Old Skool Fuel Line
Discussion in 'The Hokey Ass Message Board' started by Justme, Aug 18, 2006.
  1. Justme
    Justme
    from GA.
    I'm looking for 3/8 old style transparent red fuel line.
    Many Thanks
    Sean
  2. Check mooneyes, or speedway.
  3. stea
    stea
  4. Thirdyfivepickup
    Thirdyfivepickup
    buy a fire extinguisher.
  5. Justme
    Justme
    from GA.
  6. Bugman
    Bugman
    What he said. It has a tendancy to get brittle and crack with use.
  7. NV rodr
    NV rodr
    from Reno, NV
    I actually saw an old ford truck running that stuff leak fuel onto the exhaust then catch fire. When the fuel pump kept running the flames reached three feet higher than the cab of the truck. It took two extinguishers to put it out.
  8. DE SOTO
    DE SOTO
    The deal with this stuff is ...... YOU NEED TO REPLACE IT FREQUENTLY !!!!
    Thats why cars catch fire, People alow it to get past the hard stage .. to the brittle stage ... and then it BREAKS !!
    SO.... If yer gonna run it, buy alot so you can maintain it .... switch it out OFTEN .....Before it gets to the point it may break
  9. Thirdyfivepickup
    Thirdyfivepickup
    ...and it looses its red color if you don't have a hood. That is the good time to replace it.
  10. kornbinder
    kornbinder
    from Sonora, CA
    You may want to reconsider using the stuff. I speak from experience.:eek:
  11. blown49
    blown49
    Ouch!!!!!!!!!! That's a damn shame:(
  12. 5window
    5window
    I'd also be really curious as to how this stuff stands up to gas with ethanol in it,which is all you can get around here. Can't be better.
