Technical Ok dumb question. what are the screws called that hold the garnish moldings on a 46 Chevy p.u?
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Feb 28, 2025.
  1. rusty rocket
    rusty rocket
    So the screws in this Chevy pickup are an elongated special machine screw. Not a slot and not a Phillips. What are they called and where do you get the tool to take them out?
    Sharpone likes this.
  2. Rand Man
    Rand Man
    I’d like to see a picture of what you’re talking about, but one odd screw that older Chevy‘s used is called a clutch head almost a bit of a figure 8 shape.
  3. Kosmos55
    Kosmos55
    Like a clutch head?
    Sharpone, catdad49 and anthony myrick like this.
  4. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Dumb screws...
    Hehe just kidding.
    lothiandon1940 and Sharpone like this.
  5. rusty rocket
    rusty rocket
    That’s probably it.
    Sharpone and Rand Man like this.
  6. blue 49
    blue 49
    from Iowa
    If it's hourgl*** shaped it's a clutch head.
    Gary
  7. 05snopro440
    05snopro440
    They're clutch head screws. You can get screwdrivers or bits for them online.
    Just Gary and Sharpone like this.
  8. catdad49
    catdad49
    Yep, bought a set of three after I got my '55 Chevy pick up way back when.
  9. KenC
    KenC
    Yep, like others say, clutch head. The only places I've ever seen those were Chevys and some travel trailers. Really a b....h to remove when rusty.
  10. Lone Star Mopar
    Lone Star Mopar
    Just worked on a 58 Apache that had clutch head screws. Our 52 Chevy car also has them. In a pinch I was able to use a file end in there to get a few out. The proper tool would have been better if there are a bunch to remove. Either way, I'd start spraying them with penetrating oil now.
  11. Fordors
    Fordors
    If you’ve ever tuned or rebuilt a 4160 Holley carburetor the secondary metering plate is held on with clutch heads.
    onetrickpony likes this.
  12. HOTRODPRIMER
    HOTRODPRIMER
    Chevy clutch head screw. HRP
  13. Just Gary
    Just Gary
    Figure-eight shaped clutch head screws were on my '55 Chevy's gas tank sender.
    I loosened them with vise grips & replaced them with normal machine screws.:rolleyes:
    Sharpone and lothiandon1940 like this.
  14. CME1
    CME1
    Clutch head would be correct. I was given a set of clutch head screw drivers from a friend I was helping move a couple of years ago. Took a while for me to figure out what they were used for. But when I did need them, they were quite handy!
  15. 302GMC
    302GMC
    from Idaho
    *^#@!*$%^ screws ....
    Kerrynzl, Sharpone, Just Gary and 2 others like this.
  16. X-cpe
    X-cpe
    Also step vans.
    Squablow, Sharpone and lothiandon1940 like this.
  17. hotrodjack33
    hotrodjack33
    I needed 3 different size clutch head bits when I built my wife's Panel Deliv.
    Needless to say, when I was finished, there were none of those stupid screws left in it.
    Sharpone and Just Gary like this.
  18. Sharpone
    Sharpone
    It was one of Fords Better Ideas that snuck over to Chevrolet lol
    Dan
  19. stuart in mn
    stuart in mn
    I think they were pretty common across all GM lines. I know my Pontiac has some of them in the interior.
  20. Squablow
    Squablow
    I made a few clutch head drivers out of old ****ty screwdrivers, cut the head off and carve the shape in with a cutoff wheel. My homemade ones are extra sharp on the sides that engage when you turn out the screw. Having the engaging edges really sharp helps bite into the screws when they're rusty. The store-bought units I have are a bit more rounded.
  21. Cymro
    Cymro
    A small impact type cordless drill screwdriver worked well on my truck, plenty of penetrating oil and pressure on the bit, hit in very short bursts.
  22. vtwhead
    vtwhead
    The Filling Station sells a set of 4 that fit all the different sizes on the Chevys/GMC's. I looked everywhere for the different sizes needed, even the tool trucks couldn't supply them.
