old making tape on chrome..
Discussion in 'The Hokey Ass Message Board' started by hotrodwelder, Nov 1, 2009.
  1. hotrodwelder
    hotrodwelder
    What works the best and fastest to get old dried masking tape off of chrome bumpers?? I used mayo and it works very slowwwwwwwwww...
    Any ideas would be appreciated!
  2. hotrodwelder
    hotrodwelder
    MASKING TAPE IN THE TITLE !!!!!!!!!!!!!!!!!!!! sorry guys..
  3. Gerg
    Gerg
    goo gone or baby oil will soften the tape
  4. I used thinners, worked a charm for me.
  5. old beet
    old beet
  6. Lighter fluid or Goof Off HRP
  7. Dragons
    Dragons
    from Topock,AZ
  8. Fine steel wool works great on chrome. If you use adhesive remover it will speed up the process.
  9. FiddyFour
    FiddyFour
    lacquer thinner
  10. Unkl Ian
    Unkl Ian
    Save the Helmann's for lunch.
    Try WD40, Mineral Spirits, Lacquer Thinner, Acetone, etc.
  11. henry29
    henry29
    A lot of foamy spray window cleaners work good.
  12. mottsrods
    mottsrods
    I don't know where he got it, but a buddy, who owns a body shop, has this little rubber wheel for his angle grinder that takes the molding adhesive and other sticky crap off....and it doesn't burn through paint.
  13. skullhat
    skullhat
    i use lighter fluid all the time, works, cheap, and its easy
    skull
  14. super plus
    super plus
    On old masking tape a heat gun works , takes the glue with the tape . Just warm it but not to hot.
  15. hotrodwelder
    hotrodwelder
    Thanks for all the info, gonna try these ideas tonite.
  16. I use the stuff glass guys use for old stickers and such. Loosens glue and doesn't harm paint. Mine is called Super Seal release agent. Glasier supply stores handle it.
  17. whid
    whid
    X2...............................dave
  18. Squablow
    Squablow
    The eraser is an awesome tool for taking tape pinstripes, bumper stickers, or vinyl lettering off, I've used a few and with good results. Not sure how well it would work on masking tape though, I think it's designed for the vinyl. Might work.
  19. skullhat
    skullhat
    they pretty much take off everything well. i got 3 or four different types and sizes. great tool , as said, but i wouldnt reccomend a guy go out and spend the $$$ to clean up one bumper, now if ya can borrow it......
    skull
  20. Little Wing
    Little Wing
    from Northeast
    lil gasoline on a rag
  21. LANCE-SPEED
    LANCE-SPEED
    If its on chrome, spray some water on it then scrape w/ razor blade. A sharp blade wont damage the chrome.
  22. yessir!
  23. if it dried up flaky tape then a razor blade works fine if its still gooey almost any cleaner will do it try some fingernail polish remover cheap and easy to get
  24. Yeah, go ahead----use a razor blade on it. Then the first time you see it froom a certain angle in the sunlight. I gaurantee you will shit your pants!!!! Been there, done that, on a 65 mustang about 40 years ago. Get something chemical based to soften it up, then don't scrape it with anything harder than a plastic bodyfill applicator.
  25. ROBERT JAM
    ROBERT JAM
    wd 40 works well
  26. SanDiegoJoe
    SanDiegoJoe
    I usually use carb cleaner.
  27. Most any petroleum product will help. Goof-Off is good stuff.
    Don't use steel wool or razor blades if it's nice chrome.
