Technical old school gauges installation
Discussion in 'The Hokey Ass Message Board' started by The_Cat_Of_Ages, Mar 5, 2025.
  1. found them in @Moriarity's thread on the car C850B629-ECC8-4A54-9EF6-D20726D92B20.jpeg 10A90BD1-A330-4217-BB3D-8D7F794BF3AB.jpeg
    that thing is a LOT chunkier than i expected it to be. looks simple enough, ground to ground, power to power, negative to ground, and positive to tach
    61Cruiser and Moriarity like this.
  2. cant find an oil and volt gauge combo, the only ones i see are amp and oil.
    might get the amp/oil and leave the amp unhooked for now, as the indirect lighting stewart warner volt gauges are kinda pricey.
  3. just my luck... the moment i posted that a gauge got listed at an affordable price.
    so i have my gauge set. my wallet is crying tho
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    [QUOTE="The_Cat_Of_Ages, post: 15523174, member: 363976" my wallet is crying tho[/QUOTE]
    money spent on an old car is never wasted....
  5. swade41
    swade41
    from Buffalo,NY
    I have no idea what this brand is but I bought them at a swap meet and put them in my t-bucket almost 20 yrs ago, they have the slots on back for the illumination, no issues with the amp guage and an alternator.
    The illumination really ****s though, I try to look at them while driving under a street light, because you can't read them they're so dim.
    The_Cat_Of_Ages likes this.
  6. 57Fury440
    57Fury440
    I have three gauges under my dash. One has the light right in the back of the gauge and it is easy to see at night. The other two are side lit and they were putting more light on the floor than in the gauges. I made a shield out of thin cardboard, and it helped a lot.
  7. im just hoping my 57 makes sufficient oil pressure. been too scared to check. imagine it only makes 15 psi at 3500 rpm... scary thought
  8. squirrel
    you might be surprised how little oil pressure an engine needs, to keep running. Model Ts had no oil pressure at all, and there are plenty still going after 100+ years.
  9. swade41
    swade41
    from Buffalo,NY
    I'll let you borrow some of mine, if you look where my guage reads lol
    61Cruiser likes this.
  10. the tach transmitter arrived, absolutely junk inside, so much corrosion, definitely glad im gonna swap in the tach match.
    tach will fit perfectly where squirrel suggested :)
    RodStRace and Moriarity like this.
  11. got the tach and gauges installed and the tach box gutted. now just need to make them work... 20250312_174129.jpg
    whacha think for tach box placement?
    drivers side fender or upper firewall?
    RodStRace likes this.
  12. RodStRace
    RodStRace
    Fenderwell. Firewall is right above the exhaust. It will get warm. Also looks like it will partially block Dist. access. No need to made a cl***ic as hard to work on as a modern POS.
  13. fair enough, seen lots of them on the firewall and saw only two good places.
    fender it is. now its a waiting game for the tach match.
    what size oil feed line would i need? also how would i flare it because iirc my set only goes down to 3/16
  14. thall
    thall
    from nc
    Anyone used high pressure grease gun hose for Oil pressure gage? thought about maybe 2 or three 18" sections with connectors to join them, or a 48" milton from amazon (doubt I will need more that 48") presently have copper to plastic to an old sun blue line mounted on cup on column in 56 f100
    as mentioned above, have to offset it to left or right and a bit low. have tach on left side and sun blue line OP on right, steering wheel still gets in way a bit
    will look into the tach thing mentioned , was going to send my sun out for retrofit... but this may be a better option for this 6k and messed up transmitter... I 'cheeped' out with a retro look bosch 8k and it has worked.
  15. RodStRace
    RodStRace
    BJR, 61Cruiser and The_Cat_Of_Ages like this.
  16. thall
    thall
    from nc
    the plastic and copper for oil pressure typically 1/8" tubing and have compression fittings, not flare
  17. you can see how i mounted it here, i dont have the lighting for it done yet, will soon though.
    so far i only have like 200 in this whole project, fortunately wiring is cheap as i have crimps and wire, and my dad has copper line somewhere, need to pick up the fittings.
    other than lighting my floor up a tad too much, this is great! 20250312_195842.jpg
    very bright
    Speed~On and squirrel like this.
  18. i think im gonna tack on a little piece of black cardboard similar to my glovebox onto the back of the gauges.
    going to also install a fuse for my tach matches power feed.
    need to pick up some gasket material to cut out for the tach transmitter box, the gasket crumbled to bits.
    heres hoping all goes smoothly on the tachmatch install and oil pressure gauge install.
    just waiting on the voltmeter. probably going to run the wiring for it but not hook it up.
  19. RodStRace
    RodStRace
    If it's holding the electronic box, it should be okay to just seal it with a cereal box gasket.
  20. BJR
    BJR
    pprather and The_Cat_Of_Ages like this.
  21. RodStRace
    RodStRace
    When I found that link, it of course mentions that copper line work hardens, and shouldn't be used. It's strange that there isn't a kit for this that uses nicomp tube. I wonder if it's due to it not being soft enough to form a seal or no demand.
    The_Cat_Of_Ages and BJR like this.
  22. BJR
    BJR
    I have used copper line for oil pressure gauges for over 50 years, never had a leak. But I always put a few loops of line to spread out and absorb movement on the engine side of the firewall.
    The_Cat_Of_Ages and RodStRace like this.
  23. RodStRace
    RodStRace
    Same here, @BJR , Never had one give me trouble either. Just wanted to mention it so that it's covered and maybe there is a new solution someone knows about.
    BJR likes this.
  24. Little trick I did on my Stewart Warner temp gauge that has only light windows in my panel truck. Single LED with a sticky back and some aluminum tape. Use 1 or 2 LEDs above the windows stuck to the gauge panel and the aluminum tape to cover the back area between the gauge and housing so no light shines on the floor or into the dash.
    Algoma56 likes this.
  25. update the voltage gauge arrived... and its blue lit.
    @Moriarity how would i change that? the gauge doesnt seem to come apart
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    no, you can't really change that, the side light windows in the gauge are blue transparent plastic.
  27. i made the mistake of touching it... oops ripped right through one at the smallest touch. i barely brushed it.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    If that gauge is old, that plastic can be fairly brittle
    it doesnt fit in the bracket i have. it also has a "notch" at the bottom
