Hot Rods OLD GAS TANK, big dent.
Discussion in 'The Hokey Ass Message Board' started by pecker head, Feb 23, 2019.
  1. The second smartest way to do a Good repair to that Tank is to remove one end so you can get inside and control what your doing, then replace the end. You can get Zink in a spray can and give the total tank a fresh coating.
  2. Atwater Mike
    Atwater Mike
    This is actually the preferred way as it would be done in a professional setting, all concern for cost aside...
    Reason revisited, my son tried 2 radiator shops to have his radiator 'rodded out'. Both told him they had done it, first one didn't even remove a tank.
    After questioning him (intensely) he admitted that a back flush was all he did.
    Son Rich then marked the tanks, tried the second shop. Bang! Caught the guy in the act...the guy referred Rich to a shop that would remove tanks and perform the act.
    Why doesn't anybody solder any more??? Hell, I do!
  3. seb fontana
    seb fontana
    from ct
    Time...Last Radiator shop I went to charged me $20 for fin straitening which didn't amount to much..Claimed it was boiled but I prob could have done better with vinegar..I would try the 2# pressure..
    ffr1222k likes this.
  4. The local Rad shop I use would not remove a tank either for that job. They use an ultrasonic system that brakes down the sediment and then flush it out. New days New ways.
    Okie Pete likes this.
  5. RMONTY
    RMONTY
    Sounds like the way they break up kidney stones nowadays!
    Okie Pete, czuch and Pist-n-Broke like this.
  6. 31Dodger
    31Dodger
    YES....THIS!
    oliver westlund likes this.
  7. That tank looks like it is soldered together. As mentioned I would pick one end closest to the dent . Heat up with a MAP gas torch and carefully with a air hose blow away the solder. You can now do the repairs and when done resolder the end back on.
    Vic
  8. sunbeam
    sunbeam
    If you remove the end stuff a deflated basket ball behind the dent and air it up. I have used this on body dents that are hard to get to. If you use pressure use water pressure why do you think they call it hydrostatic test? It will spring a leak not blowup. Tip if I repair a pressure tank I fill it with water then hook up my high pressure washer and run it until I reach my test pressure.
    RMR&C and s55mercury66 like this.
  9. s55mercury66
    s55mercury66
    from SW Wyoming
    Air, as @Pist-n-Broke said, would be my choice. Use a bicycle pump to keep the pressure manageable, and check for leaks at the same time.
  10. stillrunners
    stillrunners
    from dallas
    Harbor Freight sells a 115 volt spot welder......just saying....they help out a lot on dents that you can't really get behind - you use it like a dent puller - spot weld on a little stick weld dilly - and pop out - after you break it off and file smooth...under $100 bucks...........
  11. Garpo
    Garpo
    The fun bit of these posts, is some really know; some think they know; and some have no idea but post any way.
    Sit back and read 'em all. Then try to work out which is what .:rolleyes:
    Garpo
    ffr1222k, czuch, karl share and 6 others like this.
  12. Bad advice is not Fun or Funny by any means. If I haven't done it I sure as Hell won't tell some poor guy that don't know any better to do it. I have yet to see a stud or bolt used to lift a dent that didn't leave a high spot where it was attached. When you can't get behind that spot what are ya gonna do then? Oh Ya, Body Man in a Can that's a good plan. Do like the guy that built the car RMonty is saving and become a Sculptor not a metal man.
    ffr1222k, RDR, 54vicky and 2 others like this.
  13. I agree with Garpo on this. I have friends who are always willing to tell me how to do something , but when I call them out , they always have some excuse. Like to see these types struggle with the most simple task , but they most certainly can tell you how to do it ?
    Vic
    54vicky likes this.
  14. 56sedandelivery
    56sedandelivery
    I had a small metal barrel that I used to carry water for my FED for cool down (no cooling system on the rail). I actually had a hose end cap attached to the fill cap, water hose actually pushed the ends of the barrel out (hey, it held more water now!). That would probably push out the dent if you could control the ends somehow.
    I am But ch/56sedandelivery.
  15. What about paintless dent tools, I have some old ones.
  16. clem
    clem
    If trying this, (being an old gas tank-as per thread ***le) perhaps have someone video from a distance so we can see how it goes............
    ffr1222k, Okie Pete, LTM75110 and 5 others like this.
