old farm trailers as a source of parts.
Discussion in 'The Hokey Ass Message Board' started by 5foot2, Nov 19, 2009.
  1. Okie Pete
    Okie Pete
    Around here Ford running gear was used under wagon boxes, flat trailers. When left outside for years the wheels are rotted out.
  2. olscrounger
    olscrounger
    as mentioned Sears and Montgomery Ward made some kits to convert early car ch***is to trailers--some were marketed under tha name "Bradley"-saw several like this and some were 32's as well-this was in central CA--probably still alot around on old farms,etc.
  3. Lucky77
    Lucky77
    The 40 Ford backing plates on my sedan and the spindles that I just installed on my roadster came from the front axle of some dismantled farm wagon that I bought for ten whole bucks!
  4. hvychvy
    hvychvy
    My buddy picked up this 32 frame/trailer from a guy for a case of beer a couple years ago.Mega score!!:)
  5. barnescole
    barnescole
    the 9" in my pickup came from a farm trailer made from a 57 ford truckbed and frame. big bearing, just had to s**** the leather pinion seal.
  6. hotrod harry
    hotrod harry
    from wisconsin
    found this under a ****py boat with free for the taking sign on it
    threw the boat back in the yard and fled with rest!
  7. Steelsmith
    Steelsmith
    (quote)
    <!-- / message --><!-- attachments --><FIELDSET cl***=fieldset><LEGEND>Attached Thumbnails</LEGEND>[​IMG]
    </FIELDSET>
    You sir, are a ****! Instead of being grateful for a free ch***is, and disposing of the unwanted boat which was the owners whole point to GIVING away the ch***is, you dump it in his yard! ...amazing!
    ... and then you get on the HAMB and brag about it?! Did you expect support from US?! What a **** ...
    Dan Stevens
    dba, Steelsmith
  8. BISHOP
    BISHOP
    You really should go back and pick the boat up, Damn.
  9. nutajunka
    nutajunka
    Double Damn!.....,.:p
  10. nutajunka
    nutajunka
    I have a couple friends, one a farmer who has a stack of model A and T frame rails they used as fence posts. The other has a old junkyard and uses the rails for shelving supports. T and A stuff everywhere crazy!
  11. I know where a hay trailer is in a junk pile....it was made from a Packard and still has the wire wheels on it! Rear diff housing and straight axle as well....
  12. '54Caddy
    '54Caddy
    I ran across a homemade trailer on craigslist about a year ago. made out of a 1947 studebaker pickup bed complete with fenders, and in good shape. The axle was a ford 9". all for $125.
  13. THIS is an interesting thread! An OLD thread but interesting.
    I want to add "The Vester" to it.
    I found an old Dodge axle welded up as welder tow rig in a junkyard
    Which I later turned into a six ft trailer.
    Best I can figure it is a mid 1930's Dodge truck front axle. The wheels on it were later and the hubcaps had holes cut in them because the hubs were so long on the axle. I am guessing the hubs were long because it originally came with spoked wheels.
    I replaced the rusted wheels with a couple 14's that came on my '66 Mustang when I bought it years ago. Not as interesting as some of the other finds but I'm proud of saving an old axle before it was s****ped.
    An illustration of how LONG the hubs are on this thing
  14. junkyardjeff
    junkyardjeff
    The original flatbed from my 37 Chevy p/u was removed to become a hay wagon and the truck went into the woods,I am glad nothing was done to the rest of the truck. If my uncle would have lived longer the truck probably would have been made into many things.
  15. Sorry no pictures, but I found an old wooden horse trailer that had 4 Kelsey Haze 40 spoke bent wire wheels with it. Had to drag it out of the woods swap wheel to tow it
    home for $50 bucks,. Thought it was a great deal, they are on my '46 Ford now.
  16. slickhale
    slickhale
    from Phoenix
    One of my grandpas hay wagons has 50's Mopar hubs on it. The first time I ever had to change a flat on it when i was a kid he let me fight with it for about 15 minutes before he told me about the left hand threads.
