Oil stains
Discussion in 'The Hokey Ass Message Board' started by jester5388, Aug 19, 2009.
  1. jester5388
    jester5388
    what is the best thing around the house to get oil stains off of the street so the neighbors dont get pissed off at you and write you another citation? my car likes to let people know it was there!!!!:)
  2. James Maxwell
    James Maxwell
    from So-Cal
  3. skunx1964
    skunx1964
    pressure washer
  4. 50stude p/u
    50stude p/u
    It doesnt leak it marks its territory :)
    There is this stuff called simply green that is a biodegradable degreaser. You can wash it down the storm drain with out killin the fishies
  5. 53hauler
    53hauler
  6. moter
    moter
    kitty litter..rub it in with your foot,,,sweep up
  7. madmak95
    madmak95
    citation??..... sounds like u need new neighbors not stain remover....
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    If you see an Ameripride Uniform truck ask the driver if he can get you a gallon of "Simply Better" before I retired my neighbors bought it from me a lot,about $10 a gallon it is bio-degradable industrial strength and will even remove s*** from shower doors and stainless too,to use it as a gl*** cleaner you cut it 150 to 1 it is Tough stuff.
  9. millersgarage
    millersgarage
    Laundry detergent poured directly on the stain, let sit a while, scrub and rinse.
    Works best when stain is fresh.
  10. Shifty Shifterton
    Shifty Shifterton
    Powdered laundry detergent, just enough water to make it pasty, and a push broom.
  11. Mack81
    Mack81
    from Tennessee
    I throw on kitty litter, grind it in with a board and then hit it with some laundry soap, brush it in and spray off. Works good for me.
  12. James Maxwell
    James Maxwell
    from So-Cal
    Hey wait a damn minute I thought I invented the kitty litter and grinding it with a board deal, WTF.
  13. Mack81
    Mack81
    from Tennessee
    Learned it from an old employer that how we did the shop floor.
  14. Imperial Kustom
    Imperial Kustom
    More oil. Then tell your neighbors to F.O.
  15. hotrod40coupe
    hotrod40coupe
  16. cruzincougar
    cruzincougar
    I sell products used by contractors for cleaning large oil and gas spills. You do not want to flush anything to the storm drain. It's against the Clean Water Act. Big fines!!
    Down and dirty way to deal with it as long as it doesn't go down the drain: get some neutral spirits and some cheap kitty litter. Pour the spirits onto the spill making sure none runs off. Immediately pile an inch or so of kitty litter on top. Wait until it is completely dry and sweep all of it up. You can down dispose of the litter at your municipal haz waste pick up or save it for the next spot. You may need to do it more than once if it's been there a while.
    Because of the VOC's this may be illegal in some areas with tight air quality regs.
  17. lostforawhile
    lostforawhile
    the simple green doesn't have anything hazderous in it, great stuff too.
  18. Special Ed
    Special Ed
    Yes, but the Simple Green merely disperses the oil. It doesn't eliminate it. If you hose it down, it is still oil and it will still get you in trouble. He's already had a "citation".
    I like Simple Green, also. Don't get me wrong. But kitty litter is the way to actually "pick up" the oil...
  19. evolvo
    evolvo
    from Seattle
    Pore a can of Coke on it, sweep vigorously with kitty litter. Then sit back and think about what Coke does to your insides.
  20. rottenrod
    rottenrod
    i like brake clean but i suppose that would get you in trouble enviromentally too
  21. HOTROD40COUPE - Does that stuff work like it says, or is it Snake Oil?...
  22. 29nash
    29nash
    from colorado
    I use kitty litter to remove oil stain on concrete; Put on some grubby shoes, sprinkle kitty litter on the stain, then shuffle around on it, back and forth. broom it off and marvel at the result.
  23. Truckedup
    Truckedup
    Say it's the garbage truck leaking hydraulic oil.
    You can't park off road? I used to live at a place and park my vehicle in the road.It had a E**on Valdez cl*** oil leak.One time I slipped and fell on my own oil slick.
  24. skunx1964
    skunx1964
    haha, thats my 72 gmc all the way. i almost killed myself goin to get the mail one mornin when i parked somewhere else. :D
  25. Kenneth S
    Kenneth S
  26. unkledaddy
    unkledaddy
    ULTRA DAWN, water and a scrub brush.
    My friend who was a lobsterman in M***achusetts used to pour a whole bottle of Dawn into his bilge (old wooden 28' boat) every morning and let it slosh around while he drank his coffee. Then he'd fire up his bilge pump
    and empty the bilge, never leaving any indication of a rainbow or slick in the harbor water.
    Great stuff. It dissolves oil & grease and cleans about anything. If it's not working, keep adding more Dawn til it does.
    But, you could also park in front of your neighbors houses so they have stains too.............then take Imperial Customs advice and tell them to FO.
  27. MarkL
    MarkL
    from Tacoma WA
    Oil eater works great. http://www.oileater.com/. Its $9.95 for a gallon plus full spray bottle at Costco. Awesome stuff.
  28. jester5388
    jester5388
    haha i think the neighbors know better than that. especially when the stain is in the form of a tire tread going from your garage to the street... messy oil change
  29. Strange Agent
    Strange Agent
    Kitty litter always worked for me. It's cheaper than oil-dry and it works just as nicely.
  30. hotrod40coupe
    hotrod40coupe
    Worked on the stains in my driveway.
