Technical OK, 'splain this to me...
Discussion in 'The Hokey Ass Message Board' started by gotta56forme, Feb 28, 2020.
  1. gotta56forme
    gotta56forme
    from Seattle
    Something that has been mysterious to me over the years (and I've been too self-conscious to ask) is I occasionally witness someone, usually at a car show, etc... that when they are parking their car/truck they will rev it up, to say 1500-2000ish rpm, before turning their vehicle off. My powers of observation and imagination have yet to come up with a reasoning for this. Is it just ego to announce their arrival, or is there a practical reason for this habit that I've overlooked? :confused:
    Signed,
    Stymied in Seattle
    VANDENPLAS and chryslerfan55 like this.
  2. Learned it from my Dad, just something your supposed to do !!!
  3. junkyardgenius
    junkyardgenius
    from Kernow
    Yep me too.
  4. Jalopy Joker
    Jalopy Joker
    if you have a motor that runs rich at low speeds sometimes to rev it up and then idle back down - but, if good breathing motor just adding fuel that will not get burned helps nothing - except a statement that you have arrived
  5. Man some people got real **** to worry about
  6. Doublepumper
    Doublepumper
    from OR-WA, USA
    Tinea pedis......?
  7. swade41
    swade41
    from Buffalo,NY
    If you have an engine that likes to run in the upper enchilada but fouls plugs down low, this practice helps clear the plugs so it's easier to start when it's time to leave.
  8. Hollywood-East
    Hollywood-East
    Same reason some car's whine'd it up at the track, Clean out the low speed driving "load-up" with heavy cam/comp. Parking at show.... But it is played out a lil excessive by guy's with stock crate motor's etc.
    gotta56forme likes this.
  9. Blues4U
    Blues4U
    from So Cal
    Maybe they just want to let people hear it. Don't most hot rodders like to hear an engine? I do.
  10. A 2 B
    A 2 B
    from SW Ontario
    Because we can. It's written in our DNA or something.
  11. Hemiman 426
    Hemiman 426
    from Tulsa, Ok.
    the "Italian Tune". Veni Vidi Visi!
    swade41, gotta56forme and williebill like this.
  12. jaracer
    jaracer
    My great Uncle used to do this all the time. He had always had stick shift cars and got a 59 Ford with an automatic. Now long after he got it he did his regular rev up before shut down and ran it through the back wall of the garage.
  13. Taboo56Chevy
    Taboo56Chevy
    I was taught by my grandfather to do this with my 33 as its high compression motor runs rich at idle and can at times, depending on the weather, diesel after you hit the key so blipping the throttle clears out in buildup while putting to park and fully shut down.
  14. Lone Star Mopar
    Lone Star Mopar
  15. Country Joe
    Country Joe
    Same thing happens with Harleys at red lights. They keep cracking the throttle til the light turns green. I don't mind....I like the sound.
  16. My father used to do that in his cars in the 1950's. He said that was to put a little charge back into the battery..
    Boneyard51, clem, Slopok and 2 others like this.
  17. harley jim
    harley jim
    I thought that helped the light turn quicker.
    I love to hear my flowmasters rack off a couple notes before I shut her down.
    Sent from my SM-A102U using Tapatalk
    Boneyard51 and gotta56forme like this.
  18. Tickety Boo
    Tickety Boo
    from Wisconsin
    If you had a cam lot of duration and overlap it might run rich in the idle circuit, and the points ignition system didn't burn off the fuel like the new multi spark ignition system.
    Big Block owners that do this :D:D:D
  19. Beanscoot
    Beanscoot
    I thought the idea was to insure that the cylinders got filled up with fresh fuel and air mixture so the engine was easier to start next time.
    I always thought it was a load of Malarkey though.
    gotta56forme and chryslerfan55 like this.
  20. J'st Wandering
    J'st Wandering
    I need all the help I can to get the motor started when I want to leave. If I shut off the motor when warm, the gas boils out of the carb and floods the motor. If the plugs are fowled when I shut it off, it will be just that much harder to start. I do not have a large cam, just poorly adjusted carburetors and dirty points.
  21. 41rodderz
    41rodderz
    from Oregon
    OUCH !!!! :D:D:D But you have to give gota56forme credit . If that is all he has to worry about , then he must be doing something right. :) I could use some of that .
  22. mad mikey
    mad mikey
    Maybe these car show guys who do this just want to exercise one foot before they sit their *** in a lawn chair for 4 hours.
  23. Mr48chev
    I think all of us older guys heard the "clear it out" before you shut it off thing years ago.
    I'd say that a good portion now are more in the "look at me, I'm here" mode now though.
    I don't mind guys doing that and am probably as guilty as the next guy. What bugs the **** out of me is the guy with open headers who has to fire his car up and gun the engine several times every half hour on the half hour do draw the mouthbreathers over to it to gawk and listen to his story. Usually on a car that a lot of us walk p*** without more than a second glance.
  24. 56don
    56don
    I guess there are many reasons for it getting started. I heard that it was to sling oil up into the engine after idling. Maybe before the days of efficient oil systems.
  25. steeltappet
    steeltappet
    from PA
    I thought it was to strike fear into the hearts of those with lesser motors.
  26. birdman1
    birdman1
    Old wives tale , similar to the one about running the engine to warm the oil up to help get the sludge out when draining oil.
    Scumdog and gotta56forme like this.
  27. Gman0046
    Gman0046
    Revving an engine prior to shut down indicates someone is afflicted with the small ***** syndrome. A very common affliction in the hot rod community.
  28. clem
    clem
    Funny, my wife was just asking me why our neighbour always does this with his Lamborghini’s.
    I said something about the good for the engine.
    She said something about making a statement that he had just arrived.
    Fordors and gotta56forme like this.
  29. Mike VV
    Mike VV
    from SoCal
    Seems most really don't understand the way things work..!
    I agree with the..."my dad did it".
    BUT, I don't.
    Mike
  30. partsdawg
    partsdawg
    from Minnesota
    I heard it was to prevent the blinker fluid from jelling. Or maybe it was to get the right harmonics for the muffler bearings.
