Old Rock Hard Caulking on Roof on my old 1934
Discussion in 'The Hokey Ass Message Board' started by uglyoldcrow, Dec 18, 2012.
  1. uglyoldcrow
    uglyoldcrow
    I'm beginning to get the hole in my roof ready for
    new wood and insert. Over the years it must have leaked a bit so they just kept gooping it up with a black caulk like shit. It almost looks like dull black glass and is harder then Kelsey's Nuts! Before I start grinding and sanding, I thought I'de check here to see if there is a better way. I'm not worried about hurting the paint as there isn't much left! Thanks, Jim
  2. chaddilac
    chaddilac
    Might try a heat gun to soften it up?
  3. williebill
    williebill
    Thinner or acetone to soften it up first?
  4. Old wood chisel & hammer :eek: Safety glasses for the chips that will fly all over the place.
  5. Nothing like that ol' Rock-hard Caulk.
  6. jetnow1
    jetnow1
    from CT
    1. A-D Truckers
    Often easier to remove with the old wood chisle/hammer than to soften and then remove if you can do so without damaging ajacent areas.
  7. uglyoldcrow
    uglyoldcrow
    Thanks Guys! I'm going to start with the wood chisel and hammer First. Jim
  8. Big Bad Dad
    Big Bad Dad
    Careful about grinding old putty like that. It may have asbestos in it. Dont want them fibers floating into your lungs!
  9. oldsmobum
    oldsmobum
    from SoCal
    Best reply so far :D
  10. Maybe use a shop vac to suck up the caulk as you knock it off there. I don't know how well it would pull the dust away, wear a filter maybe too in case of asbestos.
  11. 327-365hp
    327-365hp
    from Mass
    It's probably roofing tar, looks like black glass. Chisel it off, don't heat it, it'll get messy.
