Projects Old 32 Ford Hot Rod gets "Updated"...Part II (Racing History, added 06-29-15)
Discussion in 'Traditional Hot Rods' started by NealinCA, Feb 2, 2014.
  1. wingedexpress
    wingedexpress
    That frame is looking good Neal.
  2. NealinCA
    NealinCA
    I think the later "narrow" crossmembers measure 43-9/16". The earlier ones are pretty close to 43-3/4". You can easily see the difference if you stand the two side by side. I'll throw a tape on it when I pull it back out of the frame.
    Neal
  3. draider
    draider
    from Texas
    Are you going to weld or rivet the crossmember back in?
  4. NealinCA
    NealinCA
    I will probably put a couple of short welds on the tabs and then rivet the rest.
  5. NealinCA
    NealinCA
    Hey Larry...looky here. ;):)
    kidcampbell71 likes this.
  6. 3wLarry
    3wLarry
    from Owasso, Ok
    touche' mon ami
  7. inkstain27
    inkstain27
  8. 383deuce
    383deuce
    I like the NO FENDERS look myself.......Go for it Dale....Lets see some photos of what ya got going on.....
  9. I'll be following along. I always like seeing Neal's skills at work.
  10. Stovebolt
    Stovebolt
    Thanks for the measurement on the crossmember.
  11. 562roadster
    562roadster
    Damn good work!
  12. NealinCA
    NealinCA
    Made a little more progress this weekend. Like I said, I had a late 32 rear crossmember which is narrow, so I decided to add the reinforments in the kickup.
    I made patterns and cut out the 6 pieces on the bandsaw. I clamped them in place in the rails and tacked them together...
    Then pulled them out and TIG'd inside and out. That was over 16' of weld...
    They were then plug welded into the rail...
    The crossmember was then fit. Most of the rivet holes were welded up and then redrilled once in place.
    The crossmember is bolted now, but rivets are next weekends project...
    Neal
  13. Nice work Neal! Such a cool old hot rod and your giving it some well deserved love!
    Don't know if I would run it fenders or fenderless... hmmmm
    -Shiny
  14. 343w
    343w
    The 32 4 door is my favorite more-door for sure, looking good!
  15. NealinCA
    NealinCA
    OK, got the rear crossmember riveted in. Had to make some riveting tools first...
    After a little trial and error, we got the crossmember done...
    Here's some pics to remind you what I started with...
    Since the car is going back together as a "patinamobile", I left the original black paint on the sides of the rails and painted the rest with "rusty brown".
    Now the frame is done, so I am working on engine, trans, rearend, etc. Hopefully to begin ***embly soon.
    Neal
  16. alchemy
    alchemy
    Your inner "restorer" is showing.
  17. NealinCA
    NealinCA
    It's kinda funny, I feel like I can't post this project on the Fordbarn because it's too "hot rodder", and then there's not much interest here because its too "restorer". Oh well, I havin fun... ;):)
  18. hotcoupe
    hotcoupe
    neal, great looking work! what size rivet gun did you use and did you rivet them hot or cold?
    tom [in st.louis]
  19. NealinCA
    NealinCA
    Tom - We did the rivets hot. I made the rivet set for the gun to fit the head of the 5/16" rivets. I also made it longer than the ones you can buy, to get in the frame rail easier. The gun is just an import air hammer. I adjusted air pressure until I got the results I was after on some test pieces.
    Neal
  20. PRIMER STUDIO
    PRIMER STUDIO
    from Butte,MT
    Looking fantastic Neil!
  21. 3wLarry
    3wLarry
    from Owasso, Ok
    that is sick...love the rivets
    please disclose "rusty brown" formula
  22. Oh there's interest! Keep up the great work.
    A Boner likes this.
  23. NealinCA
    NealinCA
    Maybe I should just start a new thread about fake patina... ;):D
  24. clem
    clem
    Please keep the pics coming, always plenty of interest in your great work. Thanks.
    Tomkat39 likes this.
  25. harpo1313
    harpo1313
    from wareham,ma
    Nice work on those rivets.Good to see you back on it.
  26. alchemy
    alchemy
    Don't worry, there's plenty of interest here. I too think the older I get the more "restorer" I become. Some famous builder guy says something like "You've got to restore an old Ford before you can hot rod it".
  27. slug
    slug
    Great work Neal. I think more should be done the way you do them. Your stuff is trick but uses old ford parts. Just right. Slug
  28. Mart
    Mart
    Hi Neal. I like what you did with the rivets. The rivets on the top side of the frame rail, through the crossmember, how did you hold/rivet/buck them? Does the tooling reach around the lower frame rail? Is the head of the rivet on the top or the bottom?
    It looks great, by the way.
    Mart.
  29. NealinCA
    NealinCA
  30. 3wLarry
    3wLarry
    from Owasso, Ok
    note to self...research rusty brown paint codes
