Technical OLD Crankshaft
Discussion in 'The Hokey Ass Message Board' started by Michael F D'Oliveira, Feb 3, 2018.
  1. Cleaning out My shop and came across this crankshaft upstairs in the attic ....Looked in all my old Federal Mogul Shop Manuals but cannot figure out what make it is....anyone have a clue? Old enough to have a slinger ....cast # 2SA701B also says PARK 27711311_575142779491203_2099126368_o.jpg 27711355_575142826157865_2029420477_o.jpg 27786880_575142816157866_1696480374_o.jpg
  2. i have no idea , but the background in your 2nd picture makes me curious as to what type of shop you have
    i wonder what else could be found there?
  3. Paul
    Paul
    Editor
    Do I see seven main journals and six rod journals?
    Might be a helpful clue.
    6 or 12 cylinders?
    Clay Belt and Hnstray like this.
  4. Automotive Machine Shop .....established in 1938
  5.
  6. Mark T
    Mark T
  7. well that is interesting !
  8. Gerrys
    Gerrys
    Michael F D'Oliveira likes this.
  9. Rusty O'Toole
    Rusty O'Toole
    6 cyl 7 main bearings probably 1920s should narrow it down. If you can measure the bearing diameters that is another clue. It should be possible to figure it out but with a lot of time spent looking thru old manuals.
    You might try asking these guys. Chances are someone will give you the answer within an hour.
    AACA Forums
  10. sunbeam
    sunbeam
    From the length of the crank the bore centers must be huge I'm betting truck
  11. deathrowdave
    deathrowdave
    from NKy
    That thing is huge ! I know that’s what they all say ! I’m betting an off road piece of equipment , Dozer , Tractor ?
  12. Clay Belt
    Clay Belt
    Performance flathead Mopar I6?
  13. 302GMC
    302GMC
    from Idaho
    Went thru 2 AERA casting number books today with no luck. Size suggests something in the Waukesha - Hall-Scott range
  14. I was thinking Truck too..
  15. FWIW,,,closest # I found was 2SA-101,,,REO,, '32-'''39. From a 1963 FM spec' book. What are the journal sizes, and stroke?
