Old Ford Gurus I need help
Discussion in 'The Hokey Ass Message Board' started by Slapnuts1975, Jun 9, 2009.
  1. Slapnuts1975
    Slapnuts1975
    from Tennessee
    Trying to remove the starter on my 53 mainline, one bolt visible, and cant find another anywhere. Is there a trick to this?
  2. CJ Steak
    CJ Steak
    from Texas
    Which engine do you have? Most (maybe all) of the Ford engines from that era just have two bolts. The other bolt will be 180 degrees from the other one... straight across to torque it evenly. You may have to attack some grease with a screw driver to find the other bolt.
    Good luck
    -Chris
  3. Hoop-in-JAX
    Hoop-in-JAX
    They are cast into the block and have to be removed throught the tailpipe.
    Otherwise, you unscrew the small, long bolts that run completely through the starter ... they are on the front end.
  4. Hoop-in-JAX
    Hoop-in-JAX
    "Otherwise, you unscrew the small, long bolts that run completely through the starter ... they are on the front end."
    Ol' Slapnuts is saying to himself, "I ain't falling for that ****."
  5. Straightpipes
    Straightpipes
    When you take those loooooong bolts out make sure that the starter don't fall apart because they not only hold it in but they hold it together!! If you only take them out far enough to get them out of the starter plate you should be OK.
    JAX, I had a guy recently trying to pull the starter plate and all to get the starter off:D
  6. Squablow
    Squablow
    Yup, on the flathead V8 it's the long bolts that go all the way through the starter. I know it sounds crazy but it's true.
  7. Slapnuts1975
    Slapnuts1975
    from Tennessee
    Thanks for the replys guys, I figured it out. Was just waaaaaaaaaaaaayy overthinking it.
  8. Hoop-in-JAX
    Hoop-in-JAX
    Good, Slapnuts.
    And it's nice to read posts from other guys who find humor in the way some of this stuff is designed.
  9. R Pope
    R Pope
    That musta been one of Henry's lightbulb ideas.
  10. Bruce Lancaster
    Bruce Lancaster
    You found one bolt...if car has automatic, there is an extra bolt through a side bracket, and that may be what you referred to? Only different 221-239-255 starter: Extra bolt, different drive and gear.
