Hot Rods Old Speed?
Discussion in 'The Hokey Ass Message Board' started by Greezy, Nov 16, 2009.
  1. Tsquared
    Tsquared
    from Pratt, Ks.
    That`s what I was thinking...carry another 3rd member and change at the track...I`ve got 4:11s in my `40 ford....but would like to try 4:30s or 4:56s just to see what that would do to my timesand MPH in the quarter...I`d also like to try 3:50s or 3:73 to see what it does with mileage.
  2. hiboy32
    hiboy32
    from Omaha, NE
    Troy, I know Dallas changes third members in the Hellraiser. Has nine inch under his coupe and he says it takes less than hour.
    would be fun to try.
    Also, in Troys case, his engine could turn the RPM and can use the extra gear. I know that alot of people put gearsbehind a stock engine and can bearly make it to end of a quarter
  3. hiboy32
    hiboy32
    from Omaha, NE
    I was hoping for a few photos of these vintagespeed cars.....
  4. Von Hartmann
    Von Hartmann
    I'm running a 331 chevy in my 52 henry j g***er. The block is a '68 and has '66 double humps on it. This exact motor wasn't made before 65, but something they would have been running then. I've got a weiand crossram on it with discontinued 390 cfm holley double pumper race carbs on it. Best run so far was a 12.87 but I have yet to get a good run out of it since a ****** rebuild and a gear change to the 4.11.
    Shortly after the hunnert car heads up I hydrauliced #8 cylinder and bent the **** out of the rod. So I'm going to rebuild it again this winter with forged rods and a nastier solid Isky Cam.
    Current trans is a TH400 with a 3000 stall, BUT I have a mint B&M Hydro Stick under the bench that will go in it once I find a starter and a flex plate. It has the chevy adapter and everything.
  5. Von Hartmann
    Von Hartmann
    A pic of my old bomb spankin my buddies cougar.
  6. hiboy32
    hiboy32
    from Omaha, NE
    Thank you for posting ( with pics ). It is *****in to see early iron runnin good. I really want to hear about something other that a sbc. How about an early olds or caddy.
  7. HellRaiser
    HellRaiser
    from Podunk, NE
  8. Greezy
    Greezy
    Lets hear more from the B.O.C guys. And the Blue oval bunch.
