Projects Old school cool 248 Gmc
Discussion in 'The Hokey Ass Message Board' started by Neb Hillbilly, Dec 26, 2019.
  1. GMC BUBBA
    GMC BUBBA
    THATS NOT AS GOOD AS YOU THINK IT IS !!
    Take the clip off and slip the cam up and clean and lube everything with some light lube heres what we use on a rebuild . Will last for years !!! Might as well know off the drive gear remve th4e shaft and polish and clean / lube everything ....Just remove spring from piston on advance unit .... IMG_3577.JPG
  2. GMC BUBBA
    GMC BUBBA
    Hands down Nicsons !!
  3. Neb Hillbilly
    Neb Hillbilly
    well ****, apart it comes. Use the stock style vac advance?
    Sent from my S48c using The H.A.M.B. mobile app
  4. Neb Hillbilly
    Neb Hillbilly
    ****, all you guys should have told me before! oh well that is an easy change. I will look for a pair.
  5. Six Ball
    Six Ball
    from Nevada
    When I built my 270 In the 70s I got a set of Viper long tube headers from Clifford. They worked great. I only took them off because a piece poppet out where I had to put a little ding in one pipe to clear the intake manifold. I now have some of the repo Fentons. They work.
  6. jimmy six
    jimmy six
    Don't know on the Nicsons but your choice of the Clifford tube is a very good one way better than Fentons too me. I'm using the Nicsons because I bought them 40 yrs ago for $50 at the Pomona Swap meet. I too would have done the same. Many years ago Clifford had long tube and just the 3/8" thick flanges. I have a set or 2 somewhere in my stash.
    Your project is doing great ...keep it up for all of us.
  7. Neb Hillbilly
    Neb Hillbilly
    I asked about the vipers but they no longer make them. I prefer long tubes but these should be better than the Fenton's.
    Gofannon and loudbang like this.
  8. Neb Hillbilly
    Neb Hillbilly
    I didn't take any pictures today but I got the cam gear installed and was pushing on the crank gear when it appears the rods and cam hit. The crank gear needs to go on about a 1/4 more but I think I may have to grind the cam a bit. It is a bigger cast core and the rods may be slightly different with the 302 rods. We will have to further investigate.
  9. Six Ball
    Six Ball
    from Nevada
    The rods should be the same. I don't know if the 270-302 cam had notches like the 292 does. There could be a difference in steel and iron cams, I don't remember hearing that but there shouldn't be an issue in a 248. Didn't you put in some after market rod bolts? That's the first thing I'd look at.
  10. Neb Hillbilly
    Neb Hillbilly
    it actually is a 1941 270 block because the 248 was s****. The cast cam does have cut outs for the rods, they may need deepened. Pictures to come. Does show stroke is not easy to get in this application.
  11. jimmy six
    jimmy six
    I'm not sure I understand your explanation. The crank gear should have been on the crankshaft before it was installed in the block. The cam gear should be on the cam with 2 bolt flange behind and the proper clearance. From memory .003-5". The front plate which may or may not have a mount then goes on with the oil squirter aiming straight down at the crank gear. Then you slide in the the cam lining up the 2 marks. I have the crank gear aiming at where I believe the cam gear will line up. The cam will sit in all the bearings just barely so you can make the cam turn the few teeth so it will finish sliding in lining up the marks. I just did this last month with a large cast cam, not a cut down steel using the same rods.
    You them install the 2 flange bolts. The cam should "rattle" slightly on the gears and you should feel the clearance on the cam flange.
    I have put the cam in before the rod/pistons and after. It is easier with the pistons out so you can put you hand in easier to help with the cam. J.D.
  12. Neb Hillbilly
    Neb Hillbilly
    I did it a little wrong, rotator is in, put in the cam and bolted it down then was pushing on the crank gear. Crank started to turn and caught the cam. I will pull the cam tomorrow and then install the crank gear. it was a bit of disorganization but I didn't remember the crank gear wasn't installed yet.
  13. Neb Hillbilly
    Neb Hillbilly
    Now time for the rest of the story. The new rod bolts were indeed hitting the cam. Since the cam was the easier part to remove I pulled it and used one of those fancy hand held belt Sanders to deepen each of the reliefs. You can see where 3&4 were just touching the can. I then recleaned and polished the bearing journals and reinstalled the cam and checked a few of the tight bolts and there is an easy .015 or more clearance in each one.
    We then started on the head. All the guides had been previously knurled so the all were replaced this morning. First we cut them out, finish honed the interior, cut down the rest of the old guide, drive in new guides, shortened the new guides to allow enough for .480 cam lift, .200 for positive seal and .015 for some fat. There will also be clearance added when the new 1.94/1.60 seats are cut so the valve sits deeper. IMG_20200414_051836.jpeg IMG_20200414_054337.jpeg IMG_20200414_060918.jpeg IMG_20200414_060918.jpeg IMG_20200414_065116.jpeg IMG_20200414_070344.jpeg IMG_20200414_072935.jpeg IMG_20200414_074555.jpeg IMG_20200414_075223.jpeg IMG_20200414_075640.jpeg IMG_20200414_080905.jpeg IMG_20200414_081658.jpeg
    64zim, LAROKE, Six Ball and 1 other person like this.
  14. jimmy six
    jimmy six
    I understand the cam hitting problem rod bolt/nut after seeing it. I have never replaced them in 45 years of racing and never lost one, just changed the nuts. Glad it worked out.
    Six Ball and loudbang like this.
  15. Six Ball
    Six Ball
    from Nevada
    I thought that might be it because that was the only thing you had changed in crank/cam relationship. The head looks nice. It is interesting that the chambers can be cut that much.
