Old gas disposal/uses?
Discussion in 'The Hokey Ass Message Board' started by Mike51Merc, Jul 6, 2010.
  1. Mike51Merc
    Mike51Merc
    I've got an old gas tank that needs to be emptied. I figure it's got about 5-8 gallons in it.
    What do you guys do with old gasoline? Ignoring the nasty smell, does it have any uses as a cleaner or other useful purpose?
    I figure I'll probably have to store it until the local haz-mat collection which is once a year.
    Any ideas?
  2. bobss396
    bobss396
    Your local landfill usually has a couple of tanks for oil and other chemical disposal year-round. Give them a call and see what they recommend. Your local fire department will also be able to give you some advice.
    Bob
  3. Works really good for killing fire ants or weeds.
    I had a fie ant hill in my front yard a couple of years ago. Dumped the old skunk gas from a tank I was going to get boiled and the gr*** still won't grow there.:D
    probably against some sort of a law. :eek:
  4. See what did I tell ya? I don't figure that gas is any worse than 2-4D for killing brush.
    I used to dump drain oil on my firewood. It made it a little easier to get a fore started when the wood got wet.
  5. gas pumper
    gas pumper
    Weed killer, I use a dish detergent bottle to spot kill the weeds that grow thu the sidewalks and ashpalt.
    Around your foundation if you get carpenter ants.
  6. Dale Fairfax
    Dale Fairfax
    Do you have a daily driver (not a Hot Rod)? If so pour it in that tank-agallon or so to at least a half tank full. Use it up.
  7. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Don't use it as a cleaner. Even if it's old gas it could be flammable. More than one unfortunate dude has sparked a tray of gas while cleaning parts. Use safety solvent.
  8. Big Mac
    Big Mac
    It's pretty good for cleaning oil stains off the garage/driveway.
  9. Rudebaker
    Rudebaker
    from Illinois
    That and for those of us that use "traditional" lawn mowers you can mix it in with your mower gas. OK, so a 1970 Wheel horse isn't exactly traditional but who has one older they use every week?
  10. xlr8
    xlr8
    from Idaho
    Sit it out in the hot sun in a flat pan and most of it will just evaporate away.
  11. V4
    V4
    If it was July 4, I would have an idea, but since it is July 6 I guess you just have to kill weeds with it.
  12. Left Turn
    Left Turn
    from Omaha, NE
    I use it in the old work tractor (old 2cyl John Deere M, it loves the ****), works fine in old lawn mowers too... good weed killer too.
  13. PRoz
    PRoz
    Use it up a little at atime to start fires in a fire pit. Who needs paper. Throw in the wood, pour some gas on said wood and then flick a match from 10-15 feet away and wait for the woomph. :)
  14. bb1970
    bb1970
    Mix it with Pramitol. You got one helluva weed killer there.
  15. Francisco Plumbero
    Francisco Plumbero
    from il.
    Bon fire it. Dont run your mower on it. They dont make mowers that can eat that any more.
  16. As others have said... "it may be against the law"
    Most states have a water pollution prevention plan... sometimes referred to as "Storm Water Pollution Prevention Plan"
    Your safest alternative is to burn it in a pit of sorts where the sediment can be disposed of in the trash.
    You really dont want that stuff contaminating your groundwater supplies.
  17. iammarvin
    iammarvin
    from Tulare, Ca
    Aftershave lotion........the wemon justs loves the smell....
  18. redlinetoys
    redlinetoys
    from Midwest
    Putting it on the ground is a bad idea, weeds or not. Organic solvents or petroleum will stick around for a LONG time. Basically they just make their way down to the ground water and then lay on top of that forever, either sticking around at your place, moving into your drinking water well or moving down the underground waterway to your neighbors, or eventually your favorite fishing hole. Don't do it.
    Work it off in good gas in an engine, or burn it in a controlled way or just dispose of it properly at a local municipal disposal center.
  19. OrrieG
    OrrieG
    from Idaho
    Dumping it on the ground is a bad idea for future house resale too. next owner might decide your car hobby may have caused problems and hire someone to investigate. They find petroleum residue and you have an expensive problem. Most municipalites have to have a place when citizens can dispose of old solvents, paint, gas, etc. Around here they rotate to a different fire station weekly in four different parts of town or you can take it to the city dump and they have an area there. City public works dept. usually deals with it under Clean Water Act.
  20. I had some old gas so I dumped it the company work truck I drive and it worked fine. So I wound up giving a billion dollar company 5 free gallons of gas.
  21. silent rick
    silent rick
    i've seen this method used before.
    i've taken it to an old service station where the guy said sure, dump it in our waste trap, it's a petrolium product, they'll recycle it.
  22. add all your used styrofoam coffee cups till you get a creammy,,,,,,,naa forget about that,,,,bad idea....recycleing center is the safest
  23. Pouring it on the ground is the sort of thing that causes site contamination. That can result in clean up order$, fine$ etc.
  24. stuart in mn
    stuart in mn
    Mix it in with the lawnmower gas a little at a time, or mix it in with the gas in your daily driver (***uming it's not leaded gas and you have a catalytic converter.) Pouring it on the ground is a bad idea.
    My Jacobsen dates to about 1965. ;) It will run on just about anything.
  25. Antny
    Antny
    from Noo Yawk
    I pour old tired gas into a sealed container (old joint compound bucket with the lid), I use it to soak rags for nasty goo clean-up.
  26. Gofannon
    Gofannon
    Just dump it in the Gulf of Mexico, like BP does.
  27. dragster dude
    dragster dude
    not to mention how it brings out the red in your neck :rolleyes:
  28. Hdonlybob
    Hdonlybob
    Depending where you live, it makes a great weed killer....
  29. BBQ some hippies?
  30. skidsteer
    skidsteer
    some junk yards will take it. They let it sit for a while in their storage tank to separate from water and dirt, then put it in the old cars they run around the place.
