Technical Oil tank location
Discussion in 'The Hokey Ass Message Board' started by COOP, Jul 27, 2019.
  1. COOP
    COOP
    Anyone know where the reservoir for convertable fluid is on a '60 Chevy ? Having top up problems, may have low oil but don't know where to check or add fluid? Thanx.
  2. squirrel
    if it's like my 61 was, it should be right behind the rear seat back. The pump housing has a motor at one end, and the reservoir at the other end. Small plug on top, that you open up. I don't know what it's supposed to be filled with, though.
  3. BJR
    BJR
    The pump and reservoir are under the package tray behind the back seat. You access it from the trunk. There will be a plug on the round body to fill it.
