Technical Ok, Ford FE gurus let’s talk
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Feb 18, 2024.
  1. This popped up on my youtube feed:
    bchctybob, RMR&C and sidevalve8ba like this.
  2. Roothawg
    Roothawg
    That because they are watching you….
    loudbang, Oneball and RmK57 like this.
  3. Roothawg
    Roothawg
  4. Roothawg
    Roothawg
    Boneyard51 likes this.
  5. Boneyard51
    Boneyard51
    With most all FEs you want to bore just the minimum. There are a few 390s that were actually cast as 428s and can be bored out to 4.130+ otrher 399s no more that .030. Have to Sonic check FEs if you bore more than .030. It’s a good idea to Sonic chrck all FEs be Fire boring.
    Bones
    bchctybob likes this.
  6. Roothawg
    Roothawg
    This kit uses a 4.250" bore. I am guessing that would have to be an aftermarket block then.
  7. seb fontana
    seb fontana
    from ct
    Or 427 block.
    Boneyard51 and Roothawg like this.
  8. Roothawg
    Roothawg
  9. sunbeam
    sunbeam
    Are we still talking about a commuter shop truck motor or a 10 mpg street brawler
  10. sidevalve8ba
    sidevalve8ba
    Bones,
    Somehow i have it stuck in my head that the last 390's made for the pickups had thicker walled blocks. Am I wrong on this?
  11. Roothawg
    Roothawg
    Shop truck with a big cubic inch motor. Something that can tow without a lot of effort. Something that would be pretty tame but still gets close to 500 ft lbs of torque.
    Deuces, Boneyard51 and rod1 like this.
  12. Broken crank in an FE? Hahahaha
    Roothawg likes this.
  13. If you stay away from the mileage-killing C6, you can get reasonably decent economy with a FE. I'll give two personal examples.... I used to own a stone-stock '68 F100, 360/three on the tree/2.9 rear axle. This gave 20+ MPG on the highway and mid-teens in town if driven with sanity. No rocket though, and the rear gearing was too tall for serious hauling/towing. When I bought the truck, the PO swore it got good mileage, I ***umed he was lying... he wasn't.
    The other one more-or-less addresses what Root wants. This was a '67 Cougar GT, 390/4-speed/3.25 rear gears. When the car came to me in the early '70s, the motor was toast. The POs girlfriend was driving it when it dropped a valve, she managed to drive it home. It totally destroyed one piston/cylinder and the bits went everywhere inside the motor for virtually no salvageable parts in the long block, just exterior pieces. The motor that ended up in it was a 455", basically the crank/rods/heads from a 428 SCJ in a .030-over 427 center oiler block (long story on how that came to be). Add in a .530" lift solid cam, sidewinder intake, 4-tube headers (what a ***** to install!) and the 735 Holley off the GT motor. This was a monster! Melt the tires at will at almost any speed. Of course, if you got carried away with the throttle you could almost watch the gas gauge move. But it would give about 17 MPG on the freeway if driven at the posted limit which to be honest surprised me. Less around town of course, but still in double digits if you didn't get on it much.
    With a modern OD trans, I don't see any reason these results couldn't be duplicated or even improved with some attention paid to trans/rear axle ratios. With another 1/4" of stroke, a 445" should have even more grunt.
    One question I would ask is the advisability of using OD when towing/hauling heavy loads. I know most of the factory ODs aren't rated for that.
    bchctybob, Roothawg and loudbang like this.
  14. Boneyard51
    Boneyard51
    I like most things about this build, but I wonder what the figures would have been if they would have gone with the 4.250 crankshaft kit. It would have given the engine 14 more cubes and an 1/8 inch more stroke, at about the same price!
    I have always been a stroke and cube guy! More low end torque and less chance of ****tering parts.
    Bones
    Deuces and Roothawg like this.
  15. Boneyard51
    Boneyard51
    No, those are the Mirror 105 blocks. They have stronger bottom ends ,due to extra webbing and are thought to have less core shift, making the cylinder walls stronger. Some say thicker, but either way they are usually thought to be good blocks to build!
    Bones
    bchctybob, Deuces and Roothawg like this.
  16. Boneyard51
    Boneyard51
    What transmission are you thinking of using? What size tires?
    Bones
  17. Roothawg, Deuces and Boneyard51 like this.
  18. Roothawg
    Roothawg
    I am thinking of running a TKX 5 speed.
    Probably a 30" tire.
    I may still do the 445. It is probably the most cost efficient.
