Ok, So It's Stupid-Now Tell Me WHY It Won't Work! Supercharged Question
Discussion in 'The Hokey Ass Message Board' started by 38FLATTIE, Feb 3, 2012.
  1. roseville carl
    roseville carl
    Ok so Buddy let me see if I got this right, you have 325 CI at lets say 7000 RPM requires 658CFM at 100% VE or 546 at 83% VE you want to go 200 MPH which will cover 3.33 miles in a minute so if you use the last two miles with boost you will need somewhere between 546 to 658 CF of air at 14 psi, humm with EFI and maybe some type of flapper valve to shut out atmospheric pressure, and then pressurize the manifold once up to speed......HUMMMMMM
  2. 38FLATTIE
    38FLATTIE
    from Colorado
    I think we've determined that we can carry enough air to make a run. 90 seconds of boost will be enough.
    I agree that a flapper valve, of some design, will work to switch between atmospheric, and compressed air. I've received a lot of PM's, and emails on this- thank you. I need to reed and study the suggestions, then figure out how to make this work.
    I'm thinking a flapper valve to isolate the boost, EFI, boost sender, MAP sensor, and some electronically operated flow valves. The valves could be operated by the EFI operating system.
    Carl, this would be cool on your FED!
  3. roseville carl
    roseville carl
    so would the 4-71 I already have................
  4. 38FLATTIE
    38FLATTIE
    from Colorado
    Yes, I can't wait to see it with the 4-71!
  5. roseville carl
    roseville carl
    one step at a time......
  6. Dzus
    Dzus
    Now we're talkin'. Want to take this to the nth degree? If you want a rocket, build a rocket.
    Sorta.
    So what is the purpose of the blower? To pack more molecules of oxygen in a cylinder. Inject the correct ratio of fuel to oxidize with every molecule of oxygen to make power. More oxygen, more fuel, more power.
    Let's just jump to the chase. How compressed can you make oxygen? A liquid. We now have direct injectors. So, one direct injector per cylinder for the fuel, say liquid hydrogen. One other direct injector per cylinder for liquid oxygen. Don't need no blower. Don't need no intake. Don't even need any intake valve. It's entirely fed through those two injectors.
    While the hurdles would be monumental, I think we live in an era where it would almost be possible to achieve. Hell most of the technology needed for this was pioneered over 50 years ago for the the trip it to the moon.
  7. 38FLATTIE
    38FLATTIE
    from Colorado
    Russian Roulette for hotrodders, anyone?:eek:
  8. Engine man
    Engine man
    from Wisconsin
    The problem I see with only using boost for part of the run would be tuning for two widely different air pressures. You would have to use electronic fuel injection with wide range injectors that can supply enough fuel under boost but still be able to cut back enough to run without boost. With a blower, the carburetor is on top and the compression takes place after the fuel and air mixes going through the carburetor. A supercharger with a carburetor requires the carburetor to be inside the pressurized envelope. Carburetors don't handle varying air pressures very well. Racers tune for the conditions at the time of the event.
  9. 38FLATTIE
    38FLATTIE
    from Colorado
    I believe it would have to run in a fuel cl*** have to be EFI. Running fuel, it could run 'fat' on atmospheric air.
    Megasquirt makes an EFI controller, for boost- why not simply utilize it, with dual mapping? Hell, maybe even dual injectors, if necessary.
  10. Reverborama
    Reverborama
    from Minnesota
    The real question is how to get more A/F into the cylinder using no horsepower from the engine, keeping the weight down, and being moderately safe. Compressed air is going to be kind of heavy and really dangerous. An electric powered supercharger is going to need heavy batteries, unless they get that cold fusion thing working and then who's going to be wasting their time with internal combustion. You could run the supercharger with a separate gas engine. But what about a solid-fuel rocket motor? You could run a turbine with it, pressurize your plenum, bleed off any excess boost, and set it up to "run" for the length of time you race -- several seconds for the strip, a couple of minutes for Bonneville.
  11. Keep
    Keep
  12. spellsinger
    spellsinger
    Very interesting thread. But something sticks in my mind, there was a comment earlier about using pure oxygen. Depending on the volume of the intake manifold and cylinders, and having available gasoline, you are talking about a seriously strong grenade in case of a tiny backfire. my guess is that you might have something left from the windshield forward, but not much.
    But in the spirit of things, using hydrogen peroxide and a catalyst, you could make a rocket motor fairly safely from a piston engine. doubtless the engineering would be fantastic, but at least it is a safe compound till turned into hydrogen and oxygen.
  13. roseville carl
    roseville carl
    Well Buddy I quess you could always do this....If you look real hard you can see the 6-71 in there......
  14. gimpyshotrods
    gimpyshotrods
    Just because you can, doesn't mean you should.:rolleyes:
  15. falcongeorge
    falcongeorge
    from BC
    Now I could be wrong about this, I'm old, and my memory sometimes plays tricks on me, but weren't Mickeys experiments with this brought to a close by a rather spectacular starting line explosion?
  16. stainlesssteelrat
    stainlesssteelrat
    from ms
    now.. since we are being a bit.. odd here.. i may as well roll this one out.
    what would it take to convert a normal.. say.. 351c into a two stroke?
    could it be done?
  17. Mike51Merc
    Mike51Merc
    Isn't this just describing Nitrous Oxide?
  18. mart3406
    mart3406
    from Canada
    Yep....and when - not if- something goes
    even infinitesimally wrong, that's exactly
    where you'll be headed to, too....to the
    moon!!!:eek::eek::eek:
    Mart3406 ("who firmly believes
    that 'rocket science' really is 'rocket
    science'!!!
    ":D"
  19. morac41
    morac41
    Hi.. Use a 30" long pulse jet engine exaust into the inlake manifold... plenty of pressure ..no HP to drive it.....very cheap to build.....run on kero.....LOL.....
