Old Ford Gearbox I/D
Discussion in 'The Hokey Ass Message Board' started by Taildraggin, Dec 23, 2004.
  1. Just picked up an old 59 flathead complete with gearbox.
    Any idea what it is, and whats its like.
    Its got an open drive so maybe its a truck gearbox and might not be any good for the 26 RPU we are putting together.
  2. another
  3. alchemy
    alchemy
    You are right, it's a BIG truck box. Not sure of the year, but approx 42-48. Gear ratio is probably too low for street use in a T.
  4. manyolcars
    manyolcars
    4 spd, truck, granny low, 42 and newer This can be a desirable transmission for an old timey truck, with a smallblock chevy engine. The chevy probably wont break this trans and its open drive. The pic shows a 6 bolt access panel on the lower right side. This is where the power take off fits. If anyone has a power take off 1929 to 1947, I will buy it. I see that taildraggin is in England. Betcha this is a 42 engine/trans. It has a rebuilders tag on it.
  5. Flat Ernie
    Flat Ernie
    Tech Editor
    Even if you don't use the box (and you probably shouldn't - 1st gear is all but useless unless you've got a lorry!), take the time to pull the front mini-bellhousing off the front of the ******. Those make great adapters for other transmissions requiring only a flatplate adapter to be machined up...
  6. I thought it might be an old truck trans.
    Manyolcars. Yes it has got a rebuild tag on it but water got into two of the bores and they are rusted up quite bad.
    valves are rusted in on them as well but the rest is real good. Its a shame it was left outside sometime in its life [​IMG].
    Have to try and locate a transmission now.
  7. Flat Ernie
    Flat Ernie
    Tech Editor
    You should be able to adapt damn near any ****** with that 4spd front...
  8. manyolcars
    manyolcars
    FlatE the photo shows standard 42 type engine/trans. The separate bell housing was about 1948-53?
  9. Mart
    Mart
    Ernie, I have a 4 speed similar to that, from a lorry/truck. It does not have a separate bellhousing. Can't see for sure, but the pics above seem to be similar to mine, ie not a separate bell. Can anyone say what years had the separate bell housing??
    Mart.
  10. Flat Ernie
    Flat Ernie
    Tech Editor
    [ QUOTE ]
    [/ QUOTE ]
    Arrgh! You're right - I didn't look closely, just ***umed it was the later one....for those interested, here's what one would look like when unbolted
  11. I have one just like it behind my 8ba, came out of a 51 f-1, I'll check to see if it has the access panel, Manyolcars, if it does, you have dibs.
    The mounting plate has already been spoken for.
  12. AV8Paul
    AV8Paul
    I believe that the separate bell was on 1948+ trucks abd 1949 + cars.
  13. fatfender
    fatfender
    i have one of them tags on my flathead. are the all rebuilter tags?how can you find out what the mean