  19. Boneyard51
    Boneyard51
    Kool! If you go with the TKX 5, go with a medium ratio rear end, with the torque of the 445 a 3:50 would be my choice , for power and ease of cruising down the high way. A 3:89 would be nice, but with that huge torque engine , I would definitely not go any lower.
    Back in the day, 4:11s and 4:30s were the bomb, but that was with smaller engines!
    Remember, when hauling or pulling, it is not necessary to go into overdrive! In fact it is better to pull in direct! No friction going through gears!
    I went all the way across S. Dakota in third gear on a 351 Windsor with a 435 and a 3:50 with 35 inch tires, pulling a gooseneck, loaded, with a motorcycle trailer behind it! Not that I recommend that….lol just happened to me! Direct in your five speed would make it about right. That is why transmissions have multiple gears!
    Back in the late eighties, I put a basicly stock 428 CJ in my 1974 long wheel base dual wheeled long wheelbase flatbed one ton with 4:10 gears and an 435 NP four speed and probably 31 inch tires. We used that on the ranch to haul cattle! We pulled a gooseneck trailer that weighed 6000lbs empty! I smoked many diesels of that era on Tiger Mountain on I - 40! I would have to “ get out of it” there to avoid breaking the speed limit with that huge load!
    That truck now sets in the barn on the ranch!
    Bones said that!
    bchctybob and Roothawg like this.
  20. s55mercury66
    s55mercury66
    from SW Wyoming
    Don't forget, the C6 can be rollerized, dropping its drag down to E4OD levels, although it will still be without overdrive. Anyone that is going to rebuild one would be well advised to do so.
    Roothawg, saltflats and RmK57 like this.
  21. Roothawg
    Roothawg
    I have talking with Brent Lykins about this build. He is saying that due to **** gas, we should shoot for 9:1 compression. He says what I give up 10-15 hp, I could pick up easily enough. He is going to spec out a cam that comes in full on by 4,000.
    bchctybob, Boneyard51, Deuces and 2 others like this.
  22. jaracer
    jaracer
    Back in the mid 70's I was towing my race car with a 71 F250 with a 360. It did okay, but wasn't a power house. It broke a rod (had been bent from hydrostatic lock). I bought a 63 Mercury with a bad transmission and a 390. I was just going to drop it in the truck but found a lot of sludge when I pulled a valve cover. Ended up going completely through the 390. I put in a cam that Ford used in the 335 hp 390's along with a 4 bbl intake and a Ford Holley carb that came on the 335 hp engine. It pulled a lot better than the 360 and I was pretty happy with it until I bought a 76 F250 with a 460. Fuel mileage was maybe a tad better (maybe not), but that 460 pulled my big race car trailer like it wasn't even there. While I had a good number of vehicles with FE engines, the 429/460 made a lot more power stock.
  23. Roothawg
    Roothawg
    I have been wondering about that. I hear different stories based on their experiences. From this it looks about the same. I need to look at torque ratings.
    68-71 429 4V=360HP
    69-70 429 Boss=375HP
    70-71 429 CJ=370HP
    70-71 429 SCJ=375HP
    68-71 460 4V=365HP
    1972 460 4V=245HP
    73-78 460 4V=212HP
    68-71 390 320 HP
    1967 390 320 HP
    1968-76 Truck 215 HP
    1966-68 390 335 HP
    1968-71 390 265 HP
    Deuces likes this.
  24. lumpy 63
    lumpy 63
    With aluminum or iron heads?
    Roothawg and Deuces like this.
  25. RmK57
    RmK57
    1968-71 Lincoln 460’s were rated at 500 ft lbs. torque. Take it for what it’s worth for factory ratings.
  26. Rex_A_Lott
    Rex_A_Lott
    Anybody know what year they went from rating gross at the crank to net at the wheels? I was thinking early 70's but I dont really know for sure. I have also heard that some of the Hi Po options were somewhat derated to get the insurance bills down. Anybody know if that's a fact or just another urban legend?
  27. Roothawg
    Roothawg
    Aluminum
    Deuces likes this.
  28. lumpy 63
    lumpy 63
    Chris, I often build street engines in the area of 10.00 to 10.5 with aluminum heads with 0 issues. With Iron heads I try to stay around 9 to 1.
  29. squirrel
    does that work on trucks as well as cars?
    finn and lumpy 63 like this.
  30. lumpy 63
    lumpy 63
    Just did a bbc in a c30 with 10.00 to 1 thing weighs 5500 lbs :p no problems. And now that I think about it the 396 that came in it was rated at 10.25 to 1...
