil Stain remover
Discussion in 'The Hokey Ass Message Board' started by Kerry67, Mar 20, 2014.
  1. Kerry67
    Kerry67
    A few years back at the Pomona Swap Meet, I bought a jar of a very fine powder that you put on oil stains in the driveway. It worked perfect.....Anyone know the name of that stuff? I sure as hell can't remember....
  2. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    I don't know the name of it but the very fine powder probably had backing soda in it.
  3. 55Belairretrorod
    55Belairretrorod
    from Australia
    Probably 'Spill-Sorb'. White label with orange writing as I recall. It's a pot-ash product.
    Cheers,
    Arnold.
  4. Roadsir
    Roadsir
    Ahhhhhh, sheeeet man that white powder I bought at the swap meet is driveway cleaner? Is it Ajax?
  5. BISHOP
    BISHOP
  6. KoolKat-57
    KoolKat-57
    from Dublin, OH
    "Granny's" Lye Soap!
    KK
  7. stimpy
    stimpy
    its soda ash ( Sodium carbonate ) has a soap like quality we can get it as washing soda , NHRA used use it for oil clean ups as it breaks the oil surface tension . works great if you mix it with kitty litter and work it into the stain ( the oil dry shuffle ) sweep it up them hose it off , for real bad stained concrete drives we use hydrocloric acid ( muratic acid ) pour it on and let it bubble and rinse off , but it will live a bright white spot on the drive so ussually you should do the whole drive .
  8. indyjps
    indyjps
    Try powdered laundry detergent, not too harsh, the arm and hammer is a fine powder and has baking soda in it. Once you buy the box, its the same stuff you need for your electrolysis tank.
  9. Mike51Merc
    Mike51Merc
    Washing soda also cleans gas tanks very nicely.
  10. 24 Dodge
    24 Dodge
    Dawn liquid dish soap works great leave on and work in with brush.
  11. unkledaddy
    unkledaddy
    Dawn hates grease and oil.
  12. bgaro
    bgaro
    this is what i always remember my dad using on the shop floor a a kid, wet it down and scrub with a push broom. aaah the good ol days.
  13. stimpy
    stimpy
    thanks, I was trying to remember what its non commercial Name was !
  14. shadams
    shadams
  15. verde742
    verde742
    anything that says detergent on it, cuts oil and grease..
  16. Mike51Merc
    Mike51Merc
    Actually, the non-commercial name is Sodium Carbonate.
  17. bobss396
    bobss396
    Tide works pretty well, sudsy as hell when it was rinsed but smelled great.
  18. slowmotion
    slowmotion
    Tide & kerosene in a bucket of water on the shop floor at the Gulf station, 1972. Brisk broom action, rinse, good as new!
  19. fsae0607
    fsae0607
    Anybody have suggestions/recommendations to remove oil spots from an asphalt driveway?
  20. stimpy
    stimpy
    liquid tide ,as much as you can , then new seal coat .
  21. fsae0607
    fsae0607
    Sweet thanks!
  22. fortynut
    fortynut
    Ditto on Tide and Kero. Add kitty litter and use a brick to rub it in. Then wash it off. I used a hose connected to a hot water spigot when I worked in the driveway and it helped even more; especially with the above. It's the carbon molecules that make it dingy, and scaring those ******s off takes some doing.
  23. Special Ed
    Special Ed
    I guess I don't like to work as hard as most of these folks. I just use a little lacquer thinner on my driveway, or if it's fresh, I spray a little brake cleaner on it. **** ... gone. Nothing to hose off, nothing to see ....
