Hi guys, Finally got my tri-power rebuilt. Wondering if you guy's might have some leads for old style fuel lines and logs out there. Hope to have stainless lines into the carbs so I'll probably stay away from the mounted style blocks. Thanks in adavnce
Why not carve out a neat little aluminum bracket to attach to a couple of carb mount studs, then mount a 1-1.5 inch hexagonal piece of AL? Drill and tap the hex AL from the bottom to mount on the bracket. Drill and tap the hex AL to 1/8" NPT and use compression fittings. This would allow you to use SS lines. Check online metals.com for hex aluminum and SS tube.
