1952-59 Ford Ok Fellers.... I need a bit of help here.
Discussion in 'Off Topic Hot Rods & Customs' started by genosslk, Jun 10, 2009.
  1. genosslk
    genosslk
    I really need to replace the fricken vacuum wiper motor. I'm sick of them not working even after completely cleaning and re-lubing them.
    Who makes a good electric conversion for them? Something that is a bolt -in without fabbing anything up. My vintage air takes a lot of room under the dash and I have 'just' enough room for the stock vacuum motor. Any of you guys do a conversion?
    Thanks
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. genosslk
    genosslk
    Thanks, i'll check it out!
  4. Paul2748
    Paul2748
    I got Newport wiper in three cars, 54, 48, 56 Bird. No problems with them, went in pretty easy
  5. genosslk
    genosslk
    Thanks, I'll call them on Friday.
  6. I adapted in a toyota (sorry- not hamb friendly word I know!) wiper motor when I did wifeys '55 ranchwagon. Happy to post pics/instructions etc if you are looking for another option.
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    Go ahead and post it,a lot of us like to save a buck where ever we can,'cause we don't get bail outs! :rolleyes:
  8. Post,post, post. I wouldnt mine seeing the pics please.
    My 52 still has the vac one in but i use rainX and big chrome bullets.
    I wasnt sure when the stopped working but when the flattie was rebuilt they were working fine and as the years rolled by they
    stopped every time i took of at the lights.
    Could some please tell me when electric wipers were optioned?.
    I have a 59 ranch (60 model in oz) and they had vac wipers.
    Thanks tony.
  9. ctfortner
    ctfortner
    from West TN
    I recently bought the newport wipers as well. Luckily my install should be pretty easy, I have the dash completely removed to be painted in my 56. I already pulled the vacuum motor out, and held the newport in place, just ran out of time. Looks like it should be easy though.
  10. 50Fraud
    50Fraud
    I put the Newport setup in my '51 about 12 years ago. I'm a ****py mechanic and it went fairly smoothly; they've been working since then without missing a beat. Now I need to do it again on my '56.
  11. Ok , I used a wiper motor and arm/pivot out of the tailgate (rear door ) of a mid 90's Toyota Surf (possibly called 4runner in the usa ?) the model code is LN130 .
    I took the swing arm from the old vac*** motor and fitted it to the japanese pivot which I mounted on a bracket and bolted up where the va*** motor had mounted originally.
    Then I made a bracket to mount the japanese motor to the inside of the firewall (Guys with LHD may need to hang it across the other side) .
    The relay arm from the motor to the pivot (now in the centre of the original ford wiper rack) can be shortened or lengthened to suit .
    Doing the conversion this way gives 2 speeds and also keeps the factory "clap hands" motion for the stock wiper arms /blades etc.
    Hopefully these photos will load ( I'm better at fixin old cars than driving a computor!)
    Anyone who needs more info or a better pic of something is welcome to pm me and I'll email more. Rod.
  12. I must be a little stupid? I can't get photos into my post here so I've added them to my Album (Michelle's ranchwagon project) Like I said above if anyone wants more info or pics send a pm with an email addy for better pics.
