Old Ford spindle, and front end help.
Discussion in 'Off Topic Hot Rods & Customs' started by Matt Dudley, Nov 14, 2024.
  1. Matt Dudley
    Matt Dudley
    from New York
    I’m back building my hot rod. Decided to abandon my scratch built cab as it’s too wonky. Just gonna get the frame on wheels for now and then worry about a body later ( most likely ‘27 roadster )
    I bought a suspension off of an old hot rod that someone parted out and I have square back Ford spindles and they need re pinned and bushed.. Is there an old timer way to fit them? I know big truck mechanics who probably have reemers 6x too big.
    also what do I have? This is all the stuff I picked up along with an old drop out center GM rear set up for the buggy spring. I most likely will go disc brakes in the front for safety reasons but I do have backing plates so idk. I have a clean and straight original A frame that I will box and put a reproduction rivet in crossmember in with the 7* caster angle built in. I’ll weld it once it’s located correctly.
  2. RodStRace
    RodStRace
