OK What the hell is this thing??
Discussion in 'The Hokey Ass Message Board' started by smokeymtnkustoms, Aug 21, 2006.
  1. It could be anything and will self destruct in 15 seconds. If you are caught or killed the Secretary will disavow any knowledge of your actions.
    Good luck. Mr. Phelps.
  2. squirrel
    whatever it was, it probably didn't work very well with the wires not being soldered onto the switches!
  3. CURIOUS RASH
    CURIOUS RASH
    Classified's Moderator
    Something strange just happened...
    I actually started CARING about what this thing is!
    So I got some questions... What year caddy?
    Can it be some sort of corpse mover like Satan suggested? any holes on the back with wires dangling out? obvious mounting points where nothing is mounted anymore?
    Anywhere on back where lights and such used to be mounted? Follow those wires, inquiring minds want to know.
    I have one last guess though,,, could it be to switch from the left to right blinker fluid reservoirs for when one runs low? ;)
  4. HemiDave
    HemiDave
    from Austin, TX
    I had a box with a switch on it like that. Everyday I'd flip it on and off a few times. Then I got a letter from Germany that said to cut it out.
    Dave
  5. Mutt
    Mutt
    Don't Push The ****on!
    Mutt
  6. CURIOUS RASH
    CURIOUS RASH
    :D
    :D
    :D
  7. Slonaker
    Slonaker
    I'm pretty sure that is just an old project box that Radio Shack used to carry. You bought it in the store along with the switches, LEDs, etc., and made what you needed from it.
    My dad was an old Radio Shack manager from back when they didn't ****. He was always building stuff out of those. If he were still alive, he would have been able to identify all of the parts, AND quote the part numbers and prices. :)
    The only way you will figure it out is to trace any wiring that still exists, if any.
    Slonaker
    EDIT: I believe that is one of the old project boxes that was intended for housing an LED display. The front of it, if it is the one I think it is, was transparent red, like and LED alarm clock, so the LED display could be viewed through it. Whoever put it together didn't use it the way I believe it was intended.
  8. triplexkustoms
    triplexkustoms
    i'll give you 20 bucks for it, it would look great mounted next to my sears underdash c***ette player.
  9. scootersnpie
    scootersnpie
    RUN FOREST.....RUN.....I WAS GOT SOME SCRATNELLL in The ****OCKS...wana see?
  10. Bob K
    Bob K
    from Antigo Wi.
    It's a Wigwam for a Ducks ***
    B:rolleyes:B
  11. Standard equipment on a he****. Here are some refills for it.
  12. Primo
    Primo
    Your best bet for finding out what this used to control is to dig up under your dash find out what it was hooked to because like what was said it could be anything. Also if it has some lights/motor/some weird electrical thing that looks like it was added on later that is probably what it controlled.
    PRimo
  13. a catapult to launch the caskets out the back? switch to arm press ****on to launch..
  14. Mr. Mac
    Mr. Mac
    All righty then,If your married have you wife push the ****on. Run like hell first.:D :D
  15. Did the car have four-way blinkers, factory? I just pulled a Signal-Stat switch off a '66 Catalina convertible (no one wants those, so it's being s****ped, frame is bad anyways) that someone had added onto it complete with terminals that clipped onto the column wiring.
    How about back-up lights? Looks like something someone would make to improve upon or replace a factory type switch, how many things would you need an indicator to know it was turned on?
  16. Rand Man
    Rand Man
    You have to enter the code and press that ****on every 108 minutes. The fate of the world depends upon your action.
  17. Kustomz
    Kustomz
    Does that toggle switch have 3 positions like 2 on and an off position in the middle?
  18. Thorkle Rod
    Thorkle Rod
    Holly ****!! Bat Man they have our Bat cove door opener, Call the comish we need to get right on this before they find us,
    to the Batmobile Robin!!
  19. Royalshifter
    Royalshifter
    Moderator
    It looks like the Riddler's remote control bomb that Batman would have to defuse on every episode.
  20. "That there is a part off Clark's RV" - All the guys in California put them on their cars to make them go faster:eek: Gary 4T950 Chevy Guy
  21. k-member
    k-member
    Ha ha, for hauling multiples. Maybe for a deodorizer!
  22. hahaha
    get to the chopper!!
  23. MIKE-3137
    MIKE-3137
    Its for the cloaking device.
  24. 51 MERC-CT
    51 MERC-CT
    Just something to keep the driver occupied:) :D [​IMG]
  25. reverb2000
    reverb2000
    from Houston TX
    oh man, people have been DIEING to get ahold of one of those..bahahahha
  26. Eisenfaust
    Eisenfaust
    That's an electric brake (trailer) control/ switch.
  27. jusjunk
    jusjunk
    from Michigan
    Hummmmmmmmmm. Years ago we used a box like that hooked up to a few more pieces and set off radar dectors:D We used to call it trolling for tailights:p:p
    Dave
  28. 51 MERC-CT
    51 MERC-CT
    Maybe it's a H.A.M.B. detector.:) :D
  29. BinderRod
    BinderRod
    Looks like a SPANK-O-METER
  30. dabirdguy
    dabirdguy
    You lot are all FULL of it.
    That is the JImmy Hoffa Dector box.
    You turn it on and when you are near Jimmy the light goes on.