  17. wsdad
    wsdad
    made from 30s vintage car front end heavy duty springs
    4 x 8 homemade trailer - $125 (redwood falls) <SECTION cl***=userbody><FIGURE cl***=iw>
    </FIGURE>
    [​IMG][​IMG][​IMG][​IMG]
    © craigslist - Map data © OpenStreetMap
    <SMALL>(google map) (yahoo map) </SMALL>
    <SECTION id=postingbody>made from 30s vintage car front end heavy duty springs DAVE @ 507-640-0809
  18. rusty1
    rusty1
    ...bought a car from this guy, he has this old wagon with early Ford runnin gear, gonna go back for another look
  19. wade57
    wade57
    from BC Canada
    Great thread. I will be keeping my eyes peeled for old trailers.
  20. Buddy has a buzz saw made out of a '37 Plymouth. Cut the body off behind the front doors, big truck wheels welded to the drums (!), frame bent behind the rear axle to carry a big (like 2 feet or more in diameter) sawblade. To spin the blade, it had a drum in contact with one rear wheel - to cut wood, you jacked that wheel off the ground with the air pressure pumped up in the tire.
    So not only did you have the giant unguarded blade, but you had a car on a jackstand running at speed, in gear. I suppose if you nosed it up to another tree at least it wouldn't run away from you if it fell.
    But there was enough left of it a guy could have made a pickup out of it, or put another body on it.
  21. partsdawg
    partsdawg
    from Minnesota
    Next time your at a farm auction pay attention to any of the really old timers there.
    See how many are missing fingers or a arm.Corn pickers were the most common digit ******ers.
    Safety was not the biggest concern.The Depression/post Depression era folks were just trying to get by and you made do with what you had.
  22. One I own.
    Early 40's Ford axle with '49 Merc wheels.
  23. Driveway builder
    Driveway builder
    It ****s how much of this stuff was s****ped around where I live... I remember seeing this kind of stuff, even Doodle Bugs in the corner of almost every field. Now its gone and yuppies with huge houses are there. :(
  24. sunbeam
    sunbeam
    Farm Auctions are great> I picked up a wagon with a 32 frame for s**** price and Ford pickup bed trailers often have a 9 inch.
  25. patterpillar
    patterpillar
    from Montana
    Here is one of my finds. I pulled all the old rotten boards off and this was under it. I have another at my Dad's house that might be old Plymouth artillery wheels. Just for fun guess what is in the back round.
      521.3 KB
      556 KB
  26.
  27. peter schmidt
    peter schmidt
    from maryland
    Bought my model a frame form a junkyard and it was used as a hay wagon in its past life I also drug a 33 front end out of the woods with my dirt bike not to fun but it now resides under the a frame and it too was some sort of trailer the steering was bent down and welded to the wishbones couldent beat the price cost me a ratchet strap when it got caught in the chain and turned my dirt bike into an instant low rider lol
  28. Blownolds
    Blownolds
    from So Cal
    I always used to look at old trailers. I've seen some reasonably decent early Ford pickup fenders on those things before. I also once salvaged some super-duper early (like '20's) rearend out of one once. No idea why I did that.... I guess I was into the "preservation" mindset at the time.
  29. indyjps
    indyjps
    Found a trailer at a local gardening place that has this axle, can someone identify it. They're not real interested in parting with it so I may have to pony up some cash, what's the axle, wheels worth?
    I want to add this to the parts stash, just don't want to overpay.
  30. metalman
    metalman
    A guy here found a 41 Ford convertible sitting in a pasture, found the owner who was willing to sell. Problem, the doors were missing. Old rancher claimed he had the doors, sure enough they were 5 miles away being used as gates on his sheep pen!
    Growing up on a farm we had all types of trailers, wagons, saws made out of old cars and trucks with the left over bodies lying in the trees and arroyas. Never thought twice about saving any of it, the farm and everything with it was sold off years ago.
