Technical Old School brake conversion on a 32 Chevrolet
Discussion in 'The Hokey Ass Message Board' started by Lono, Sep 4, 2015.
  1. Lono
    Lono
    I want to convert mechanical brakes to juice on a 32 Chevrolet. I plan on running a 235/ powerglide on a stock boxed frame.
    I've tried looking for a build thread pertaining to this but cant find one.
    I want to keep it old school with nothing newer that say 60- 62. Any suggestions out there?
  2. 302GMC
    302GMC
    from Idaho
    In the old days, lots of those cars & trucks were converted to Huck hydraulics, but we don't do that any more. '51 up Bendix fronts from a pickup and a '51-'54 Powerglide torque tube axle , shortened for the '32. would be a mid to late '50s conversion. Your front axle can to be honed to use the larger '51 up 3100 kingpins & spindles. If you're staying with 6 lug wheels, the p***. rear axle shafts can be modified & pickup drums used, otherwise use '51-'54 p*** drum/ hubs up front.
    Using your '60-62 time frame, rodders were using '60 Chev truck dual master cylinders & hanging pedals by then. Since you're using a PG, here's a chance to get dual circuit brakes if you desire ...
    Lono likes this.
  3. paul55
    paul55
    from michigan
    Just to add to the above, you can actually use 49-54 Chev. p***. car backing plates, hubs and drums. Can also fit these spindles to your axle and use complete set-up.
    Lono likes this.
  4. tb33anda3rd
    tb33anda3rd
    Lono likes this.
  5. Lono
    Lono
    When you say, use the complete set up, your talking brakes or are we talking changing the steering components as well?
    I plan on going 235 and before i pull out the original drive line, My mind wonders to the motor/ ****** and if a pre 59 235 will bolt up to the stock ******?
    Thanks guys for your input.
  6. Lono
    Lono
    Here's a couple pictures from when it was bought. 32.jpg 11998378_164198680583888_1892838973_n.jpg
    tb33anda3rd likes this.
  7. squirrel
    49-50 brakes are Huck, 51-54 are Bendix type. You can also use the original spindles, and play around with the bolts and spacers to mount the later backing plates. The original inner wheel bearing inner race might be needed to fit the later hubs onto the original spindles.
    51-54 car hubs and drums are 5 lug, and will fit the same as 51-59 truck 6 lug hubs and drums.
    Lono likes this.
  8. TFoch
    TFoch
    Nice ride! 32 Chevy's are cool.
    Lono likes this.
  9. Lono
    Lono
    So a sheepish, dumb*** question... will a 59 235 bolt into the stock ******?
  10. 302GMC
    302GMC
    from Idaho
    You don't want to do that ... what you want is a '41-'47 pickup 3 speed & the bellhousing to go with it. I like to use a '54 10'' truck flywheel, & a diaphragm pressure ***'y when keeping 6 volts, & I don't dump the clutch in low ... u-joints & axle shafts are getting scarce.
    Lono and tb33anda3rd like this.
  11. tb33anda3rd
    tb33anda3rd
    i honestly can't tell you they would or won't .
    how do the pedals mount? if they bolt to the bell housing you have to see if the bell mounts to the later engine [i don't think it does] . so you might have to change to a later ****** and mount the pedals to the frame.
  12. Lono
    Lono
    Still waiting for its homecoming. 33 is frame mount, not sure about the 32.
  13. squirrel
    if you want to install a later 235 engine, you might consider going to an open driveline. The rearend housing and axles from a 41-46 truck can be made to fit, and you can put a late 50s open drive center section into it. The 40s truck rear came with hydraulic Huck brakes.
  14. logride
    logride
    from CB IA
    The chevy mechanical brakes aren't the worst with good cables and don't leak.
  15. Gofannon
    Gofannon
    ...and you can use late 50's internals in that '41-'47 pickup 3 speed for slightly stronger box with better ratios. I think the truck rear axles are heavier, aren't they? Use early 50's truck with the 3.55:1 gear set, and bendix brakes.
  16. PBRmeASAP
    PBRmeASAP
    hugh fan of 32's
    keep us posted as to what you do and figure out.
  17. Gofannon
    Gofannon
    There's a very cool 32 pictured in this article, owned by George Varden. Does anyone have any more info? I think there was a magazine feature done on the car mid 50's. It would be interesting to see what the rest of the driveline is, for Lono's sake.
    [​IMG] [​IMG] [​IMG] [​IMG]
    Lono likes this.
  18. paul55
    paul55
    from michigan
    Okay, been awhile since dad and I messed with the stock axle, but..... here goes. If I'm wrong on anything, hopefully someone will correct me. The 49-54 p***. spindles and brakes will work on the '32, but the '32 kingpin is smaller, so you'll need different spindle bushings for the smaller pin. Also, will have to fit thrust bearing and shims between bottom of axle boss and spindle. Could also use later 1/2 ton axle with hydraulic brakes to maintain 6 lugs. Or, use this complete set-up and use 49-54 p***. 5-lug drums on the 1/2 ton spindles. There are a few other combos that we'll have to try and remember, as we've been messing with early Chevs for over 40 yrs. Hope some of this helps.
    Lono likes this.
  19. paul55
    paul55
    from michigan
    Forgot, the outer bearings are the same for many of the years mentioned, but the problem with the '32 spindles is the smaller dia. of the inner. Suppose you could machine a spacer/sleeve for the spindle and fit later backing plates and drums to stock '32 spindles.
  20. Lono
    Lono
    Thats the Engine bay I want!!!!
    Thank you for posting this great article.
  21. Lono
    Lono
    I'd like to keep the front axle intact. So from your comments will this work ( CORRECT ME IF I'M WRONG PLEASE):
    Stock Axle
    49-54 p***. 5-lug drums and 53/54 brakes
    Modified kingpin, thrust bearings and shims
  22. squirrel
    49-50 brakes and drums are different from 51-54 brakes and drums. Huck vs. Bendix.
    Lono likes this.
  23. Gofannon
    Gofannon
    Check your king pin angle. Beam axles are around 7 degrees, 39 to 54 p***enger cars about 4 1/2. Trucks have deeper steering arms. I'd use truck spindles (7 degree) with bendix brakes. If you want 5 lug, p***enger car hubs bolt straight on.
  24. volvobrynk
    volvobrynk
    from Denmark
    This might be the most stupid question of the day, but here goes. I've found a good rear end from a 34 master, and after looking at it for 5 minuts i got this weird ideer: install to clutch slaves to move the manual brake arms.
    Will this work or be stupid in epic proportions?
  25. Gofannon
    Gofannon
  26. Gofannon
    Gofannon
    It would work, with careful thought to cylinder sizes, stroke, and angles etc. It would never be as good as Bendix brakes as they are self energising.
    tb33anda3rd and Lono like this.
  27. Lono
    Lono
    Got ya. So I'll correct that to 53-54 brakes, drums and backing plates on the stock spindles...
    F@#$! I think I'm in a fog bank...
  28. 302GMC
    302GMC
    from Idaho
    It would work, but hydraulic Huck brakes aren't much better than dry ones ...
  29. volvobrynk
    volvobrynk
    from Denmark
    According to my math the rear brakes on surply 45-50 % of the stopping power. And that will ensue that it doesn't try to flip back to front on heavy braking.
    And in the last month or so I got the hankering for a torque tube rear end instead of the open Nissan.
    And I'm going 1956 truck front brakes, in the front. So my believe they should stop the car just fine.
    According to the VCCA page, "them stock brakes stop more then good, and if you stop any harder you will separate the body from wood!!"
