Old steering wheel I.D. ? Help
Discussion in 'The Hokey Ass Message Board' started by Standard gas&oil, Feb 28, 2011.
  1. Standard gas&oil
    Standard gas&oil
    from USA #1
    I'm wanting to install a cl***ic Grant wheel on my hot rod and I need to know what this steering wheel came out of to order the correct installation kit. Its a large shaft, tapered with no splines and has a keyway.
      55.4 KB
      51.9 KB
      61.1 KB
  2. Intro please...
  3. Standard gas&oil
    Standard gas&oil
    from USA #1
    Intro.... been there done that. Not one person knows anything about this wheel ? Anyone............... Bueller.
  4. squirrel
    How about a closer up pic of the horn ****on, and of the steering gearbox? does it look like it's original for the car? what kind of car is it? I can't see little pictures very good
  5. Standard gas&oil
    Standard gas&oil
    from USA #1
    I will snap some new pics today. It does not look to be original for this 1950 chevy truck. I bought this hot rod truck half finished. Thanks.
  6. Idaho/Dave
    Idaho/Dave
    from Idaho
    is the end of the shaft were the keyway slot tapered, it looks early Ford to me?
  7. Standard gas&oil
    Standard gas&oil
    from USA #1
    Yes, the shaft is tapered. I like the wheel but its 18' and pinches my leg as I get in and out of the truck, Im 6-1 200 lbs and want to use a smaller cl***ic metalflake wheel. Thanks for the help. Early Ford ?
  8. Or Willys/Overland. Willys was still running a taper shaft with a wheel like that clear up into the '60s.
  9. espo35
    espo35
    from california
    My guess is Ford Truck, pre-1954
  10. Standard gas&oil
    Standard gas&oil
    from USA #1
    I purchased the Ford hub kit from speedway and it does not fit the shaft. The shaft is to big. Any other options ? Help.
    :confused:
  11. Standard gas&oil
    Standard gas&oil
    from USA #1
    Anyone............................? Bueler