  17. tubman
    tubman
    I used to think this was a joke, but have found it is the only way I could get beads seated on some tires. I don't know if it would work for this, but if you try it, start small. I had about 20 failures before I got the first one set, but I still had my eyebrows when I was done.
  18. blowby
    blowby
    from Nicasio Ca
    I've probly seated 100 tires with starter fluid, as recently as a couple weeks ago. It's a pretty extreme explosion, you would definitely have to start small. I've also welded enough motorcycle fuel tanks that I no longer tediously wash them out. Just drain the gas, flush once with water to remove the remaining liquid and then a flame. The result is a quick WHOOSH out the filler hole from the remaining fumes, potentially about right to push out a mild dent, though I've never deformed a tank this way. I'd still be concerned about the results in this situation, unless it was a potential throw away tank.
    What I do for motorcycle tank dents is bend a piece of 1/2" plumbing pipe so it will reach the dent through the filler hole, smash the end into a s**** and apply pressure while tapping on the cir***ference on the outside as mentioned.
  19. Gerrys
    Gerrys
    If using air pressure fill with water and use a hand pump to control it. Do not use starting fluid unless you want to create a bomb.
    clem, rockable and 54vicky like this.
  20. 54vicky
    54vicky
    there is a big difference between a tire bead and a fuel? tank.the pressure in tank will blow out through the filler if you are lucky if not lucky it will lessen the gene pool.which may not be a big loss
    RDR, clem, Pist-n-Broke and 1 other person like this.
  21. woodiewagon46
    woodiewagon46
    from New York
    If I was to guess, I would say that by the 2" pipe thread flange and galvanized finish, I would think that the tank is from an old water system possibly an expansion or storage tank.
  22. Terrible80
    Terrible80
    This is hilarious! Put some air in that *****, use a regulator a few pounds won't blow it up, I'd even gently heat the dent with a rose bud if needed.
    Bandit Billy and Okie Pete like this.
  23. scotts52
    scotts52
    A possible alternative that I haven't seen mentioned yet is to fill the tank with hydraulic fluid. Then get a hand operated hydraulic pump. Rig a valve to seal the opening. You could S-L-O-W-L-Y start pumping in more hydraulic fluid and see where the pressure was forming. Maybe even use a rubber mallet along the edge of the dent to help relieve the stress and push the dent out.
  24. 51504bat
    51504bat
    If indeed this tank is a gas tank or if it ever had gas in it my advice is don't go anywhere near it with a torch. Just before I got out of the Army I spent 6 weeks working in the Post machine shop as part of a transition to civilian life. The shop supervisor related a story about a local who tried to cut into a 55 gallon barrel which by all accounts had been sitting empty for 30 years but at some time prior it had held gasoline. The empty barrel exploded as soon as he cut into it killing him. The super's point was that you never use a torch near a container that once had gas in it no matter how long it had been empty. Advice I heed to this day.
    clem likes this.
  25. RmK57
    RmK57
    One way I used to remove dents in headers is seal up both ends, then pressurize the tube with air and heat the area with a torch. Dent comes out nicely.
    Ad far as heating, welding gas tanks, I've done a few. Two good washes with Dove dish soap with hot water. Then rinse for 10-15 minutes with a garden hose and your good to go.
    Terrible80 likes this.
  26. Beanscoot
    Beanscoot
    I removed a dent in a more conventionally shaped fuel tank last summer with careful application of compressed air, using a rag wrapped around a blow gun held in the filler neck.
    Make sure to use a blow gun (or operator) that isn't only full blast all the time, and it's quite controllable.
    RMR&C and Terrible80 like this.
  27. clem
    clem
    What about the fuel that gets into the metal of the tank,
    Or,
    Just read post 54 above to see what I am getting at.
  28. According to some of these posts I should be Dead by now.
    Terrible80, egads and kidcampbell71 like this.
  29. clem
    clem
    I am always intrigued by the number of people that weld up gas tanks, and maintain that a water wash or two will make it perfectly safe.
    Then there are those that won’t do it under any cir***stances.
    Generally those in the second group know someone personally who has been in the first group and have seen or heard the consequences of when it didn’t go so well.
    I guess it is up to the individual to decide for himself/herself !
  30. clem
    clem
    Maybe next time, maybe not........