  16. Neb Hillbilly
    Neb Hillbilly
    I hope the head doesn't end up bitting me on the **** later. If it does, then I guess I will have to buy a 270H head.
    64zim, Six Ball and loudbang like this.
  17. jimmy six
    jimmy six
    Any early small port head will work with those pistons. With a taper to a big port manifold and blending causes a venturii effect when the valve first opens you will have instant torque up to the rpm where a street engine normally runs. If it wasn’t that I had them, both H and D’s I would never have worried about a small port.
    Have you sonic tested the side you removed metal to clear the piston? Doug Robinson of the BMR LSR blown GMC’s told me the H had more metal but I have never cut one to see.
    Good luck and thanks for sharing.
    loudbang and Six Ball like this.
  18. Neb Hillbilly
    Neb Hillbilly
    The head was already ground that way when I pulled the original 248 apart. Really, I have now built a whole new engine based on a set of antique Jahn's pistons, a questionable head and a Mallory dist. Didn't end up using nearly anything else, but I have a few spare for the barn. Most of the stuff had ever been run in the 248 so the pistons/rings are more or less new. Kinda scared to thickness check the ground portion, but I may in the morning. I have 2 small port 2 x 1 intakes and a 477 head but I guess I am dumb enough to want the big port just because. If I do use a small head I will have to dig into my "fluids" book to find the proper dimensions to cut a true venturi shape for the best transition. The stupid drag racer in me is having a hard time with "street" even though I know this just an old truck that will never be quick, I seem to always push it a bit.
    So here is this evenings question. Where do I get the stud seals for the valve cover? Nothing in my Felpro gasket set and nothing on Napa online.
    64zim and loudbang like this.
  19. jimmy six
    jimmy six
    Y-Block Ford rocker and valley plate cover....J. D.
    Tman, Six Ball and loudbang like this.
  20. Neb Hillbilly
    Neb Hillbilly
    Took the day off in a pandemic to work on the head. First I checked the cut back part of the chamber. Thinnest spot was .250" but most were over .400". Should be plenty thick. Took a couple pictures how does not heat the chamber cutting back was. Cut the intake seat, bowl hogged under the valve and cut back the chamber. Then cut the exhaust seat. I did some mild porting, squared the exhaust floor, blended the short side radius as much as possible. Flowed the head and it flows 195 cfm on the intake and 135 on the exhaust at .550". This is very similar to a stock small valve small block Chevy head. Certainly not great but not horrible. Head checks straight so no need the mill it. They are finish grinding the seats and Friday morning we will look at springs. IMG_20200415_061250.jpeg IMG_20200415_061303.jpeg IMG_20200415_061311.jpeg IMG_20200415_061349.jpeg IMG_20200415_063143.jpeg IMG_20200415_063212.jpeg IMG_20200415_102326.jpeg IMG_20200415_102652.jpeg
    64zim, loudbang, Gofannon and 2 others like this.
  21. 302GMC
    302GMC
    from Idaho
    You certainly build a fine looking GMC, cleanest machine work I've ever seen ….
    The rocker cover nuts were tapered to self seal on the 228-302 ...
  22. jimmy six
    jimmy six
    I see the br*** water guides are still your head, these are very important an if you look into them you can see the water driving up the block to the head directs the cooler water to the exhaust valves...
    302 GMC is correct if you have them. They not only taper they have a portion that's straight and go into the cover to help center it but has no gasket. The Ford Y-Block rubber seals have a taper and with a flat washer makes a good oil seal. Just another option.
  23. Neb Hillbilly
    Neb Hillbilly
    My buddies at the machine shop work on Y blocks regularly so I will see if they have a set. I can't afford a aluminum valve cover so I was going to put chrome acorns on my powder coated stock valve cover.
    Thanks for all the support guys. I am trying to do everything to the best of my ability and pocket book.
  24. Gofannon
    Gofannon
    Do you have the cover with the embossed GMC logo? Coolest valve cover there is for a GMC, IMHO.
  25. Neb Hillbilly
    Neb Hillbilly
    Yes this one. A Nicson or Wayne would also be cool. tapatalk_1583536601825.jpeg
    64zim, LAROKE, loudbang and 1 other person like this.
  26. Six Ball
    Six Ball
    from Nevada
    The newer straight letter one is cool too. Funny the GMC is the only one I can think of where the stock cover is cooler than any of the after market covers. Cadillac and Olds Rocket come close
    I tried to cut one down for my 4 cylinder bur it didn't work. They are not as straight as they look and very thin.
  27. jimmy six
    jimmy six
    That one has the hole for a copper tube and no vents. I believe it’s military. But I’ve been wrong on a lot..
  28. Neb Hillbilly
    Neb Hillbilly
    This one is actually from a 248 that came out of a bus, well that is what I was told. It has a early PCV system. I will take a picture of my military 6x6 302 when I steal the manifolds for break in of this engine. It is likely very similar or the same. My 55 GMC 150 248 has a vented top and just a road draft tube. I plan to run a PCV system but not sure what it will be made up of yet. I also have the valve cover that came on the 248 I bought with 2 breathers attached. They are welded on crooked so idk if I could stand to use them. IMG_20191218_060509.jpeg IMG_20191218_060521.jpeg
  29. Neb Hillbilly
    Neb Hillbilly
    loudbang, Six Ball and LAROKE like this.
  30. Neb Hillbilly
    Neb Hillbilly
    Worked on ***embling the head today. Going to use "Z28" SBC springs for 100lbs of seat pressure. Also using positive seals on the guides. Pics tomorrow
