Hot Rods Old Allstate Under Dash AC
Discussion in 'The Hokey Ass Message Board' started by Boxcar's 1928, Sep 16, 2022.
  1. Boxcar's 1928
    Boxcar's 1928
    Just scrounged up this old Allstate a/c unit while on a work trip to Vegas. I'm guessing mid 60's... Any thoughts? Any comments on getting it up and running? Seems complete....and dirty. Mailed it off to my home address....so I'm $80 into it so far. 20220916_111202.jpg
    skooch likes this.
  2. greybeard360
    greybeard360
    See if the blower works. Do a vacuum test on the evap core and see if it holds a vacuum. If it does, flush the core, clean up the unit and chill out!
    firstinsteele likes this.
  3. Boxcar's 1928
    Boxcar's 1928
    Cool man! Thanks
  4. Bob Lowry
    Bob Lowry
    allstate truck.jpg Way cool....I would use it..nice find...would be perfect for my advertising truck...
    Boxcar's 1928 likes this.
  5. 38Chevy454
    38Chevy454
    I use a similar old 60s underdash evaporator unit. Works great on R134a, even though the official thermal expansion valve is designed for R12. Used on 2 vehicles, tgey are the Mk IV type.
    As suggested, just ensure the fan motor works, and the evap holds vacuum. They are so straightforward simple there isn't much to go wrong with them. It's most likely set up for flare fittings. That's not bad, just more susceptible to leaks than modern O-ring type.
  6. davidh73750
    davidh73750
    Bob Lowry and elgringo71 like this.
  7. bobss396
    bobss396
    When I worked for Sears, they installed AC units. Simple kits to better looking deluxe kits. Even in 1976 dollars, I could not see a profit selling them for $299. I recall a pile of AC parts in a back room, you could have built a couple of systems just from what was laying around.
    davidh73750 and Bob Lowry like this.
  8. davidh73750
    davidh73750
    $300 then is about $1600 now.
    I have this Sears unit dated 64 definitely has mid century vibe
    bobss396 likes this.
  9. bobss396
    bobss396
    Very cool. There were a lot of dealers in the day that installed AC on new cars, that looks like a piece they used. The older Mustang units for in almost anything.
  10. junkyardjeff
    junkyardjeff
    I put one of those in a 53 Olds,found it in a junkyard in a 62 Olds that sat so long it sunk to the frame. Still had freon and had it in the 53 by the next weekend and working and worked great.
