Okay, I am finally gonna break down and...
Discussion in 'The Hokey Ass Message Board' started by Chopperdave, Apr 9, 2004.
  1. Chopperdave
    Chopperdave
    pull the 6 outta my 52 chevy
    it allready has a turbo 350 and i need to put a v8 in it, but a 50's v8, i know that i can get an adapterplate to fit anything to anything, so...
    does anybody have a take out motor that is complete and runs well???
    okay, NO buick motors... sorry buick guys, i don't like them.
    don't really want a y-block either...
    but!
    i'd prefer a good running olds v8
    but i'll use just about any good pre 62 v8
    so
    does anybody have a decent running one they would part with???
    cheap is the key word here too...
    okay, i'm really not cheap, i am just way over extended as it is...
  2. shoebox72
    shoebox72
    Wow'em all & put a built flatty in it. [​IMG] [​IMG]
    Billy
  3. DrJ
    DrJ
    Is it a BOP pattern T350 or a Chevy pattern?
    You're planning on going with an adapter plate I guess?
  4. Chopperdave
    Chopperdave
    the chevy one, it has a 216 with the stovebolt co adapter and a b&m race trans
    i will need an adapter plate for all the engines i can think of that i would want to run, yes
  5. wayfarer
    wayfarer
    If you want to get rid of that 216 adapter, let me know.
  6. TheDooWopKid13
    TheDooWopKid13
    if your giving it away for free ill take it.
  7. Chopperdave
    Chopperdave
    ill keep that in mind
    thanx
  8. If you use a bigger v/8, you'll fight that stock steering box. And you'll almost have to use a rear-sump oil pan to clear the equalizer thingee for the stock steering linkage. Maybe a Pontiac, Olds or caddy and don't be shy about moving the engine over an inch or 2 off center to the right side. You'll probably need to for steering box clearance.
    Sorry, I'd go for a sbc. I did the same swap as you only with a 4 speed and the chevy V/8 is the way to go....how 'bout a DIFFERENT chevy v/8? Maybe a big block or a 348/409?
  9. Greezy
    Greezy
    Theres no shame in putting a chevy in the chevy. The swap is pretty simple.
